Kongbalder Skrevet 25. oktober 2005 Del Skrevet 25. oktober 2005 Hei til alle overklokkere. Legger ut CPU-Z rapport. Det jeg lurer på hvorfor pc'n blir ustabil på 3045.3 MHz. Jeg ser også at jeg ikke får stilt ned på Clock multiplier som ligger konstant på x21.0 Noen som vet hvordan jeg kan få stilt denne? CPU-Z Report CPU-Z version 1.30. CPU(s) Number of CPUs 1 Name Intel Pentium 4 Code Name Northwood Specification Intel® Pentium® 4 CPU 2.80GHz Family / Model / Stepping F 2 7 Extended Family / Model 0 0 Brand ID 9 Package mPGA-478 Core Stepping C1 Technology 0.13 µ Supported Instructions Sets MMX, SSE, SSE2 CPU Clock Speed 3045.3 MHz Clock multiplier x 21.0 Front Side Bus Frequency 145.0 MHz Bus Speed 580.1 MHz L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size L1 Trace Cache 12 Kµops, 8-way set associative L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size L2 Speed 3045.3 MHz (Full) L2 Location On Chip L2 Data Prefetch Logic yes L2 Bus Width 256 bits Mainboard and chipset Motherboard manufacturer ASUSTeK Computer INC. Motherboard model P4PE, REV 1.xx BIOS vendor Award Software, Inc. BIOS revision ASUS P4PE ACPI BIOS Revision 1007 BIOS release date 11/10/2003 Chipset Intel i845PE rev. B0 Southbridge Intel 82801DB (ICH4) rev. 02 Sensor chip Asus ASB100 Graphic Interface AGP AGP Status enabled, rev. 2.0 AGP Data Transfer Rate 4x AGP Max Rate 4x AGP Side Band Addressing supported, enabled AGP Aperture Size 64 MBytes Memory DRAM Type DDR-SDRAM DRAM Size 1536 MBytes DRAM Frequency 145.0 MHz FSB:DRAM 1:1 CAS# Latency 2.5 clocks RAS# to CAS# 3 clocks RAS# Precharge 3 clocks Cycle Time (TRAS) 6 clocks DRAM Idle Timer 16 clocks # of memory modules 2 Module 0 Micron Technology DDR-SDRAM PC2100 - 512 MBytes Module 1 Micron Technology DDR-SDRAM PC2100 - 1024 MBytes Software Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600) DirectX version 9.0c Lenke til kommentar
Rikky Skrevet 25. oktober 2005 Del Skrevet 25. oktober 2005 Multiplieren går ikke an å justere. Det er stor sannsynlighet for at det er minnet som holder deg igjen. Det er spesifisert til å klare 133 MHz, så det kan hende 145 MHz blir litt mye. Prøv lavere minnefrekvens. Lenke til kommentar
Kongbalder Skrevet 26. oktober 2005 Forfatter Del Skrevet 26. oktober 2005 Multiplieren går ikke an å justere. Det er stor sannsynlighet for at det er minnet som holder deg igjen. Det er spesifisert til å klare 133 MHz, så det kan hende 145 MHz blir litt mye. Prøv lavere minnefrekvens. 5060241[/snapback] Det betyr vel og det at dette ikke er noe å satse på når det gjelder å overklokke. Har prøvd med lavere minnefrekvens, og da får jeg den stabil på 2900MHz, men det vil jeg på ingen måte kalle overklokking, jeg mener det blir jo å fornærme ordet overklokke, he he. Nei må visst til å oppgrader med litt av hvert, he he Mvh kongbalder Lenke til kommentar
Smirnoff Skrevet 31. oktober 2005 Del Skrevet 31. oktober 2005 (endret) Hvor høyt har du justert spenningen til CPU? Kan være du må leke litt med minnedivideren (husker ikke om P4PE har det da). Endret 31. oktober 2005 av Smirnoff Lenke til kommentar
Sensurert Skrevet 31. oktober 2005 Del Skrevet 31. oktober 2005 var ikke det beste minnet du hadde nei, men har du økt vcore? prøv å øk med 0.5v Lenke til kommentar
