Hvordan åpne en webside fra vb?
Er ikke helt rå i visual basic, men her er litt kode...
Public test As String
Dim mbDontNavigateNow As Boolean
Private Sub Form_Load()
On Error Resume Next
Me.Show
tbToolBar.Refresh
Form_Resize
startside = "http://dokumenter.mine.nu/"
cboAddress.Move 50, lblAddress.Top + lblAddress.Height + 15
If Len(startside) > 0 Then
cboAddress.Text = (startside)
cboAddress.AddItem cboAddress.Text
startside = "http://dokumenter.mine.nu/trening/index.php"
'try to navigate to the starting address
timTimer.Enabled = True
brwWebBrowser.Navigate (startside)
End If
End Sub
Private Sub brwWebBrowser_DownloadComplete()
Me.Caption = brwWebBrowser.LocationName
End Sub
Private Sub brwWebBrowser_NavigateComplete2(ByVal pDisp As Object, URL As Variant)
Dim i As Integer
Dim bFound As Boolean
For i = 0 To cboAddress.ListCount - 1
If cboAddress.List(i) = brwWebBrowser.LocationURL Then
bFound = True
Exit For
End If
Next i
mbDontNavigateNow = True
If bFound Then
cboAddress.RemoveItem i
End If
cboAddress.AddItem brwWebBrowser.LocationURL, 0
cboAddress.ListIndex = 0
mbDontNavigateNow = False
End Sub
Private Sub cboAddress_Click()
If mbDontNavigateNow Then Exit Sub
brwWebBrowser.Navigate cboAddress.Text
End Sub
Private Sub cboAddress_KeyPress(KeyAscii As Integer)
If KeyAscii = vbKeyReturn Then
cboAddress_Click
End If
End Sub
Private Sub Form_Resize()
cboAddress.Width = Me.ScaleWidth - 100
brwWebBrowser.Width = Me.ScaleWidth - 100
brwWebBrowser.Height = Me.ScaleHeight - (picAddress.Top + picAddress.Height) - 100
End Sub
Private Sub statistikk_Click()
End Sub
Private Sub timTimer_Timer()
If brwWebBrowser.Busy = False Then
timTimer.Enabled = False
Else
Me.Caption = "Laster..."
End If
End Sub
Private Sub tbToolBar_ButtonClick(ByVal Button As Button)
Select Case Button.Key
Case "Back"
brwWebBrowser.GoBack
Case "Forward"
brwWebBrowser.GoForward
Case "Refresh"
brwWebBrowser.Refresh
Case "statestikk"
webserver = "http://dokumenter.mine.nu/trening/statestikk.php"
brwWebBrowser.Navigate (webserver)
Case "rekorder"
webserver = "http://dokumenter.mine.nu/trening/rekorder.php"
Case "stopp"
webserver = "http://dokumenter.mine.nu/trening/stopp.php"
Case "start"
webserver = "http://dokumenter.mine.nu/trening/index.php"
Case "mat"
webserver = "http://dokumenter.mine.nu/trening/mattips.html"
End Select
End Sub
Private Sub trening_Click(Index As Integer)
End Sub
Hvis du mener å bare åpne en webside fra VB i standard web browser, og ikke i en browser inne i vb programmet ditt som jan rune sikter til. Kan du bruke dette kode eksemplet.
Option Explicit
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Private Const SW_NORMAL = 1
Private Sub Command1_Click()
ShellExecute hwnd, "Open", "http://www.hardware.no", "", "", SW_NORMAL
End Sub
ShelleExecute kommandoen kan du også bruke til å åpne alle type filer i det programmet de er registrert å bli åpnet i.
(Redigert pga av en liten bug i kode eksemplet:)
[ Denne Melding var redigert av: Rep på 2002-08-26 00:17 ]
