Richard87 Skrevet 26. oktober 2005 Del Skrevet 26. oktober 2005 noen som vett hvordan jeg kan lage ett nyt "desktop" og kjore ett nytt programm inni? koden min forelopig er dette: Private Const strDesktop = "Teesting" Private Type SECURITY_ATTRIBUTES nLength As Long lpSecurityDescriptor As Long bInheritHandle As Long End Type Private Type DEVMODE dmDeviceName As String * 32 dmSpecVersion As Integer dmDriverVersion As Integer dmSize As Integer dmDriverExtra As Integer dmFields As Long dmOrientation As Integer dmPaperSize As Integer dmPaperLength As Integer dmPaperWidth As Integer dmScale As Integer dmCopies As Integer dmDefaultSource As Integer dmPrintQuality As Integer dmColor As Integer dmDuplex As Integer dmYResolution As Integer dmTTOption As Integer dmCollate As Integer dmFormName As String * 32 dmUnusedPadding As Integer dmBitsPerPel As Integer dmPelsWidth As Long dmPelsHeight As Long dmDisplayFlags As Long dmDisplayFrequency As Long End Type Private Type PROCESS_INFORMATION hProcess As Long hThread As Long dwProcessId As Long dwThreadId As Long End Type Private Type STARTUPINFOW cbSize As Long lpReserved As Long lpDesktop As Long lpTitle As Long dwX As Long dwY As Long dwXSize As Long dwYSize As Long dwXCountChars As Long dwYCountChars As Long dwFillAttribute As Long dwFlags As Long wShowWindow As Integer cbReserved2 As Integer lpReserved2 As Long hStdInput As Long hStdOutput As Long hStdError As Long End Type Private Declare Function CreateDesktop Lib "user32.dll" Alias "CreateDesktopA" (ByVal lpszDesktop As String, ByVal lpszDevice As String, ByRef pDevmode As DEVMODE, ByVal dwFlags As Long, ByVal dwDesiredAccess As Long, ByRef lpsa As SECURITY_ATTRIBUTES) As Long Private Declare Function CloseDesktop Lib "user32.dll" (ByVal hDesktop As Long) As Long Private Declare Function SwitchDesktop Lib "user32.dll" (ByVal hDesktop As Long) As Long Private Declare Function GetProcessWindowStation Lib "user32.dll" () As Long Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (pDst As Any, pSrc As Any, ByVal ByteLen As Long) Private Declare Function lstrlen Lib "kernel32" Alias "lstrlenA" (ByVal lpString As Long) As Long Private Declare Function EnumDesktops Lib "user32.dll" Alias "EnumDesktopsA" (ByVal hwinsta As Long, ByVal lpEnumFunc As Long, ByVal lParam As Long) As Long Private Declare Function CreateProcess Lib "kernel32" Alias "CreateProcessW" (ByVal lpApplicationName As Long, ByVal lpCommandLine As Long, lpProcessAttributes As Any, lpThreadAttributes As Any, ByVal bInheritHandles As Long, ByVal dwCreationFlags As Long, lpEnvironment As Any, ByVal lpCurrentDirectory As Long, lpStartupInfo As STARTUPINFOW, lpProcessInformation As PROCESS_INFORMATION) As Long Private Declare Function WaitForSingleObject Lib "kernel32.dll" (ByVal hHandle As Long, ByVal dwMilliseconds As Long) As Long Private Declare Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long Private Declare Function GetLastError Lib "kernel32.dll" () As Long Private Const DESKTOP_CREATEMENU As Long = &H4& Private Const DESKTOP_CREATEWINDOW As Long = &H2& Private Const DESKTOP_ENUMERATE As Long = &H40& Private Const DESKTOP_HOOKCONTROL As Long = &H8& Private Const DESKTOP_JOURNALPLAYBACK As Long = &H20& Private Const DESKTOP_JOURNALRECORD As Long = &H10& Private Const DESKTOP_READOBJECTS As Long = &H1& Private Const DESKTOP_SWITCHDESKTOP As Long = &H100& Private Const DESKTOP_WRITEOBJECTS As Long = &H80& Private Const DF_ALLOWOTHERACCOUNTHOOK As Long = &H1& Private Const GENERIC_ALL = &H10000000 Private Const UOI_FLAGS = 1 Private Const UOI_NAME = 2 Private Const UOI_TYPE = 3 Private Const UOI_USER_SID = 4 Private Const INFINITE As Long = &HFFFFFFFF Public Function Kiosk(Exec As String) As Boolean 'Create the desktop Dim hDesktop As Long, lRet As Long, lFlags As Long, lAccess As Long, lErr As Long Dim SA As SECURITY_ATTRIBUTES, DM As DEVMODE, SI As STARTUPINFOW, PI As PROCESS_INFORMATION SetSecurityAttributes SA lFlags = 0 'Do not allow hooks lAccess = SetAccess lRet = CreateDesktop(strDesktop, 0, DM, lFlags, lAccess, SA) If lRet <> 0 Then 'Successfuly created desktop! SwitchDesktop lRet hDesktop = lRet 'Set Startup Information SetStartupInfo SI 'Load the process lRet = CreateProcess(StrPtr(Exec), 0, 0, 0, 2, 0, 0, 0, SI, PI) If lRet <> 0 Then 'Wait for the application to terminate WaitForSingleObject PI.hProcess, INFINITE 'Start cleaning up... CleanUp 'All successfull(belive it or not;) ) Kiosk = True Else lRet = GetLastError Debug.Print lRet, "Error when creating process" Kiosk = False End If Else lRet = GetLastError Debug.Print lRet, "Error when creating desktop" Kiosk = False End If End Function Private Function CleanUp() CloseHandle PI.hProcess CloseHandle PI.hThread CloseDesktop hDesktop End Function Private Function SetSecurityAttributes(SA As SECURITY_ATTRIBUTES) As Boolean With SA .nLength = Len(SA) 'To identify version and control. .lpSecurityDescriptor = 0 'Not used on 9x system, advanced control for NT systems .bInheritHandle = True End With End Function Private Function SetAccess() As Long Dim lAccess As Long lAccess = DESKTOP_CREATEMENU Or DESKTOP_CREATEWINDOW Or DESKTOP_READOBJECTS Or DESKTOP_WRITEOBJECTS Or DESKTOP_SWITCHDESKTOP SetAccess = lAccess End Function Private Function SetStartupInfo(SI As STARTUPINFOW) As Boolean With SI .cbSize = Len(SI) .lpTitle = StrPtr(strDesktop) .lpDesktop = StrPtr(strDesktop) End With End Function Lenke til kommentar
aadnk Skrevet 26. oktober 2005 Del Skrevet 26. oktober 2005 Hva med å endre destinasjonsvinduets parent slik at den befinner seg innenfor et vindu etter ditt valg (det være seg en form eller et vindu du har skapt med CreateWindowEx-APIet). Da skulle du oppnå akkurat det samme. SetParent-APIet er som følger: Declare Function SetParent Lib "user32" Alias "SetParent" (ByVal hWndChild As Long, ByVal hWndNewParent As Long) As Long Lenke til kommentar
Richard87 Skrevet 26. oktober 2005 Forfatter Del Skrevet 26. oktober 2005 (endret) Jeg vet ikke om du skjonner helt va du mener. jeg vil lage ett nytt desktop(du har sikkert lagt merke til "Windows Security" desktopet nar du trykker Ctrl+Alt+Del) Jeg kaller kiosk "explorer.exe" , og sa skal dette programmet kjore opp i ett nytt desktop, dvs desktop "Teeesting". Hoved poenget her er at da blir Ctrl+Alt+Del disablet(Tilogme i NT baserte systemer) og jeg kan enkelt lage et "sikkert" system. Jeg tror problemet ligger i SetStartupInformation, men jeg har INGEN ide... her er en tutorial som handler om CreateDesktop API en... vbAccelerator) Endret 26. oktober 2005 av Richard87 Lenke til kommentar
trrunde Skrevet 27. oktober 2005 Del Skrevet 27. oktober 2005 Hadde ett eksempel på ett slikt program, skal finne det når jeg er ferdig på skolen. Kå slags kiosk program ska du laga nå?? nytt lan?? Lenke til kommentar
aadnk Skrevet 27. oktober 2005 Del Skrevet 27. oktober 2005 Det finnes metoder for å i hvert fall gjøre Task Manager utilgjengelig for brukeren, blant annet med følgende kode (som fungerer i både 9x og NT): Private Declare Function SystemParametersInfo Lib "user32" Alias "SystemParametersInfoA" (ByVal uAction As Long, ByVal uParam As Long, ByVal lpvParam As Any, ByVal fuWinIni As Long) As LongPrivate Declare Function GetVersion Lib "kernel32" () As Long Public Sub DisableTaskManager(Optional bDisabled As Boolean = True) Dim objWSH As Object ' Sjekk hvorvidt vi eksekverer under NT eller ikke If GetVersion() And &HC0000000 Then ' Nei, vi er i 9x - benytt således normalmetoden SystemParametersInfo 97, bDisabled, CStr(1), 0 Else ' I NT derimot, må vi endre en registernøkkel for å få ønskede effekt Set objWSH = CreateObject("WScript.Shell") ' Endre nøkkel objWSH.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\" & _ "System\DisableTaskMgr", IIf(bDisabled, 1, 0), "REG_DWORD" End If End Sub Uansett hva jeg gjør, får jeg likevel ikke programmet til å bli eksekvert. Merkelig nok fungerer ikke CreateProcess i det hele tatt etterpå, dersom jeg kjører en liknenden (fungerende!) kode i annetsteds. Det må sågar en omstart til før det ordner seg. Saktens tror jeg nok det beste ville være å forkaste den gjeldende eksekveringsprosedyren - dsv. alt utenom koden som lager desktopen, og erstatte det med dette eksempelet. Lenke til kommentar
