En revolusjon innen hardware!
Man-made diamonds sparkle with potential
By Kevin Maney, USA TODAY
BOSTON — In the back room of an unmarked brown building in a run-down strip mall, eight machines, each the size of a bass drum, are making diamonds.
IPB Image Apollo Diamond "seeds" grow into pure diamonds perfect for lasers and computer chips, as well as jewelry.
By Geoff Forester for USA TODAY
That's right — making diamonds. Real ones, all but indistinguishable from the stones formed by a billion or so years' worth of intense pressure, later to be sold at Tiffany's.
The company doing this is Apollo Diamond, a tiny outfit started by a former Bell Labs scientist. Peer inside Apollo's stainless steel-and-glass machines, and you can see single-crystal diamonds literally growing amid hot pink gases.
This year, Apollo expects to grow diamonds as big as 2 carats. By the end of 2005, it might expand to 10 carats. The diamonds will probably start moving into the jewelry market as early as next year — at perhaps one-third the price of a mined diamond.
The whole concept turns the fundamental idea of a diamond on its head. The ability to manufacture diamonds could change business, products and daily life as much as the arrival of the steel age in the 1850s or the invention of the transistor in the 1940s
In technology, the diamond is a dream material. It can make computers run at speeds that would melt the innards of today's computers. Manufactured diamonds could help make lasers of extreme power. The material could allow a cellphone to fit into a watch and iPods to store 10,000 movies, not just 10,000 songs. Diamonds could mean frictionless medical replacement joints. Or coatings — perhaps for cars — that never scratch or wear out.
Scientists have known about the possibilities for years. But they've been held back because mined diamonds are too expensive and too rare. And they're hard to form into wafers and shapes that would be most useful in products.
Manufacturing changes that. It's like the difference between having to wait for lightning to start a fire vs. knowing how to start it by hand.
"I'm just so completely awed by this technology," says Sonia Arrisonof tech analysis group Pacific Research Institute. "Basically, anything that relies on computing power will accelerate."
Arno Penzias, a venture capitalist and Nobel Prize winner for physics, says, "This diamond-fabrication story marks a high-profile milestone on an amazing scientific journey."
"We can't begin to see all the things that can happen because single diamond crystals can be made," says Apollo co-founder Robert Linares, elegant and slim in a golf shirt, slacks and loafers as he sits at the two plastic folding tables that make up Apollo's low-budget conference room. "We are only at the beginning."
Linares has worked on the technology for 15 years, much of that time in his garage. From the start, he did this because of the promise of diamonds in technology. Linares wasn't trying to make gems. In fact, he didn't think he could.
Then he had a happy accident. Well, actually, time will tell whether the accident was a happy one...
Full artikkel: http://www.usatoday.com/tech/news/techinno...-diamonds_x.htm
tja..og siden lys kan brytes i prismer kan i teorien en diamant slipes i fasetter og dermed implementert i en prosessor utgjøre rimelig kjappe operasjoner kombinert med fiberteknologi. Tenk deg en diamantprosessor med glassfiber buss og ram..og hdd's med laser/dvd teknologi, ai ai ai...
"Thermal management is a major challenge to increasing a laser's power," explains Textron scientist Yulin Wang. The diamond has the highest thermal conductivity of any material, which allows it to quickly move heat away from the laser's insides. Textron needs large, pure diamond pieces for its lasers and finally found them at Apollo
CVD diamonds can help solve one of the computer industry's biggest challenges. Companies such as Intel advance computer chip technology by squeezing microscopic wires closer together while making the chips run ever faster. But that's making the chips increasingly hotter. At some point this decade, the chips could run so hot they'd melt. But not if the chips were based on diamond wafers instead of silicon.
It's the hardest material, it won't expand in heat, won't wear, is chemically inert and optically transparent
Manufactured diamonds will be like other inventions that were so profound because they made new things possible. Steel allowed engineers to dream of skyscrapers and suspension bridges. Transistors led to computers and pacemakers and so much else. So this may be the beginning of the diamond age of technology
Så mulighetene er der, men om det er innen rekkevidde med dagens teknologi er annen sak.
Endret av CrazyD
Ingen som har nevnt at kiloprisen på diamant er rimlig høy da..?
Det er mulig å lage kunstige diamanter, altså slik at de gjør samme nytte, men en ekte kjenner kan se at de er kunstige.
Det sa ihvertfall læreren min en gang jeg spurte han om det.
Ikke det at det blir kjempebillig alikevel, men billigere blir det jo.
umm det er jo hele poenget...
har du lest artikkelen eller er du bare en av de som skriver før du tenker?
Greia er jo at hvis du kan lage fullverdige diamanter i en lab så blir jo prisen på industridiamant latterlig lav...
vi snakker ikke om gifteringer her, men diamanter som kan lages og brukes i stor skala... idag finnes det f.eks. sagblad med industridiamant på skjæret men prisen er for høy til at det blir utnyttet skikkelig.
Endret av CrazyD
En av de ja :thumbup:
Men samme hvordan en vrir og vender på det så er ekte diamanter (slik som blir til av kull som ligger i press i tusner av år) :p...
ja..les redigert innlegg..(du var for kjapp ;) )
Til å være diamanter eller i det hele tatt?
ummm?
ummm?
Blir det billig med tanke på at det er diamant, eller like billig som... Melk?
Altså, hvor billig?
Hvordan skal jeg kunne vite det?
Blir som å spørre om LCD blir like billig som... Melk?
DVD prisene har rast det siste året og nå er vel en DVD plate på samme prisene som melk...DVD brenner hastigheter har gått opp mens priser går ned enda...RAM prisen har gått ned..LCD priser har droppet enormt siste året, og sammenlignet med ...Melk? kan man vel si at LCD har blitt betraklig billigere en Melk? har blitt.
Så hvordan det vil affektere deg som endebruker er ikke lett for meg å svare på, men det er lov å tenke selv.
Litt av begrensningene med å begynne å bruke laserlys i datamaskiner er at lys er begrenset av visse bølgelengder og tar egentlig forholdsvis stor plass. Raskt og lite varmeutviklende, men plasskrevende. Synlig lys har bølgelengde fra 397nm-723nm, og da sier det seg selv at dette blir stort.
ummm?
Altså, hvor billig?
Hvis flere og flere diamanter blir "produsert" så synker jo prisen. :hmm:
Endret av Pels
De blir nok ikke billige, kilosprisen er nok høy, men, kilosprisen på gull er også meget høy, blir brukt en del gull i datakomponenter selv om det er dyrt pr. kilo, hva har det å si at det er dyrt for ett kilo, når det i dataverdenen er snakk om at du trenger 0.001 gram pr. enhet du skal produsere ?
Poenget er vel ikke at det blir så vanvittig billig, men at det kan produseres i store kvanta. Relativt billig (selv om det kanskje går bare en liten del pr. enhet som skal skal lages, så blir det ganske mye når man skal lage kanskje en million enheter, bare for å ta ett tall ut fra løse lufta... :thumbup: )
