Mr_Snuffles Skrevet 1. november 2005 Del Skrevet 1. november 2005 Disse bildene er hentet fra et innlegg på Xbox 360 forumene til IGN. Xbox 360 bildene er tatt av skjermen til en demokiosk på EBgames i USA. PC bildene er hentet fra den offisielle demoen som kan lastes ned herfra. PC bildene ble også tatt 'off-screen' med samme kamera for å gjøre forholdene så like som mulig mellom versjonene. PC over og Xbox 360 under: The first part of the "Chased" demo. The campfire in the 360 demo is so much more detailed. The pillars have much more texture patterns, shadows, and heat bending effects from the flames that you can't appreciate with this off-screen shot. This next shot is right outside this little campfire. Believe it or not, these two screens are from the EXACT same location. The rocks are non existant in the PC version. On the 360 you can see vegetation and the rocks have a realistic weatness that reflects light as the rain bounces off. After going through the cave, you reach your friends by where the dinosaur makes his first appearance. The cobblestone here is just as impressive as the rocks in the last screens with rain bouncing off of what appears to be paralax mapped cobblestone. The PC version just looks like flat shaded lines on the floor in comparison. Now the Kong Demo. The lighting, the fur, the facial textures, the scars, but most notably and what jumps at you immediately is the LIGHTING.... and oh... did I mention the lighting!! drooling The PC version looks ok, but its amazing what advanced lighting and shadowing can do to a game. Lenke til kommentar
Torrevieja Skrevet 1. november 2005 Del Skrevet 1. november 2005 Skarpere bilder på Xbox 360, hvertfall på de 3 siste sammenligningene. Kjører vel på en HDTV sikkert. Siste bildet var Lekkert ! Lenke til kommentar
MindTooth Skrevet 1. november 2005 Del Skrevet 1. november 2005 Lurer på hvilke oppsett de PC bildene ble kjørt på. Virket veldig tampt. GO Xbox 360 Lenke til kommentar
TCi Skrevet 1. november 2005 Del Skrevet 1. november 2005 Syns det er littt rart at de PC bildene ikke har noe slags specular eller paralax mapping... eller hva det nå heter. Ser ingen grunn til at PC versjonen ikke ville kunne få ut til dels samme grafikk. Men 360 er jo en dedikert spillemaskin så den burde se litt bedre ut da utviklerene kan slenge på flere effekter. Det virker som at PC versjonen har blitt utviklet med tanke på maskinvarestøtte istedet for utseende. Lenke til kommentar
Bad_Byte Skrevet 1. november 2005 Del Skrevet 1. november 2005 Jeg prøvde demoen på min spill pc (amd xp 2500 / radeon 9800pro) og grafikken så like lille ut, lille er kanskje ikke helt rett ord men tatt i betraktning til xbox360 bildene Lenke til kommentar
Mala Skrevet 1. november 2005 Del Skrevet 1. november 2005 Artig sammenligning :!: Lenke til kommentar
Mr_Snuffles Skrevet 1. november 2005 Forfatter Del Skrevet 1. november 2005 Det hersker ingen tvil om at en high-end PC vil kunne kjøre med samme detaljer som det vi ser i Xbox screenshotene. Xbox 360 versjonen er laget etter de andre versjonene, mer som en 'Special Edition' utgave. Problemet er at selv en PC med AMD FX 57 CPU og 2x Nvidia 7800GTX i SLI, vil ha problemer med å kjøre i stabil framerate med alle disse effektene skrudd på. I Xbox 360 versjonen brukes pixel/vertex shaderne til fulle, HDR lighting samt en en rekke typer mapping (parallax, specular, normal). PC versjonen, kan virke veldig tam i forhold, men ligger egentlig ikke så veldig langt bak dagens titler, som f.eks FEAR, Quake 4 og Call of Duty 2. Alle kan prøve demoen og gjøre seg opp en mening selv. Av det jeg sett av dagens PC spill med tilsvarende effekter, er det kun tech demoen HL2: Lost Coast som er i nærheten av det vi ser på disse bildene. Den demoen bruker HDR og noe av den samme mappingen som vises i de våte steinene på bildene over, men i langt mindre skala. Oblivion på PC vil også være på samme nivå når det gjelder effekter, men spørsmålet er hva slags PC må man ha for å kjøre alt glatt på "fullt". Lenke til kommentar
Daisy Chain Skrevet 2. november 2005 Del Skrevet 2. november 2005 (endret) her er link til video av King Kong og Kameo http://news.spong.com/detail/news.asp?prid...5&cb=0.2207257# edit: shaky-cam med laber kvalitet... Endret 2. november 2005 av Daisy Chain Lenke til kommentar
