Optimize Virtual Memory Utilisation, riktig ?
Hei, jeg bruker Win xp x64 og fant dette på nett. Kan noen bekrefte at det stemmer ?
By increasing the size of the Page File some performance improvement can be obtained.
Right click My Computer go to Properties>Advanced Tab>Performance Settings>Advanced Tab>Change.
Select the HDD on which you have Windows x64 installed and check Custom Size. Insert 2.5 X RAM as Initial Size and 5 x RAM as Maximum Size. Click Set and OK>OK>OK
Default :
Initial size: 1536
Maximum size: 3072
For meg vil da verdiene bli:
Initial size: 2560
Maximum size: 5120
Endret av sir-ivar
