TurtleMan Skrevet 28. september 2005 Del Skrevet 28. september 2005 Hei, fikk nettopp nå en blåskjerm. Gjorde ikke noe spesielt på PC'en bare surfet litt rundt osv. Mld er: *** Stop: 0x000000D1 (0xb926c76e, 0x00000002, 0x00000000, 0xb926c76e) Hva er dette? Prøvde å kopiere mld inn på google, men google fant jo ikke en dritt, prøde med hele mld, og med bare 0xb926c76e. Kan noen si meg hva som er gale?? Maskinvaren står i signaturen, har AVG antivirus 7 Pro, og Sygate Personal FW Pro, og SP1 og Windows XP Pro. Lenke til kommentar
Spragleknas Skrevet 28. september 2005 Del Skrevet 28. september 2005 Stop 0x000000D1 Error Message When You Turn Your Computer OffView products that this article applies to. Article ID : 317326 Last Review : September 27, 2005 Revision : 1.2 This article was previously published under Q317326 SYMPTOMS When you shut down your computer that has one or more universal serial bus (USB) devices attached to it, you may receive the following error message on a blue screen: Stop 0x000000D1 (0x00000040, 0x00000002, 0x00000000, 0xfc96a9dc) CAUSE This problem may occur because the OHCI endpoint is unable to find the transfer descriptor in the list. RESOLUTION To resolve this problem, obtain the latest service pack for Windows XP. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: 322389 (http://support.microsoft.com/kb/322389/EN-US/) How to Obtain the Latest Windows XP Service Pack The English version of this fix should have the following file attributes or later: Date Time Version Size File name -------------------------------------------------- 06-Feb-02 18:30 5.1.2600.28 15,616 Usbohci.sys STATUS Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article. This problem was first corrected in Windows XP Service Pack 1. APPLIES TO • Microsoft Windows XP Home Edition • Microsoft Windows XP Professional Back to the top Back to the top Keywords: kbhotfixserver kbqfe kbbug kbenv kberrmsg kbfix kboswin2000fix kbwinxpsp1fix KB317326 Lenke til kommentar
TurtleMan Skrevet 28. september 2005 Forfatter Del Skrevet 28. september 2005 Det sa meg igrunn lite... Har det noe med USB å gjøre? Jeg har aldri fått denne mld før, og nå når jeg restartet maskinen er den helt fin igjen.. Når det gjelder USB'er, har camera, printer, skanner, mus og i fronten har jeg 2 usb'er og de står free slik at jeg kan putte inn enten ledningen til K750'en eller mp3 spiller, eller blåtann adapter.. Har det noe med USB å gjøre? Lenke til kommentar
darkness| Skrevet 29. september 2005 Del Skrevet 29. september 2005 Meldingen sier i hvert fall at du bør laste ned siste SP, men egentlig så stemmer ikke alt overens med det du forteller. Du sa du satt og surfet. I teksten over står det at den skal dukke opp når du slår maskinen av. Lenke til kommentar
Frijazz Skrevet 29. september 2005 Del Skrevet 29. september 2005 Det anbefales uansett å installere SP2. Lenke til kommentar
