Test av komposite effekt
Kræsjer her óg.
Connecting to server www.student.uit.no[129.242.80.34]:80 ...
VIDEO:  [DX50]  640x480  24bpp  25.000 fps  2355.1 kbps (287.5 kbyte/s)
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 48000 Hz, 2 ch, 16 bit (0x10), ratio: 192000->192000 (1536.0 kbit)
Selected audio codec: [pcm] afm:pcm (Uncompressed PCM)
vo: X11 running at 1280x1024 with depth 24 and 32 bpp (":0.0" => local display)
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm:ffmpeg (FFmpeg MPEG-4)
Checking audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
AF_pre: af format: 2 bps, 2 ch, 48000 hz, little endian signed int
AF_pre: 48000Hz 2ch Signed 16-bit (Little-Endian)
AO: [oss] 48000Hz 2ch Signed 16-bit (Little-Endian) (2 bps)
Building audio filter chain for 48000Hz/2ch/16bit -> 48000Hz/2ch/16bit...
Starting playback...
VDec: vo config request - 640 x 480 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
VO: [xv] 640x480 => 640x480 Planar YV12
[mpeg4 @ 0x848e868]frame skip 8t:  0.000    1/  1   0%  0%  0.0% 0 0 1%
A:   2.9 V:   2.9 A-V: -0.000 ct: -0.003   73/ 73   4%  3%  8.1% 0 0 41%
MPlayer interrupted by signal 2 in module: decode_audio
Broken pipe
