janan71 Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 (endret) Fra World of Raids, PTR patch 3.1.0: Shaman * Bloodlust/Heroism: Cooldown reduced to 5 minutes, but Sated and Exhausted now last 10 minutes. * Poison Cleansing Totem and Disease Cleansing Totem have been merged into "Cleansing Totem." Cleansing Totem pulses every 3 sec, down from 5. * Talents o Enhancement + Lava Lash now has a new icon. + New Talent: Frozen Power: Increases the damage done by your Frostbrand Weapon if it is enchanted on your main-hand weapon by 10/20%, and your Frost Shock has a 50/100% chance to root the target in Ice for 5 sec. when used on targets at or further than 15 yards from you. + Spirit Weapons: Now reduces all threat generated by 30%, not just physical attacks. + Stormstrike charges have been increased by 2, and cooldown reduced by 2 sec. + Improved Stormstrike re-designed: When you Stormstrike, you have a 50/100% chance to immediately grant you 20% of your base mana. + Toughness: No longer increases your armor. Instead, this talent now increases your total Stamina by 2/4/6/8/10%. + Unleashed Rage - Reduced to 3 points, down from 5. Each point now also increases your total Agility by 1/2/3%. o Elemental + New Talent: Booming Echoes- Reduces the cooldown of your Flame Shock and Frost Shock spells by an additional 1/2 sec., and increases the direct damage done by your Flame Shock and Frost Shock spells by an additional 10/20%. o Restoration + Ancestral Awakening: This talent now accounts for your ineffective healing, rather than effective. + Cleanse Spirit now has a new icon. + Riptide: This spell has a new icon. Endret 24. februar 2009 av janan71 Lenke til kommentar
Kuldesjokk Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Grats med nye ikoner nok en gang Lenke til kommentar
janan71 Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 (endret) Var jo et par som var ganske greie da, i alle fall for enhancement. + Stormstrike charges have been increased by 2, and cooldown reduced by 2 sec. + Improved Stormstrike re-designed: When you Stormstrike, you have a 50/100% chance to immediately grant you 20% of your base mana. => Enda mer mana er vel alltid greit. + Toughness: No longer increases your armor. Instead, this talent now increases your total Stamina by 2/4/6/8/10%. => Et ubrukelig talent er ikke lenger fult så ubrukelig. + Unleashed Rage - Reduced to 3 points, down from 5. Each point now also increases your total Agility by 1/2/3%. => Færre poeng for +ap og +agi gjør et bra talent enda bedre. Endret 24. februar 2009 av janan71 Lenke til kommentar
XtaZ Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Hmm. Healing stream og mana spring totem var det vel å snakk om at skulle merges sammen men ser ikke den i lista. Håper dette fortsatt er aktuelt? Lenke til kommentar
nilox Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 + Cleanse Spirit now has a new icon. + Riptide: This spell has a new icon. Haha, kødder du eller? Hva er det med shamans og nye ikoner? Har de en egen fyr som kun lager ikoner som har lite å gjøre eller? Lenke til kommentar
Dernel Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Men vi fikk da mye nytt og bra i enhancement Kanskje jeg greier og drive med arena :O Lenke til kommentar
Lycantrophe Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 (endret) Wtf? Judgements of the Wise til shamans? Og ang. ikonene: Hahaha! :!: Endret 24. februar 2009 av Lycantrophe Lenke til kommentar
Nerf Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Wewt! Da er det bare å vente på en oppdatering på http://www.wow-europe.com/en/info/classes/shaman/ : Ny styrke: "Gets exciting new icons with each patch to enhance PvP viability!" Dette er ikke morsomt lengre. >.> Lenke til kommentar
XtaZ Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 (endret) Forresten. Burde ikke Frozen power heller vert et elemental skill istedenfor enhance? Greit at den booster frostbrand weapon men fryse folk fast på avstand når man er meele klasse virker litt rart da man uansett må innpå fienden. funker heller ikke på nært hold så å fryse fast fienden i close combat å løpe unna å ta noen heals funker jo heller dårlig. På elemental derimot hadde dette vert gull så håper den ligger tidlig på enhance treet så jeg får tatt nytte av det også Endret 24. februar 2009 av XtaZ Lenke til kommentar
DisplayName123 Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Du må innpå fienden, ja, og det er jo mye enklere dersom de ikke løper fra deg? Lenke til kommentar
XtaZ Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Du må innpå fienden, ja, og det er jo mye enklere dersom de ikke løper fra deg? At folk stikker fra enhc shaman har vel aldri vert noe stort problem da man har både slow effect på frost shock å ghost wolf? Skal ikke si sikkert jeg men da jeg stort sett har spilt som elemental men får ele shammys tak på den skillen også så ser jeg for meg at pvp mot meele class blir en helt ny opplevelse Lenke til kommentar
Lycantrophe Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Har du levd under en sten de siste tre årene? Lenke til kommentar
Zarfax Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 (endret) Skulle ikke både Ele og enh få mer pvp utility? Ser uansett relativt bra ut, mye bedre enn det jeg hadde trodd Endret 24. februar 2009 av Zarfax Lenke til kommentar
BullStrike Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Hei. Jeg vurderer å lage meg en Shaman, Dranei (allianse). Er det noe gøy å være shaman? Må de være sånn magi dude, eller kan de være melee? Er det lett/gøy å levle? Lenke til kommentar
Dernel Skrevet 24. februar 2009 Del Skrevet 24. februar 2009 Som shaman kan du velge enten melee, eller caster (magi dude) I starten har du dog bare spells, men det blir mye bedre og artigere oppover i levlene. Shaman er Lett/gøy å levle, ja Lenke til kommentar
FKL982 Skrevet 25. februar 2009 Del Skrevet 25. februar 2009 Gøy og gøy..respec av og til, så er det gøy. Hadde enchancement til 60, ble drittlei. Specca elemental, var gøy til rundt lvl 67, men hadde det til 70. Nesten 72 nå, er enchancement igjen, og det er VILT gøy Topper alltid DPS-listene Lenke til kommentar
Fylla Skrevet 28. februar 2009 Del Skrevet 28. februar 2009 har mikest litt og kommet fram til denne Resto speccen. hva tror dere, duger denne til raids? Lenke til kommentar
Trashyman Skrevet 28. februar 2009 Del Skrevet 28. februar 2009 Er vel ærlig talt standard spec for healing. Dog, hvorfor har du ikke Cleanse Spirit? Lenke til kommentar
Dernel Skrevet 28. februar 2009 Del Skrevet 28. februar 2009 Ja, Cleanse Spirit er jo et must. Lenke til kommentar
Fylla Skrevet 1. mars 2009 Del Skrevet 1. mars 2009 har vell nok av shamans i Raidene og vi har Totems for det + at vi har mage's etc som tar seg av curse så vil tør og påstå at Cleanse Spirit er waste og heller vil putte den siste pointsen i noe som har mere effekt. Lenke til kommentar
