Fenalår Skrevet 23. oktober 2005 Del Skrevet 23. oktober 2005 Jeg lastet ned ProFTPD ved hjelp av apt-get install ProFTPD Så lastet jeg ned Webmin ved hjelp av "apt-get" fordi jeg har hørt at det skal være noe enklere da. Men jeg får jo jaggu ikke oppretta en bruker! Jeg prøvde å søke litt rundt etter en guide, men jeg så at filen "proftpd.conf" ble nevnt flere ganger, men spørsmålet mitt blir: Hvordan kan jeg opprette en bruker med passord osv.? Så hvis noen kunne satt opp et eksempel for meg hadde det hvert supert! Filen proftpd.conf ser slik ut hvis det sier dere noe: # # /etc/proftpd.conf -- This is a basic ProFTPD configuration file. # To really apply changes reload proftpd after modifications. # ServerName "debian" ServerType inetd DeferWelcome off MultilineRFC2228 on DefaultServer on ShowSymlinks on TimeoutNoTransfer 600 TimeoutStalled 600 TimeoutIdle 1200 DisplayLogin welcome.msg DisplayFirstChdir .message ListOptions "-l" DenyFilter \*.*/ # Uncomment this if you are using NIS or LDAP to retrieve passwords: #PersistentPasswd off # Uncomment this if you would use TLS module: #TLSEngine on # Uncomment this if you would use quota module: #Quotas on # Uncomment this if you would use ratio module: #Ratios on # Port 21 is the standard FTP port. Port 21 # To prevent DoS attacks, set the maximum number of child processes # to 30. If you need to allow more than 30 concurrent connections # at once, simply increase this value. Note that this ONLY works # in standalone mode, in inetd mode you should use an inetd server # that allows you to limit maximum number of processes per service # (such as xinetd) MaxInstances 30 # Set the user and group that the server normally runs at. User nobody Group nogroup # Umask 022 is a good standard umask to prevent new files and dirs # (second parm) from being group and world writable. Umask 022 022 # Normally, we want files to be overwriteable. AllowOverwrite on # Delay engine reduces impact of the so-called Timing Attack described in # http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02 # It is on by default. #DelayEngine off # A basic anonymous configuration, no upload directories. # <Anonymous ~ftp> # User ftp # Group nogroup # # We want clients to be able to login with "anonymous" as well as "ftp" # UserAlias anonymous ftp # # Cosmetic changes, all files belongs to ftp user # DirFakeUser on ftp # DirFakeGroup on ftp # # RequireValidShell off # # # Limit the maximum number of anonymous logins # MaxClients 10 # # # We want 'welcome.msg' displayed at login, and '.message' displayed # # in each newly chdired directory. # DisplayLogin welcome.msg # DisplayFirstChdir .message # # # Limit WRITE everywhere in the anonymous chroot # <Directory *> # <Limit WRITE> # DenyAll # </Limit> # </Directory> # # # Uncomment this if you're brave. # # <Directory incoming> # # # Umask 022 is a good standard umask to prevent new files and dirs # # # (second parm) from being group and world writable. # # Umask 022 022 # # <Limit READ WRITE> # # DenyAll # # </Limit> # # <Limit STOR> # # AllowAll # # </Limit> # # </Directory> # # </Anonymous> <Global> </Global> Lenke til kommentar
Twofish Skrevet 26. oktober 2005 Del Skrevet 26. oktober 2005 har du prøvd å legge til brukere med useradd? er du sikker på at ftp serveren kjører som den skal og svarer på oppkoblinger? Lenke til kommentar
AudunSæther Skrevet 26. oktober 2005 Del Skrevet 26. oktober 2005 Brukere i ProFTP er de samme brukerene som generelt på boksen. Dermed bruker du "useradd". Du kan vel også definere virtuelle brukere kun for ProFTP, men det kan jeg lite om. Lenke til kommentar
mads Skrevet 24. november 2005 Del Skrevet 24. november 2005 sjekk ut: http://proma.sourceforge.net Lenke til kommentar
