Problem med avspilling i Mediaplayer
Mnett
Hei
Når jeg skal spille av videoer på internett (for eksempel nrk nett tv) så får jeg ikke spilt den av. Feilen som kommer er "C00D11BB - Kan ikke spille av filen fordi den angitte protokollen ikke støttes. Hvis du skrev inn en URL-adresse i dialogboksen Åpne URL-adresse, kan du prøve å bruke en annen transportprotokoll (for eksempel "http:" eller "rtsp:")."
Når jeg trykker på play bare stopper den. Den starter ikke å bufre eller noe. Noen spm vet hva som er galt?
se dette her:
http://msmvps.com/chrisl/articles/12340.aspx
lykke til
edit: og dette
C00D11BB: Cannot play the file
Windows Media Player cannot play the file because the specified protocol is either not supported by the Player or not supported by the server that is hosting the content.
If you encountered this error by clicking a link on a Web page, the link might not be valid.
If you encountered this error by typing a Uniform Resource Locator (URL) in the Open URL dialog box, try opening the file by using a different transport protocol (for example, "http:" or "rtsp:").
A list of protocols supported by the Player and the correct syntax follows:
mms://server/filename (for example, a file with a .wma, .wmv, .asf, or .mp3 extension)
http://server/filename
rtsp://server/filename
mms://server/sami.asf?SAMI=http://server/sami/sami_demo.smi (SAMI file)
If Windows Media Player supports the protocol and you still cannot play the content, ensure that the Player is configured to use all of its supported protocols.
To configure protocol settings
On the Tools menu, click Options, and then click the Network tab.
In the Streaming protocols area, select all the protocol check boxes.
Note
The supported protocols can be used only to stream digital media files. Windows Media Player cannot be used as a browser.
Endret av gaggen
