stian90_2 Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 (endret) Fatal error: Call to undefined function: readelements() in /web/www/frac/users/iquniez/poll/vote.php on line 15 Der er erroren. Noen som kan hjelpe meg ? (A) Scriptet er slik: <?php require 'settings.php'; require 'pollcode.php'; // Save ip-number to log so user cant vote again $filename = $DATAPATH . "iplog.txt"; $fp = fopen($filename, "a"); $linetoadd = $_SERVER["REMOTE_ADDR"].':'; fputs($fp, $linetoadd); fclose($fp); // Read current poll data $arrPoll = ReadElements(); $question = $arrPoll[2]; $arrAlts = $arrPoll[0]; $arrVotes = $arrPoll[1]; // Add vote $vote = $_GET["alt"]; $arrVotes[$vote] += 1; $filename = $DATAPATH . "poll.txt"; $fp = fopen($filename, "w"); $linetoadd = stripslashes($question.":"); fputs($fp, $linetoadd); for($i=0; $i < count($arrAlts); $i++) { $linetoadd = stripslashes($arrAlts[$i]).":".$arrVotes[$i].":"; fputs($fp, $linetoadd);; } fclose($fp); $ref = $_SERVER["HTTP_REFERER"]; header("Location: $ref"); ?> Endret 17. oktober 2005 av stianiquniez Lenke til kommentar
Knebba Skrevet 17. oktober 2005 Del Skrevet 17. oktober 2005 tror nok du må poste pollcode.php eller settings.php også Lenke til kommentar
stian90_2 Skrevet 17. oktober 2005 Forfatter Del Skrevet 17. oktober 2005 (endret) settings.php <?php /* TxtPoll Settings Version: 1.1 Author: Peter Tornstrand <[email protected]> Date: 2005-09-26 Note: Feel free to use this script however you like. If you like it or have made improvements to it please don't hesitate to drop me a line. */ // Password for the administration interface $PASSWORD = '******'; // Path to the directory containing the data files $DATAPATH = '/web/www/frac/users/iquniez/poll/'; // Domain (without www) $DOMAIN = 'iquniez.frac.dk'; ?> pollcode.php <?php /* TxtPoll Vote code Version: 1.1 Author: Peter Tornstrand <[email protected]> Date: 2005-09-26 Note: Feel free to use this script however you like. If you like it or have made improvements to it please don't hesitate to drop me a line. */ require 'settings.php'; function ReadPollData() { $filename = $DATAPATH . 'poll.txt'; $fp = fopen($filename, "r"); $fc = fread($fp,filesize($filename)-1); fclose($fp); $elements = explode(":", $fc); $h = (count($elements)-1) / 2; $question = stripslashes($elements[0]); $i = 0; while ($h > $i) { $item[$i] = $elements[(2*$i+1)]; $votes[$i] = $elements[(2*$i+2)]; $i++; } return array ($item, $votes, $question); } function ReadLogFile() { $filename = $DATAPATH . 'iplog.txt'; $fp = fopen($filename, "r"); $fc = fread($fp,filesize($filename)); fclose($fp); $elements = explode(":", $fc); return $elements; } ?> Endret 17. oktober 2005 av stianiquniez Lenke til kommentar
Christian_ Skrevet 18. oktober 2005 Del Skrevet 18. oktober 2005 Jeg kan ikke se at du har laget funksjonen readelements() i noen av filene. Så du prøver å kjøre en funsksjon som ikke finnes Lenke til kommentar
stian90_2 Skrevet 18. oktober 2005 Forfatter Del Skrevet 18. oktober 2005 Vet du hvordan den funksjonen skal se ut ? Lenke til kommentar
Axentrix Skrevet 18. oktober 2005 Del Skrevet 18. oktober 2005 ReadPollData er vel funksjonen han egentlig mener å bruke (denne var iallefall i den ene fila). Foresten, et tips: For å slippe å skrive administratorpassordet åpent, så skriver du md5 summen av det og der du sjekker passorder, bruker du "if($PASSWORD == md5($_POST["passord"])) i stedet Lenke til kommentar
stian90_2 Skrevet 18. oktober 2005 Forfatter Del Skrevet 18. oktober 2005 (endret) Takk for tipset.. Fikk det til og fungere når jeg er i admin. men når jeg går til: http://iquniez.frac.dk/index.php?page=poll Så er bare siden blank :S Har includa den med denne scriptet. <?php include 'poll/poll.php' ?> Endret 18. oktober 2005 av stianiquniez Lenke til kommentar
kakkle Skrevet 21. oktober 2005 Del Skrevet 21. oktober 2005 Kan du poste koden poll.php ? Litt vanskelig å se hva du har gjort. er dette noe du har laget selv ? Vil anbefale at du setter deg skikkelig inn i php, og lager et egtet, slik at du har god kontroll over scriptet. Lenke til kommentar
stian90_2 Skrevet 21. oktober 2005 Forfatter Del Skrevet 21. oktober 2005 Har ikke skrevet selv. poll.php ser slik ut: <?php include 'settings.php'; include 'pollcode.php'; $arrPoll = ReadPollData(); // Count total votes $total_votes = 0; for ($i=0; $i < count($arrPoll[1]); $i++) { $total_votes += $arrPoll[1][$i]; } ?> <p class="question"><?php echo $arrPoll[2] ?></p> <ul class="txtPoll"> <?php $arrIps = ReadLogFile(); if (in_array($_SERVER["REMOTE_ADDR"], $arrIps)) { for ($i=0; $i < count($arrPoll[0]); $i++) { if ($total_votes>0) { echo '<li>'.$arrPoll[0][$i].'<div class="graph" style="width:'.round(($arrPoll[1][$i]/$total_votes*100),0).'px;"><!-- --></div><div class="percent">'.round(($arrPoll[1][$i]/$total_votes*100),0).'%</div></li>'."\n"; } else { echo '<li>'.$arrPoll[0][$i].'<div class="graph" style="width:1px;"><!-- --></div><div class="percent">0%</div></li>'."\n"; } } } else { for ($i=0; $i < count($arrPoll[0]); $i++) { if ($total_votes>0) { echo '<li><a href="/poll/vote.php?alt='.$i.'">'.$arrPoll[0][$i].'</a><div class="graph" style="width:'.round(($arrPoll[1][$i]/$total_votes*100),0).'px;"><!-- --></div><div class="percent">'.round(($arrPoll[1][$i]/$total_votes*100),0).'%</div></li>'."\n"; } else { echo '<li><a href="/poll/vote.php?alt='.$i.'">'.$arrPoll[0][$i].'</a><div class="graph" style="width:1px;"><!-- --></div><div class="percent">0%</div></li>'."\n"; } } } ?> </ul> <p class="totalvotes">Totalt votes: <?php echo $total_votes ?></p> Lenke til kommentar
