Hva er galt med klokken?
kan det være batteriet på hk som ikke funker så bra lenger ??
men det virker litt rart i grunn, for da skal jo alt i BIOS resettes hver gang? :hmm:
Hva skjer egentlig når biosen resettes?
Når jeg starter opp pcen etter å ha dratt ut strømmen kommer det opp
en melding om att diskettstasjonen ikke finnes.
Jeg tok den ut for et halvt år siden, men har alldri fått denne meldingen i oppstarten.
http://help.lockergnome.com/index.php?showtopic=38006
Bruk dette som det står om nederst på sida:
Open the Registry Editor like you did before and navigate to the key for Windows Time [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time]. In the File drop-down menu select to Export this key to a suitable location with a name like WindowsTime.reg. This in case something goes wrong.
Next, copy the text below between the dotted lines (but not the dotted lines themselves) and paste into Notepad. Save the result as time.reg. Double click on this saved .reg file to merge the contents.
Windows Registry Editor Version 5.00
"Description"="Maintains date and time synchronization on all clients and servers in the network. If this service is stopped, date and time synchronization will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start.
"DisplayName"="Windows Time"
"ErrorControl"=dword:00000001
"Group"=""
"ImagePath"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,\
74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,\
00,76,00,63,00,68,00,6f,00,73,00,74,00,2e,00,65,00,78,00,65,00,20,00,2d,00,\
6b,00,20,00,6e,00,65,00,74,00,73,00,76,00,63,00,73,00,00,00
"Objectname"="LocalSystem"
"Start"=dword:00000002
"Type"=dword:00000020
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Config]
"LastClockRate"=dword:0002625a
"MinClockRate"=dword:000260d4
"MaxClockRate"=dword:000263e0
"FrequencyCorrectRate"=dword:00000004
"PollAdjustFactor"=dword:00000005
"LargePhaseOffset"=dword:00138800
"SpikeWatchPeriod"=dword:0000005a
"HoldPeriod"=dword:00000005
"MaxPollInterval"=dword:0000000f
"LocalClockDispersion"=dword:0000000a
"EventLogFlags"=dword:00000002
"PhaseCorrectRate"=dword:00000001
"MinPollInterval"=dword:0000000a
"UpdateInterval"=dword:00057e40
"MaxNegPhaseCorrection"=dword:0000d2f0
"MaxPosPhaseCorrection"=dword:0000d2f0
"AnnounceFlags"=dword:0000000a
"MaxAllowedPhaseOffset"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Parameters]
"ServiceMain"="SvchostEntry_W32Time"
"ServiceDll"=hex(2):43,00,3a,00,5c,00,57,00,49,00,4e,00,44,00,4f,00,57,00,53,\
00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,77,00,33,00,\
32,00,74,00,69,00,6d,00,65,00,2e,00,64,00,6c,00,6c,00,00,00
"NtpServer"="time.windows.com,0x1"
"Type"="NTP"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Security]
"Security"=hex:01,00,14,80,90,00,00,00,9c,00,00,00,14,00,00,00,30,00,00,00,02,\
00,1c,00,01,00,00,00,02,80,14,00,ff,01,0f,00,01,01,00,00,00,00,00,01,00,00,\
00,00,02,00,60,00,04,00,00,00,00,00,14,00,8d,00,02,00,01,01,00,00,00,00,00,\
05,0b,00,00,00,00,00,18,00,ff,01,0f,00,01,02,00,00,00,00,00,05,20,00,00,00,\
20,02,00,00,00,00,14,00,9d,00,00,00,01,01,00,00,00,00,00,05,04,00,00,00,00,\
00,18,00,9d,00,00,00,01,02,00,00,00,00,00,05,20,00,00,00,21,02,00,00,01,01,\
00,00,00,00,00,05,12,00,00,00,01,01,00,00,00,00,00,05,12,00,00,00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\TimeProviders]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\TimeProviders\NtpClient]
"Enabled"=dword:00000001
"InputProvider"=dword:00000001
"AllowNonstandardModeCombinations"=dword:00000001
"CrossSiteSyncFlags"=dword:00000002
"ResolvePeerBackoffMinutes"=dword:0000000f
"ResolvePeerBackoffMaxTimes"=dword:00000007
"CompatibilityFlags"=dword:80000000
"EventLogFlags"=dword:00000000
"DllName"="C:\\WINDOWS\\system32\\w32time.dll"
"SpecialPollTimeRemaining"=hex(7):74,00,69,00,6d,00,65,00,2e,00,77,00,69,00,6e,\
00,64,00,6f,00,77,00,73,00,2e,00,63,00,6f,00,6d,00,2c,00,37,00,39,00,63,00,\
39,00,36,00,66,00,62,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
"SpecialPollInterval"=dword:00093a80
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\TimeProviders\NtpServer]
"InputProvider"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Enum]
"0"="Root\\LEGACY_W32TIME\\0000"
"Count"=dword:00000001
"NextInstance"=dword:00000001
Endret av zuco~
HEI!
ved et uhell, bikka kompisn min pc'n sin. etter det skulle han sette den på igjen og med en gang hann satte den på begynte den å pipe hele tiden, med faste korte mellomrom. det kom også en melding opp,
Award BootBloc BIOS v1.0
Copyright © 2000, Award Software, Inc.
BIOS ROM checksum error
Detecting floppy drive A media...
Drive A error. System halt
hva har skjedd?
