Er dette ok ping?
Er dette ok ping-tider?
Ping har startet ...
PING www.vg.no (193.69.165.21): 56 data bytes
64 bytes from 193.69.165.21: icmp_seq=0 ttl=248 time=23.247 ms
64 bytes from 193.69.165.21: icmp_seq=1 ttl=248 time=22.840 ms
64 bytes from 193.69.165.21: icmp_seq=2 ttl=248 time=23.117 ms
64 bytes from 193.69.165.21: icmp_seq=3 ttl=248 time=22.705 ms
64 bytes from 193.69.165.21: icmp_seq=4 ttl=248 time=22.399 ms
64 bytes from 193.69.165.21: icmp_seq=5 ttl=248 time=21.291 ms
64 bytes from 193.69.165.21: icmp_seq=6 ttl=248 time=21.168 ms
64 bytes from 193.69.165.21: icmp_seq=7 ttl=248 time=21.136 ms
64 bytes from 193.69.165.21: icmp_seq=8 ttl=248 time=20.759 ms
64 bytes from 193.69.165.21: icmp_seq=9 ttl=248 time=20.324 ms
64 bytes from 193.69.165.21: icmp_seq=10 ttl=248 time=20.619 ms
64 bytes from 193.69.165.21: icmp_seq=11 ttl=248 time=19.545 ms
--- www.vg.no ping statistics ---
12 packets transmitted, 12 packets received, 0% packet loss
round-trip min/avg/max/stddev = 19.545/21.596/23.247/1.170 ms
Har 512 SHDSL fra Direct Connect.
EDIT: Bor i Sør-Trøndelag
:hmm:
Endret av steveak
Tja, selv har jeg dette:
Pinging vg.no [193.69.165.21] with 32 bytes of data:
Reply from 193.69.165.21: bytes=32 time=11ms TTL=246
Reply from 193.69.165.21: bytes=32 time=10ms TTL=246
Ping statistics for 193.69.165.21:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 10ms, Maximum = 11ms, Average = 10ms
Lyse Fiber :)
Vel. Har Lyse fiber her også:
Pinger vg.no [193.69.165.21] med 32 byte data:
Svar fra 193.69.165.21: byte=32 tid=51ms TTL=244
Svar fra 193.69.165.21: byte=32 tid=49ms TTL=244
Svar fra 193.69.165.21: byte=32 tid=50ms TTL=244
Ping-statistikker for 193.69.165.21:
Pakker: sendt = 4, mottatt = 4, tapt = 0 (0% tap),
Gjennomsnittlig tid for tur-retur i millisekunder:
minimum = 49ms, maksimum = 51ms, gjennomsnittlig = 50ms
Har UPC Chello
Svar fra 193.69.165.21: byte=32 tid=11ms TTL=249
Svar fra 193.69.165.21: byte=32 tid=8ms TTL=249
Svar fra 193.69.165.21: byte=32 tid=15ms TTL=249
Svar fra 193.69.165.21: byte=32 tid=13ms TTL=249
minimum = 8ms, maksimum = 15ms, gjennomsnittlig = 11ms
:hmm:
husk at du pinger med flere byte enn de andre da ;)
Også kommer det an på hvor stor trafikk det er på vg's hjemmeside. + at arbeid i felte kan føre til litt lengre tid :p
Ellers er den grei ;)
Måtte jo teste dette jegå.
Har Catch sdsl 2048/2048
ping www.vg.no
Pinging www.vg.no [193.69.165.21] with 32 bytes of data:
Reply from 193.69.165.21: bytes=32 time=8ms TTL=247
Reply from 193.69.165.21: bytes=32 time=7ms TTL=247
Reply from 193.69.165.21: bytes=32 time=9ms TTL=247
Minimum = 7ms, Maximum = 9ms, Average = 7ms
Me:
Reply from 193.69.165.21: bytes=32 time=2ms TTL=249
Reply from 193.69.165.21: bytes=32 time=3ms TTL=249
Minimum = 2ms, Maximum = 3ms, Average = 2ms
Merk at dette er med trådløst innomhus..
Da trådstarter pinger med 64bytes burde jo andre gjøre det også.
Har NGT
Første forsøket fikk jeg average på 132ms...
Trådløst #¤%#"#¤
Men de 3 andre gangene fikk jeg nogenlunde likt
ping -n 10 -l 64 www.vg.no
Pinging www.vg.no [193.69.165.21] with 64 bytes of data:
Reply from 193.69.165.21: bytes=64 time=16ms TTL=247
Reply from 193.69.165.21: bytes=64 time=15ms TTL=247
Reply from 193.69.165.21: bytes=64 time=17ms TTL=247
Reply from 193.69.165.21: bytes=64 time=18ms TTL=247
Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
Minimum = 15ms, Maximum = 18ms, Average = 16ms
EDIT:trodde antall byte ahdde større virkning en det hadde.
Har 4500/728 NGT
Endret av norpreacher
Er ikke mye forskjell nei..
Reply from 193.69.165.21: bytes=64 time=3ms TTL=249
Reply from 193.69.165.21: bytes=64 time=2ms TTL=249
osv..
Jaja, ikke så aller verst da.
Får ikke til å pinge med annet enn 64 akkurat nå. Ping'en er innebygget i
(et) nettverksverktøy i Mac OSX, ingen valg der. Går sikkert an å gjøre
det via kommandolinje i terminal men det vet jeg ikke helt hvordan funker. :blush:
Uansett er det jo greit nok virker det som.
Panther må jo ha tidenes kjappeste ping?? 2ms? Har du fiberlinje rett inn
i VG? :!:
CCTS master som oxo har fiber ligger jo endel over for å si det mildt?
:hmm:
Pinger www.vg.no [193.69.165.21] med 32 byte data:
Svar fra 193.69.165.21: byte=32 tid=<1ms TTL=128
pwned :cool:
pwned :cool:
Journalist i VG Nett du eller?
Reply from 193.69.165.21: bytes=32 time=943ms TTL=248
Reply from 193.69.165.21: bytes=32 time=787ms TTL=248
Reply from 193.69.165.21: bytes=32 time=944ms TTL=248
Reply from 193.69.165.21: bytes=32 time=1668ms TTL=248
Minimum = 787ms, Maximum = 1668ms, Average = 1085ms
Netcom EDGE - på kanten av stupet :roll:
Svar fra 193.69.165.21: byte=32 tid=394ms TTL=248
Svar fra 193.69.165.21: byte=32 tid=343ms TTL=248
Svar fra 193.69.165.21: byte=32 tid=395ms TTL=248
Svar fra 193.69.165.21: byte=32 tid=342ms TTL=248
   minimum = 342ms, maksimum = 395ms, gjennomsnittlig = 368ms
så en britisk server
Pinger coh.co.uk [192.94.58.1] med 32 byte data:
Svar fra 192.94.58.1: byte=32 tid=68ms TTL=52
Svar fra 192.94.58.1: byte=32 tid=60ms TTL=52
Svar fra 192.94.58.1: byte=32 tid=56ms TTL=52
Svar fra 192.94.58.1: byte=32 tid=59ms TTL=52
Ping-statistikker for 192.94.58.1:
   minimum = 56ms, maksimum = 68ms, gjennomsnittlig = 60ms
Canal Digital Maxi (4000/1000)
Tromsø
INGEN aktivitet på linjen.
Endret av Dwagon
Svar fra 193.69.165.21: byte=32 tid=14ms TTL=244
Svar fra 193.69.165.21: byte=32 tid=85ms TTL=244
Svar fra 193.69.165.21: byte=32 tid=83ms TTL=244
minimum = 14ms, maksimum = 85ms, gjennomsnittlig = 49ms
Telenor 2000/300
