Str1fe Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Jeg har installert wine i følge denne guiden: http://www.winehq.org/site/download-deb så skriver jeg "wine" i terminal og får opp: wine: creating configuration directory '/home/paal/.wine'... err:module:load_builtin_dll failed to load .so lib for builtin L"gdi32.dll": libstdc++.so.5: cannot open shared object file: No such file or directory err:module:import_dll Loading library gdi32.dll (which is needed by L"c:\\windows\\system\\user32.dll") failed (error c000007a). err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\rundll32.exe") not found err:module:LdrInitializeThunk Main exe initialization for L"C:\\windows\\rundll32.exe" failed, status c0000135 wine: wineprefixcreate failed while creating '/home/paal/.wine'. Hva har jeg gjort galt ? Jeg bruker linux Ubuntu hvis noen lurer Lenke til kommentar
objorkum Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 (endret) Jeg har installert wine i følge denne guiden:http://www.winehq.org/site/download-deb så skriver jeg "wine" i terminal og får opp: wine: creating configuration directory '/home/paal/.wine'... err:module:load_builtin_dll failed to load .so lib for builtin L"gdi32.dll": libstdc++.so.5: cannot open shared object file: No such file or directory err:module:import_dll Loading library gdi32.dll (which is needed by L"c:\\windows\\system\\user32.dll") failed (error c000007a). err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\rundll32.exe") not found err:module:LdrInitializeThunk Main exe initialization for L"C:\\windows\\rundll32.exe" failed, status c0000135 wine: wineprefixcreate failed while creating '/home/paal/.wine'. Hva har jeg gjort galt ? Jeg bruker linux Ubuntu hvis noen lurer 5019013[/snapback] Kvifor ikkje legge inn den Wine-pakken som ligg i Universe? Først må du lagt til alle repositories, om du ikkje har det. Her er min /etc/apt/source.list for Ubuntu Breezy 32-bit: http://www.objorkum.com/files/sources.txt Rediger din med "sudo gedit /etc/apt/sources.list" Køyr "sudo apt-get update" etterpå i ein terminal. Opne opp Synaptic og søk etter "wine". Fjern pakken du har lagt inn. Legg inn den andre "wine"-pakken. Endret 17. oktober 2005 av objorkum Lenke til kommentar
meastp Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Kan kanskje slenge inn problemet mitt her også, da? meastp@ubuntu:~$ wine /media/cdrom0/SETUP/SETUP.exe Warning: the specified Windows directory L"c:\\windows" is not accessible. Warning: the specified System directory L"c:\\windows\\system" is not accessible. Warning: could not find DOS drive for current working directory '/home/meastp', starting in the Windows directory. wine: cannot find '/media/cdrom0/SETUP/SETUP.exe' meastp@ubuntu:~$ (Breezy, dette også. Først installerte jeg winesetuptk og kjørte det. Så installerte jeg wine og winelib, og da forsvant winesetuptk. Men problemet er altså at jeg ikke får kjørt noe.) Lenke til kommentar
objorkum Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 cannot find '/media/cdrom0/SETUP/SETUP.exe' Finst den? Lenke til kommentar
objorkum Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Einaste eg gjorde: - La inn pakken "wine" Så køyrde eg: wine /mnt/windows/WINDOWS/system32/notepad.exe Voila! Notisblokk kom opp. Lenke til kommentar
meastp Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Joda, den finnes. Uansett skulle jo ikke de andre feilmeldingene kommet opp? Jeg har dessverre ingen windows-install å teste på. Forslag til hva jeg kan forsøke med? Lenke til kommentar
objorkum Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Får du feilmeldingane om du berre køyrer "wine"? Lenke til kommentar
meastp Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 (endret) Får du feilmeldingane om du berre køyrer "wine"? 5019200[/snapback] meastp@ubuntu:~$ wine Warning: the specified Windows directory L"c:\\windows" is not accessible. Warning: the specified System directory L"c:\\windows\\system" is not accessible. Warning: could not find DOS drive for current working directory '/home/meastp', starting in the Windows directory. Wine 20050725 Usage: wine PROGRAM [ARGUMENTS...] Run the specified program wine --help Display this help and exit wine --version Output version information and exit meastp@ubuntu:~$ Jepp. Og jeg er ikke den eneste. Endret 17. oktober 2005 av meastp Lenke til kommentar
objorkum Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Får du feilmeldingane om du berre køyrer "wine"? 5019200[/snapback] meastp@ubuntu:~$ wine Warning: the specified Windows directory L"c:\\windows" is not accessible. Warning: the specified System directory L"c:\\windows\\system" is not accessible. Warning: could not find DOS drive for current working directory '/home/meastp', starting in the Windows directory. Wine 20050725 Usage: wine PROGRAM [ARGUMENTS...] Run the specified program wine --help Display this help and exit wine --version Output version information and exit meastp@ubuntu:~$ Jepp. Og jeg er ikke den eneste. 5019243[/snapback] Om du slettar ~/.wine ? Lenke til kommentar
meastp Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Joa, det funker bedre nå. Får en melding, når jeg kjører ra2-setupen, at "Could not initialize directx". Hvordan fikser jeg det? Lenke til kommentar
objorkum Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Joa, det funker bedre nå. Får en melding, når jeg kjører ra2-setupen, at "Could not initialize directx". Hvordan fikser jeg det? 5019516[/snapback] Bruker RA2 DirectX? Wine er vel heller dårleg på DirectX-støtte? Eg er ikkje sikker... Cedega er mykje betre til det, i alle fall. Lenke til kommentar
meastp Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Du mener at det er umulig? Minimum DirectX-versjon er 7.0. Jeg har alt prøvd Cedega, men der er det ikke støtte for ipx, og da er det ikke noe poeng. Nederlag å ha windows bare fordi jeg spiller det på LAN noen få ganger i året, da... Lenke til kommentar
meastp Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Kanskje versjonen min er litt gammel? Så at pakkene på winehq bare er for warty og hoary? Jeg har nå Wine 20050725 Lenke til kommentar
objorkum Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Det garantert minimal forskjell på pakken du har, og den nyaste hos WineHQ. Lenke til kommentar
meastp Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 Det jeg kan forsøke, er jo å installere det på en annen PC med xp, og så kopiere mappa over. Men jeg lurer på om directx-initialize-meldingen kommer da også? Meldingen, som jeg har skjønt den, betyr jo at directx-støtten ikke finnes/kan legges til i systemet. Det er jo flere som har fått RA2 til å funke. Jeg vil så gjerne få det til å funke. Da kanskje jeg kan forsøke med flere (eldre) C&C-spill også. Lenke til kommentar
Str1fe Skrevet 18. oktober 2005 Forfatter Del Skrevet 18. oktober 2005 Jeg har installert wine i følge denne guiden:http://www.winehq.org/site/download-deb så skriver jeg "wine" i terminal og får opp: wine: creating configuration directory '/home/paal/.wine'... err:module:load_builtin_dll failed to load .so lib for builtin L"gdi32.dll": libstdc++.so.5: cannot open shared object file: No such file or directory err:module:import_dll Loading library gdi32.dll (which is needed by L"c:\\windows\\system\\user32.dll") failed (error c000007a). err:module:import_dll Library user32.dll (which is needed by L"C:\\windows\\rundll32.exe") not found err:module:LdrInitializeThunk Main exe initialization for L"C:\\windows\\rundll32.exe" failed, status c0000135 wine: wineprefixcreate failed while creating '/home/paal/.wine'. Hva har jeg gjort galt ? Jeg bruker linux Ubuntu hvis noen lurer 5019013[/snapback] Kvifor ikkje legge inn den Wine-pakken som ligg i Universe? Først må du lagt til alle repositories, om du ikkje har det. Her er min /etc/apt/source.list for Ubuntu Breezy 32-bit: http://www.objorkum.com/files/sources.txt Rediger din med "sudo gedit /etc/apt/sources.list" Køyr "sudo apt-get update" etterpå i ein terminal. Opne opp Synaptic og søk etter "wine". Fjern pakken du har lagt inn. Legg inn den andre "wine"-pakken. 5019093[/snapback] Jeg gjorde som du sa og det virket Lenke til kommentar
meastp Skrevet 18. oktober 2005 Del Skrevet 18. oktober 2005 Nå har jeg kopiert over en mappe med installert RA2 v1.006 + NO-CD-Patch. Jeg kjørte det, og selv om det skjedde en del i terminalen, så kjørte spillet. Jeg fikk ikke lyd. Forsøkte single player. Her gikk det først temmelig halv-sakte - om du drar gamespeed på laveste blir det vel noe av det samme. Så forsøkte jeg å scrolle, og da krasjet spillet. Legger ved terminal-debug-tekst. Hva gjør jeg nå? debug.wine.txt Lenke til kommentar
meastp Skrevet 19. oktober 2005 Del Skrevet 19. oktober 2005 Ok, making progress... debugger med en på #winehq. Låner litt plass for debugfiler. 10129output.txt 10133output.txt Lenke til kommentar
dayslepr Skrevet 19. oktober 2005 Del Skrevet 19. oktober 2005 skumleste igjennom tråden her, tenkte bare å nevne at jeg må gjøre slik: wine WoW.exe -opengl ..for å "fortelle" spillene at de skal bruke OpenGL (som er mye bedre støttet) i stedet for DirectX .. men det kan jo være at RA er avhengig av DirectX-driten ...... Lenke til kommentar
meastp Skrevet 20. oktober 2005 Del Skrevet 20. oktober 2005 Det tror jeg, den bruker DX7. Jeg har nå klart å kjøre RA2, samt kommet inn på "network" fordi jeg satt opp IPX på eth0. Jeg skal teste litt mer, og hvis det funker bra, så kan jeg legge en post i tråden som heter noe sånt som ra i wine, eller lage en ny tråd med guide. Lenke til kommentar
