Halo 2 på xbox live, nede i dag fra kl 9=>
Gjest Slettet+19283741
Er det noen som vet hvorfor Halo 2 på xbox LIVE er nede i dag? Jeg vet det er noen oppgraderingen på gang, men er det noen som har noen detaljer om hvilke oppgraderinger det er snakk om?
På forhånd, takk!
På forhånd, takk!
5053224[/snapback]
hele Xbox live og Xbox.com er nede pga. av oppgraderinger til Xbox 360
Alt blir mye mye mer avansert, men ikke kommet så mye info enda
sjekk xbox.com i morgen så får du nok vite alt
Endret av kewell79
Fra Xbox-scene.com
On Monday, October 24, Xbox Live and Xbox.com will be offline for servicing and unavailable for approximately 24 hours.
Simultaneously, the Xbox.com forums will be shut down in preparation for their grand re-opening.
On October 25, when both Xbox Live and the Website are back online, Xbox.com will be sporting a whole new look-redesigned, revamped and ready to kick into high gear with the launch of Xbox 360. Xbox Live, will also be ready to support all the great new Xbox 360 features.
Approximately one week later, the My Xbox portion of Xbox.com, as well as the new forums, will be unveiled. For more details about My Xbox click here.
My Xbox is a seamless integration between Xbox 360, Xbox Live, and Xbox.com. It reflects the friends you add, achievements you earn, and games you play on Xbox.com in real time. You'll be able to compare your achievements with any other Xbox Live member just by logging in to My Xbox on Xbox.com. (Remember, achievements are new and can only be earned by playing Xbox 360 games.)
