Cursio Skrevet 15. oktober 2005 Del Skrevet 15. oktober 2005 http://www.p-mate.com/eng/intro.html Les og le! Det gjorde jeg! :!: "she-pee"?! hahaha Once you have used it, you can't do without it.The P-Mate gives you more freedom, safety and hygiene. It is developed in connection with the experiences of thousands of women who have tested the P-Mate at grand events, both nationally and internationally. No toilets available when in desperate need of one? Dirty toilets? Always standing in the wrong line? THE P-MATE OFFERS THE SOLUTION! P-MATE.... YOUR LITTLE TRAVEL-DATE! Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/
goliatmo Skrevet 15. oktober 2005 Del Skrevet 15. oktober 2005 Da var vi et skritt nærmere total likestilling Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5012130
SimDaDim Skrevet 15. oktober 2005 Del Skrevet 15. oktober 2005 Lol, "The She Pee" Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5012132
Snublefot Skrevet 15. oktober 2005 Del Skrevet 15. oktober 2005 Hvorfor i alleverden skulle vi ha lyst til det ? :/ Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5012156
Cursio Skrevet 15. oktober 2005 Forfatter Del Skrevet 15. oktober 2005 Hvorfor i alleverden skulle vi ha lyst til det ? :/ 5012156[/snapback] Derfor! Every woman, young or old, will recognize one or more of the following situations in which she has to pee urgently: 1. There's no toilet available. 2. There is a toilet, but it is so dirty that you'd rather prefer to hold your piddle. 3. There is no bush or secluded spot where you can bare your bottom quietly 4. Or you are standing in front of an impenetrable brushwood. 5. What is creeping through that penetrable brushwood? 6. The stinging nettles stand very high today! 7. The toilet consists of two footings and a hole. You spatter your shoes or it leaks against your legs. 8. You are pregnant, you have to pee often but it is difficult to get up. 9. You are not pregnant, but, for any reason, it is hard for you to squat. 10. You are in an exotic place with only... an open sewerage. 11. You are waiting in the end of a line at an outside-event, will you make it? 12. You have made it, like the hundreds of women before you, you open the door but... do you still want to? 13. You have to hand in a piddle for a research and your pee is flowing everywhere, except into the pot. 14. For your profession you wear clothes that you can't take off very easily, even if there is a suitable pee-spot around. 15. You are on a boat with a toilet that's too small, or there's no toilet. To every problem, the p-mate is the solution! *ler meg ihjel* Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5012214
Snublefot Skrevet 15. oktober 2005 Del Skrevet 15. oktober 2005 Hehehe..... du sier noe der Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5012232
InsertNumLock Skrevet 15. oktober 2005 Del Skrevet 15. oktober 2005 Hadde jeg sett ei dame som sto å pissa med en slik, hadde jeg løpt alt jeg hadde. Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5012268
Peter Skrevet 15. oktober 2005 Del Skrevet 15. oktober 2005 Frykter at jeg hadde blitt stående og stirre... Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5012300
lceman™ Skrevet 16. oktober 2005 Del Skrevet 16. oktober 2005 Denne fikk meg til å tenke på en av åpningsscenen i " The Full Monty" Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5012687
The Norwegian Skrevet 16. oktober 2005 Del Skrevet 16. oktober 2005 Utrolig nødvendig du... Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5013158
Πεισιθάνατος Skrevet 16. oktober 2005 Del Skrevet 16. oktober 2005 Acolyt3, jeg synes du har utelatt en del viktige elementer i stedsbeskrivelsen din. Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5013311
Complexity Skrevet 16. oktober 2005 Del Skrevet 16. oktober 2005 haha.. mojjo hadde blidt litt skremt om jeg så en dame som sto og tisset ja Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5013448
The Norwegian Skrevet 16. oktober 2005 Del Skrevet 16. oktober 2005 Acolyt3, jeg synes du har utelatt en del viktige elementer i stedsbeskrivelsen din. 5013311[/snapback] hva da? Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5013775
Venerable Skrevet 16. oktober 2005 Del Skrevet 16. oktober 2005 Acolyt3, jeg synes du har utelatt en del viktige elementer i stedsbeskrivelsen din. 5013311[/snapback] hva da? 5013775[/snapback] Hørt om sarkasme? On topic: Tenk hvis slike apperater kommer seg inn på utesteder, og dritas kvinnfolk skal prøve å pisse inne. Vi gutter har mange år med trening, men jeg har fremdeles aldri hatt et vorspiel uten å finne masse piss utenfor toalettskåla dagen etter. For ikke å snakke om at de sikkert vil miste dingsen et par ganger. Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5014108
bortevekk Skrevet 16. oktober 2005 Del Skrevet 16. oktober 2005 ^^var akkurat det jeg tenkte på da leste det som var skrevet der. Syns jeg ser for meg selv ganske beruset skal prøve å håndtere en sånn en, nei da løfter jeg heller på skjørtet! Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5014416
Cursio Skrevet 16. oktober 2005 Forfatter Del Skrevet 16. oktober 2005 ^^var akkurat det jeg tenkte på da leste det som var skrevet der. Syns jeg ser for meg selv ganske beruset skal prøve å håndtere en sånn en, nei da løfter jeg heller på skjørtet! 5014416[/snapback] Haha joda sant nok! :!: Lenke til kommentar https://www.diskusjon.no/topic/483880-n%C3%A5-kan-kvinner-urinere-st%C3%A5ende/#findComment-5015154
