4pin Molex adapted to 3pin?
slyenn
Hi
I have an Antec p180. The 3 120mm fans is getting their power from 4pin Molex connecters directly from the PSU.
I also have a Fan controller, with room for 4 fans.
The problem is the Fan controller can only connect fans using 3pin connecters.
Is there a cable or other solution to make these 3 fans's fit onto the Fan controller.
4 pin Molex to 3pin (fan connecter). :?:
Thanks :ermm:
