OC-Freak Skrevet 13. november 2005 Rapporter Del Skrevet 13. november 2005 Innstillinger: Kapersky antivirus kjørende i bakgrunnen, samt noen andre dilleprogrammer som msn, lydkort, skjermkort osv Trådløst AV. Lysstyrke på skjerm: 2 hakk opp i forhold til minimum. Så en test der maskinen ikke gjør noe - bare står på. System Info Manufacture American Megatrends Inc Model 255/259 Series ModelEx OS Windows XP Service Pack 2 CPU Info CPU Manufacture Intel Corporation CPU Model Intel® Pentium® M processor 1.86GHz CPU Frequency ~799Mhz CPU Extensions | MMX | SSE2 | Enchanted SpeedStep CPU Cache Info Level 1 Instructions 32 Level 1 Data 32 Level 2 Data 2048 System RAM info Total Memory: 1008Mb Memory slots 4 ( 1: 0Mb; 2: 0Mb; 3: 1024Mb; 4: 0Mb; ) Display Device Info Adapter Mobile Intel® 915GM/GMS,910GML Express Chipset Family Resolution 1680x1050 OpenGL render device Intel 915GM OpenGL driver version 1.4.0 - Build 4.14.10.4396 Vertex shader version 0.0 Pixel shader version 2.0 Hard Disk Drive Info S.M.A.R.T. Supported and Enabled HDD Model ST9120821A HDD Serial 3PL00LBA HDD FirmWare 3.04 Main Battery Info Device Name 255/259 Manufacture OEM Serial # Unique ID 00001OEM255/259 Chemistry Lithium Ion Temperature Termal Control Not Present Designed Capacity 81866mWh Full Charged Capacity 79435mWh Designed Voltage 10,8V Current Voltage 10,006V Manufacture Date 0/0/0 Cycles Count 0 Cells count 3 Force charge support Not Supported Force discharge support Not Supported Benchmark results CPU BEmarks 0 GPU BEmarks 0 RAM BEmarks 0 HDD BEmarks 0 Work Done Pi calculations 0 Cycles HDD read\write 0 Mb Fames Rendered 0 Frames Benchmark Options Resolution 800x600x32 FullScreen Disabled Mode Custom Results Total time 5:01:24 Discharge rate (minimum) 2147483648 mWh Discharge rate (maximum) 2147483648 mWh Discharge rate (average) 2147483648 mWh Lenke til kommentar
OC-Freak Skrevet 13. november 2005 Rapporter Del Skrevet 13. november 2005 Konklusjon: Batterilevetiden vil variere fra 3 timer til 5 timer avhengig av belastning, lysstyrke på skjerm, trådløst nett osv. Ekstern mus osv vil også redusere batterilevetiden merkbart. Lenke til kommentar
DHL Skrevet 13. november 2005 Rapporter Del Skrevet 13. november 2005 Konklusjon: Batterilevetiden vil variere fra 3 timer til 5 timer avhengig av belastning, lysstyrke på skjerm, trådløst nett osv. Ekstern mus osv vil også redusere batterilevetiden merkbart. 5147686[/snapback] Takker for hurtig svar på PM, OC-Freak. Lader nå opp 259IEN' min (med identiske specs. som din) Skal kjøre samme test som deg når den er ferdigladet, og se om batteriene våre er noe forskjellige. Hvilken versjon av BatteryEater er det du bruker? (Antar at det er dette programmet du tester med - har ikke lastet det ned selv ennå) Hvis det er interessant for andre kan jeg også poste resultattidene til full load, read og idle. Lenke til kommentar
OC-Freak Skrevet 13. november 2005 Rapporter Del Skrevet 13. november 2005 BE versjon 2.60 Lenke til kommentar
DHL Skrevet 13. november 2005 Rapporter Del Skrevet 13. november 2005 Har her forsøkt å kjøre en tilnærmet identisk test, som den OC-Freak gjorde først, med min maskin. (som har akkuratt samme specs som OC-Freak) - Netshop 259IEN 100% test med BatteryEater 2.60 Instillinger: Intel GMA900 skjermkortet ESET NOD32 antivirus kjørende i bakgrunnen msn(online) - med nettkabel (trådløst av) lydkort skjermkort Lysstyrke på skjerm: 2 hakk opp i forhold til minimum. Drivere fra CD som følger med installert, kjørt på fersk WINXP SP2 ENG installasjon fet skrift er der jeg har funnet forskjeller. Det skal sies at jeg hadde glemt å skru av skjermbeskytter - og denne sto på under testen i ca 20 min. Men dette bør ikke virke negativt på batteritiden? System Info Manufacture American Megatrends Inc Model 255/259 Series ModelEx OS Windows XP Service Pack 2 CPU Info CPU Manufacture Intel Corporation CPU Model Intel® Pentium® M processor 1.86GHz CPU Frequency ~799Mhz CPU Extensions | MMX | SSE2 | Enchanted SpeedStep CPU Cache Info Level 1 Instructions 32 Level 1 Data 32 Level 2 Data 2048 System RAM info Total Memory: 1008Mb Memory slots 4 ( 1: 0Mb; 2: 0Mb; 3: 1024Mb; 4: 0Mb; ) Display Device Info Adapter Mobile Intel® 915GM/GMS,910GML Express Chipset Family Resolution 1680x1050 OpenGL render device Intel 915GM OpenGL driver version 1.4.0 - Build 4.14.10.4277 vs. Build 4.14.10.4396 Vertex shader version 0.0 Pixel shader version 2.0 Hard Disk Drive Info S.M.A.R.T. Supported and Enabled HDD Model ST9120821A HDD Serial 3PL01QL5 HDD FirmWare 3.04 Main Battery Info Device Name 255/259 Manufacture OEM Serial # Unique ID 00001OEM255/259 Chemistry Lithium Ion Temperature Termal Control Not Present Designed Capacity 78778mWh vs 81787mWh Full Charged Capacity 74540mWh vs. 80845mWh Designed Voltage 10,8V Current Voltage 12,487V Manufacture Date 0/0/0 Cycles Count 0 Cells count 3 Force charge support Not Supported Force discharge support Not Supported Benchmark results CPU BEmarks 0 GPU BEmarks 0 RAM BEmarks 0 HDD BEmarks 0 Work Done Pi calculations 13040 Cycles vs. 11961 HDD read\write 21855 Mb vs. 12830 Fames Rendered 320138 Frames vs. 328167 (pga 20 min med scr.sav?) Benchmark Options Resolution 1680x1050x32 FullScreen Enabled Mode Classic Results Total time 2:45:51 vs 3:17:06 Discharge rate (minimum) 2147483648 mWh Discharge rate (maximum) 2147483648 mWh Discharge rate (average) 2147483648 mWh Noe det er verdt å merke seg er det store avviket på harddisk read/write i.f.t OC Freak. Hvorfor testene oppførte seg så forskjellig her vet jeg ikke. Jeg skal gjøre en "readers test" i morgen for å se om det er såpass store avvik i batteritiden her ( jeg synes en halvtime er mye ) Lenke til kommentar
DHL Skrevet 14. november 2005 Rapporter Del Skrevet 14. november 2005 Jeg kjørte i dag en test på batteritiden ved en "readers test" som nevnt tidligere. For å være ganske sikker på at min laptop ikke gjorde mer jobb enn OC-Freak's skrudde jeg av msn og antivirus, slik at bare default bakgrunnsprogrammene til skjermkort og lydkort kjørte. OC-Freak fikk på denne testen 4timer og 56 min. Jeg fikk 3 timer og 59 min, altså omtrent en time forskjell med samme/~lavere krav fra bakgrunnsprogrammer. (Samme maskin, for de som ikke har lest over) Er det vanlig med så store forskjeller på batteritid ved bruk av samme type batteri? Bortsett fra dette er jeg veldig fornøyd med maskinen. Har dessverre fått et tastatur som buler noe opp på midten (F7,F8 og tastene rundt ligger litt høyere opp enn de andre), som gjør at jeg får irriterende knirkelyder når jeg trykker på disse tastene. Dette er litt kjedelig når man sitter på lesesal. Er veldig fornøyd med maskinen ellers, men om problemet med batteritid ikke bedrer seg, og jeg ikke blir vant til knirkingen fra tastene, tror jeg at jeg tar en telefon til NetShop. Er disse grunnene gode nok til å få nytt batteri og tastatur? (Vet at dette høres litt sytete ut i forhold til Mr. Locke, som bare fikk 2 timer på sitt batteri i idle mode ) Lenke til kommentar
Mr.Locke Skrevet 14. november 2005 Rapporter Del Skrevet 14. november 2005 (endret) 259IEN kjører kontinuerlig uten vifte i sikkert 2000 dager under vanlig kontorbruk i GMA900 modus, og ikke ved jevne mellomrom etter 20 minutters stillhet som på mange andre maskiner. I 6600 modus går vifta innimellom, men da også på veldig svak hastighet, rundt hvert 10 minutt veldig kort tid under normal kontorbruk. Vifteanordningen har nesten ingen aksellerasjonsstøy når den slår seg av/på så det er en veldig myk, lite merkbar og lite irriterende overgang når den først setter i gang. Endret 14. november 2005 av Mr.Locke Lenke til kommentar
OC-Freak Skrevet 15. november 2005 Rapporter Del Skrevet 15. november 2005 *drep batteri fortest mulig* testen. *MAX lysstyrke på skjerm. *Nvidia 6600 skjermkort. *Razer diamondback USB mus som sluker strøm (er vel den mest strømsultne musa på markedet) *Opptisk drev brukt til vekselvis brenning og lesing av plater i hele testperioden. *winamp spiller musikk *Trådløst internett på og pålogget msn. System Info Manufacture American Megatrends Inc Model 255/259 Series ModelEx OS Windows XP Service Pack 2 CPU Info CPU Manufacture Intel Corporation CPU Model Intel® Pentium® M processor 1.86GHz CPU Frequency ~800Mhz CPU Extensions | MMX | SSE2 | Enchanted SpeedStep CPU Cache Info Level 1 Instructions 32 Level 1 Data 32 Level 2 Data 2048 System RAM info Total Memory: 1024Mb Memory slots 4 ( 1: 0Mb; 2: 0Mb; 3: 1024Mb; 4: 0Mb; ) Display Device Info Adapter NVIDIA GeForce Go 6600 Resolution 1680x1050 OpenGL render device GeForce Go 6600/PCI/SSE2 OpenGL driver version 2.0.1 Vertex shader version 3.0 Pixel shader version 3.0 Hard Disk Drive Info S.M.A.R.T. Supported and Enabled HDD Model ST9120821A HDD Serial 3PL00LBA HDD FirmWare 3.04 Main Battery Info Device Name 255/259 Manufacture OEM Serial # Unique ID 00001OEM255/259 Chemistry Lithium Ion Temperature Termal Control Not Present Designed Capacity 76916mWh Full Charged Capacity 76264mWh Designed Voltage 10,8V Current Voltage 12,597V Manufacture Date 0/0/0 Cycles Count 0 Cells count 3 Force charge support Not Supported Force discharge support Not Supported Benchmark results CPU BEmarks 0 GPU BEmarks 0 RAM BEmarks 0 HDD BEmarks 0 Work Done Pi calculations 58206 Cycles HDD read\write 5026 Mb Fames Rendered 729519 Frames Benchmark Options Resolution 1280x800x32 FullScreen Disabled Mode Classic Results Total time 1:56:18 Discharge rate (minimum) 2147483648 mWh Discharge rate (maximum) 2147483648 mWh Discharge rate (average) 2147483648 mWh Lenke til kommentar
OC-Freak Skrevet 15. november 2005 Rapporter Del Skrevet 15. november 2005 (endret) OBS på at jeg har kun 1.86GHz CPU, har du bedre CPU vil tiden bli dårligere (til de som evt måtte ha annen CPU - for at de ikke skal hyle om tidene avviker mye). Jeg har også kun 1 x 1Gb RAM brikke. 2 brikker vil trekke ørlite mer strøm, men dette burde ikke utgjøre så mange minutter. Endret 15. november 2005 av OC-Freak Lenke til kommentar
Dev82 Skrevet 25. november 2005 Rapporter Del Skrevet 25. november 2005 Noen som kan bekrefte om ladetiden blir kortere eller ikke? Ev. hvor lang tid vil det ta etterhvert? Har driiitlyst på en slik maskin. stiduck Lenke til kommentar
Cocytor Skrevet 25. november 2005 Rapporter Del Skrevet 25. november 2005 Hva? Er det en tråd om 259IEN her også? Er det noen som har fått en fungerende maskin fra Itbutikken.no? Aner meg at de har et problem med deres leveranser. Link Lenke til kommentar
B4stian Skrevet 6. januar 2006 Rapporter Del Skrevet 6. januar 2006 Hvordan skal jeg lade denne første gangen da? Tar den skade av bruk med en gang? Lenke til kommentar
Mr.Locke Skrevet 7. januar 2006 Rapporter Del Skrevet 7. januar 2006 Nei, ikke så lende den står i strømmen. Batteriet kan derimot bli feilkalibrert hvis du bruker den på batteri uten å ha ladet den i 1 døgn først ved å ha den i strømmen hele tiden det første døgnet. Om du bruker maskinen mens den er i strømmen/lader er irellevant. Lenke til kommentar
Klyngve Skrevet 12. januar 2006 Rapporter Del Skrevet 12. januar 2006 Jeg bestilte maskinen idag, og fikk vite at den ville bli sendt på mandag. Høres ikke ut som om de har særlig problemer med leveranser for meg, i alle fall. Lenke til kommentar
MIZZ_HELL Skrevet 22. januar 2006 Rapporter Del Skrevet 22. januar 2006 Hvor lang tid tar det fra man bestiller til man får den/den blir sendt?? Kommer nokk til å bestille denne denne uken har sikklet lenge på den, og nå skal jeg endelig bestille den :D Standard 1 stk. Uniwill tastatur norsk til modell 259xx (På lager 100+) 1 stk. Uniwill 259IEN barebone PC 15,4" WSXGA+, DVD-RW,Nvidia 6600 256MB, kortleser (På lager 20+) Montering 1 stk. Produksjon og testing av PC stasjonær (På lager 100+) CPU 1 stk. Intel Pentium M 760 2,0 GHz FSB533 2MB CACHE BOXED "Sonoma" (På lager 2) Minne 1 stk. Kingston 1 GB 533MHz (4200) DDR2 SODIMM Non-ECC CL4, 200 pins, (På lager 20+) Minne 2 Ingen Harddisk 1 stk. Seagate Momentus 120GB 5400RPM 8MB IDE ATA/100 2,5" 9,5mm ST9120821A (På lager 4) Operativsystem 1 stk. Microsoft Windows XP Home OEM Norsk versjon m/SP2 (På lager 20+) Nettverkskort 1 stk. Bluetoothmodul for uniwill bærbar Bluetooth for uniwill 259 (På lager 20+) Trådløst nettverk 1 stk. Intel Wireless LAN Mini PCI Card ABG 11-54MBPs (På lager 19) Sum pris: kr 15984,01 Er dette en OK pc..? Prisen svir litt men.. får den uten moms, så det føles jo litt bedre da Lenke til kommentar
Klyngve Skrevet 22. januar 2006 Rapporter Del Skrevet 22. januar 2006 Jeg har tilsvarende med litt annet oppsett, og er veldig fornøyd! Lenke til kommentar
the_fire Skrevet 23. januar 2006 Rapporter Del Skrevet 23. januar 2006 Vel, jeg leter fortsatt etter laptop. Fungerer denne til BF2? Hvordan er den ellers i bruk? Lenke til kommentar
Mr.Locke Skrevet 23. januar 2006 Rapporter Del Skrevet 23. januar 2006 Den er veldig rask til BF2 i native oppløsning (1680x1050) med mesteparten av effekter på fullt. Dvs mere enn rask nok (I GF6600 modus.) Lenke til kommentar
MIZZ_HELL Skrevet 24. januar 2006 Rapporter Del Skrevet 24. januar 2006 Nå er maskinen bestillt.. Gleder meg som F!! Har ønska meg den i evigheter og nå er den snart på vei :D Btw... noen som vet hvor lang tid det tar før de sender den etter at man har bestillt? Lenke til kommentar
Explorer Skrevet 24. januar 2006 Rapporter Del Skrevet 24. januar 2006 Nå er maskinen bestillt.. Gleder meg som F!! Har ønska meg den i evigheter og nå er den snart på vei :D Btw... noen som vet hvor lang tid det tar før de sender den etter at man har bestillt? 5489153[/snapback] Det går nok ganske raskt, tipper et par dager med mekking før sending. Var ihvertfall noe sånn det tok for meg, med min 259.. Om batteritiden, er litt usikker på om den er normalt god, eller om den er for dårlig. Tviler sterkt på at jeg ville greid å få 5 timer batteritid (ikke mulig uansett da jeg har større prosessor). Tviler egentlig på at jeg ville greid 4 timer heller. Men det må jeg i så tilfelle bare kjøre en test på når jeg får tid.. Lastet ned et program for å styre prosessoren, Notebook Hardware Control/Centrino Hardware Control. Dette gir mulighet for å tvinge prosessoren til å kjøre på laveste hastighet (mye bedre styring enn Windows greier) for å få mest mulig batteritid. Det gir også mulighet for å stille på Vcore-speinningen til prosessoren, noe som gjør at den kjører kaldere og lengre batteritid. Man kan stille spenningen for hvert enkelt av trinnene med multiplier, noe jeg ikke har gjort. Ved 840MHz (som den kjører på laveste hastighet) så har jeg senket spenningen helt ned til 0,700V til sammenligning så kjører den normalt 0,988V der. Det ble en merkbar forbedring i temperaturene med det. Temperaturen ligger nå på 49 grader C og viften viser ikke livstegn. Maskinen holder også en veldig behagelig temperatur til å ha i fanget da. Lenke til kommentar
