Admin Login Script
Her er et loggin script, men nyhetscript kan du få her:
cutephp.com
admin.php
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
 <title>Administrasjon</title>
 <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
 <link rel="stylesheet" type="text/css" href="style.css">
</head>
<body>
<h1>Administrasjon</h1>
<?php
/* LOGINFORM */
if ($_SESSION['auth']) echo "<p>Du er for øyeblikket logget inn. Vil du <a href=\"index.php?page=logout\">logge ut</a>?</p>";
else {
echo <<< end
 <form action="index.php?page=login" method="post">
 <table cellspacing="0" cellpadding="0" border="0">
   <tr><td>Brukernavn:   </td><td><input name="user" type="text" size="$InputSize"></td></tr>
   <tr><td>Passord:   </td><td><input name="pass" type="password" size="$InputSize"></td></tr>
   <tr><td></td><td><input type="submit" value="Login"></td></tr>
 </table>
 </form>
 <p>Du må logge inn!</p>
end;
</body>
</html>
login.php
<?php
/* KONFIGURASJON */
$URLToAdminPage  = "admin.php";
$Username  	= "admin";
$EncryptedPassword	= "1a1dc91c907325c69271ddf0c944bc72";
/* SCRIPTET STARTER HER *****************************************************/
$user = $_POST['user'];
$pass = $_POST['pass'];
if ($user == $Username && md5($pass) == $EncryptedPassword) {
$_SESSION['auth'] = true;
header("Location: $URLToAdminPage");
else header("Location: $URLToAdminPage&msg=error");
logout.php
<?php
/* KONFIGURASJON */
session_start();
session_destroy();
$_SESSION = array();
if (ereg("^[^?]+$", $URLToAdminPage)) $URLToAdminPage = $URLToAdminPage . "?";
header("Location: $URLToAdminPage&msg=loggedout");
brukernavn og passord er satt til:
brukernavn: admin
passord: admin
Endret av stianiquniez
