Lorents Skrevet 5. oktober 2005 Del Skrevet 5. oktober 2005 (endret) Hei! Eg har problemer med å køyre opengl applikasjonar på pc'n min.. lorents@exilion-1:~$ glxgearsXlib: extension "GLX" missing on display ":0.0". glxgears: Error: couldn't get an RGB, Double-buffered visual. lorents@exilion-1:~$ glxinfo name of display: :0.0 Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". Error: couldn't find RGB GLX visual visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". 0x21 24 tc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None Xlib: extension "GLX" missing on display ":0.0". Xlib: extension "GLX" missing on display ":0.0". 0x22 24 dc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None Segmentation fault Eg veit ikkje kva det er som gjer det. det berre var sånn ein dag. Her er xorg.conf fila mi: # /etc/X11/xorg.conf (xorg X Window System server configuration file)# # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following commands: # # cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom # sudo sh -c 'md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum' # sudo dpkg-reconfigure xserver-xorg Section "Files" FontPath "unix/:7100" # local font server # if the local font server has problems, we can fall back on these FontPath "/usr/lib/X11/fonts/misc" FontPath "/usr/lib/X11/fonts/cyrillic" FontPath "/usr/lib/X11/fonts/100dpi/:unscaled" FontPath "/usr/lib/X11/fonts/75dpi/:unscaled" FontPath "/usr/lib/X11/fonts/Type1" FontPath "/usr/lib/X11/fonts/CID" FontPath "/usr/lib/X11/fonts/100dpi" FontPath "/usr/lib/X11/fonts/75dpi" # paths to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" EndSection Section "Module" Load "bitmap" Load "dbe" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "record" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "keyboard" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Device" Identifier "NVIDIA Corporation NV18 [GeForce4 MX 440 AGP 8x]" Driver "nv" BusID "PCI:1:0:0" EndSection Section "Monitor" Identifier "ADI P900" Option "DPMS" HorizSync 30-110 VertRefresh 50-150 EndSection Section "Screen" Identifier "Default Screen" Device "NVIDIA Corporation NV18 [GeForce4 MX 440 AGP 8x]" Monitor "ADI P900" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1600x1200" "1280x1024" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1600x1200" "1280x1024" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1600x1200" "1280x1024" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "1600x1200" "1280x1024" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1600x1200" "1280x1024" "1152x864" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1600x1200" "1280x1024" "1152x864" "1024x768" "800x600" "640x480" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" EndSection Section "DRI" Mode 0666 EndSection Kan nokon hjelpe? Litt vanskeleg å skrive demo uten OpenGL.. Endret 25. oktober 2005 av Lorents Lenke til kommentar
objorkum Skrevet 5. oktober 2005 Del Skrevet 5. oktober 2005 (endret) Du har ikkje NVIDIA-drivaren inne, og har difor ikkje 3D-aksellerasjon, men berre 2D. Distro? EDIT: Ser ut som du har Ubuntu. I så fall: http://www.ubuntuguide.org/#installnvidiadriver Endret 5. oktober 2005 av objorkum Lenke til kommentar
Lorents Skrevet 25. oktober 2005 Forfatter Del Skrevet 25. oktober 2005 Eg har løyst problemet! (egentlig for lenge sida, men har ikkje orka å skrive før no) "# nvidia-glx-config enable" Lenke til kommentar
