Problemer med dvd brenneren
Har en Plextor dvd/cd rom brenner px-716a har siste firmware og jeg har hatt den lenge, men nå funker plutselig ikke brenneren som den skal, noen gangerfår jeg ikke startet å brenne engang, men som regel får jeg bare opp en feil melding etter at den liksom skal være ferdig med å brenne. her er loggen som kom ut av nero:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programfiler\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26.10.2004 18:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
(Nero Express)
Recorder: <PLEXTOR DVDR PX-716A> Version: 1.08 - HA 0 TA 0 - 6.6.0.16
Adapter driver: <nvata> HA 0
Drive buffer : 8192kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <TSSTcorp DVD-ROM TS-H352A>Version: TS05 - HA 0 TA 2 - 6.6.0.16
=== Scsi-Device-Map ===
CdRomPeripheral : PLEXTOR DVDR PX-716A nvata Port 0 ID 0 DMA: Off
CdRomPeripheral : TSSTcorp DVD-ROM TS-H352A nvata Port 0 ID 2 DMA: Off
DiskPeripheral : ST3250823AS nvata Port 2 ID 0 DMA: Off
OtherPeripheral : SI Pseudo Device 0000 Si3114r5 Port 3 ID 16 DMA: Off
=== CDRom-Device-Map ===
PLEXTOR DVDR PX-716A E: CDRom3
TSSTcorp DVD-ROM TS-H352A F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1046960kB)
Free physical memory: 535MB (548664kB)
Memory in use : 47 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
24.9.2005
Audio CD
12:16:48 #1 CDADOC -1 File Cdadoc.cpp, Line 1465
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 03:37.15, Pause frames: 150, Filters: 0, Name: 'Missy Elliot French man-All in my grill.mp3'.
Track 02: Length: 03:35.06, Pause frames: 150, Filters: 0, Name: 'Missy Elliott french - All n my grill.wma'.
Track 03: Length: 04:32.18, Pause frames: 150, Filters: 0, Name: 'Outkast - All In My Grill.mp3'.
Track 04: Length: 04:49.38, Pause frames: 150, Filters: 0, Name: '01-missy_elliott-joy_(feat_mike_jones)_(produced_by_timbaland)_-_www.torrentazos.com.mp3'.
Track 05: Length: 03:04.22, Pause frames: 150, Filters: 0, Name: '02-missy_elliott-partytime_(produced_by_timbaland)_-_www.torrentazos.com.mp3'.
Track 06: Length: 04:15.73, Pause frames: 150, Filters: 0, Name: '03-missy_elliott-irresistible_delicious_(feat_slick_rick)_(produced_by_craig_x_brockman)_-_www.torrentazos.com.mp3'.
Track 07: Length: 03:47.25, Pause frames: 150, Filters: 0, Name: '04-missy_elliott-lose_control_(feat_ciara_and_fat_man_scoop)_(produced_by_missy_elliot)_-_www.torrentazos.com.mp3'.
Track 08: Length: 02:52.24, Pause frames: 150, Filters: 0, Name: '05-missy_elliott-my_struggles_(feat_mary_j_blige_and_grand_puba)_(produced_by_quran_h_goodman)_-_www.torrentazos.com.mp3'.
Track 09: Length: 04:16.50, Pause frames: 150, Filters: 0, Name: '06-missy_elliott-meltdown_(produced_by_scott_storch)_-_www.torrentazos.com.mp3'.
Track 10: Length: 04:45.66, Pause frames: 150, Filters: 0, Name: '07-missy_elliotton_and_on_(produced_by_the_neptunes)_-_www.torrentazos.com.mp3'.
Track 11: Length: 03:25.24, Pause frames: 150, Filters: 0, Name: '08-missy_elliott-we_run_this_(produced_by_rhemario_rio_beats_webber)_-_www.torrentazos.com.mp3'.
Track 12: Length: 04:18.71, Pause frames: 150, Filters: 0, Name: '09-missy_elliott-remember_when_(produced_by_missy_elliot)_-_www.torrentazos.com.mp3'.
Track 13: Length: 05:10.56, Pause frames: 150, Filters: 0, Name: '10-missy_elliott-my_man_(feat_fantasia)_(produced_by_the_avila_brothers)_-_www.torrentazos.com.mp3'.
Track 14: Length: 03:49.12, Pause frames: 150, Filters: 0, Name: '11-missy_elliott-cant_stop_(produced_by_rich_harrison)_-_www.torrentazos.com.mp3'.
Total size: 56:48.50
12:16:48 #2 Text 0 File Burncd.cpp, Line 2948
BURN-Proof activated
12:16:48 #3 Text 0 File Reader.cpp, Line 127
Reader running
12:16:48 #4 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
12:16:48 #5 Text 0 File Writer.cpp, Line 122
Writer PLEXTOR DVDR PX-716A running
12:16:48 #6 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using CD-R/RW media
12:16:48 #7 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 255499 ( 56:48.49)
12:16:48 #8 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
12:16:48 #9 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: PLEXTOR DVDR PX-716A;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
12:16:48 #10 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
12:16:48 #11 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (Missy Elliot French man-All in my grill.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 16290 (16290) = #16290/3:37.15
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16290 blocks [PLEXTOR DVDR PX-716A]
1: TRM_AUDIO_NOPRE (Missy Elliott french - All n my grill.wma)
original disc pos #0 + 16131 (16131) = #16131/3:35.6
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 16131 blocks [PLEXTOR DVDR PX-716A]
2: TRM_AUDIO_NOPRE (Outkast - All In My Grill.mp3)
original disc pos #0 + 20418 (20418) = #20418/4:32.18
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20418 blocks [PLEXTOR DVDR PX-716A]
3: TRM_AUDIO_NOPRE (01-missy_elliott-joy_(feat_mike_jones)_(produced_by_timbaland)_-_www.torrentazos.com.mp3)
original disc pos #0 + 21713 (21713) = #21713/4:49.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21713 blocks [PLEXTOR DVDR PX-716A]
4: TRM_AUDIO_NOPRE (02-missy_elliott-partytime_(produced_by_timbaland)_-_www.torrentazos.com.mp3)
original disc pos #0 + 13822 (13822) = #13822/3:4.22
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13822 blocks [PLEXTOR DVDR PX-716A]
5: TRM_AUDIO_NOPRE (03-missy_elliott-irresistible_delicious_(feat_slick_rick)_(produced_by_craig_x_brockman)_-_www.torrentazos.com.mp3)
original disc pos #0 + 19198 (19198) = #19198/4:15.73
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19198 blocks [PLEXTOR DVDR PX-716A]
6: TRM_AUDIO_NOPRE (04-missy_elliott-lose_control_(feat_ciara_and_fat_man_scoop)_(produced_by_missy_elliot)_-_www.torrentazos.com.mp3)
original disc pos #0 + 17050 (17050) = #17050/3:47.25
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17050 blocks [PLEXTOR DVDR PX-716A]
7: TRM_AUDIO_NOPRE (05-missy_elliott-my_struggles_(feat_mary_j_blige_and_grand_puba)_(produced_by_quran_h_goodman)_-_www.torrentazos.com.mp3)
original disc pos #0 + 12924 (12924) = #12924/2:52.24
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12924 blocks [PLEXTOR DVDR PX-716A]
8: TRM_AUDIO_NOPRE (06-missy_elliott-meltdown_(produced_by_scott_storch)_-_www.torrentazos.com.mp3)
original disc pos #0 + 19250 (19250) = #19250/4:16.50
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19250 blocks [PLEXTOR DVDR PX-716A]
9: TRM_AUDIO_NOPRE (07-missy_elliott-on_and_on_(produced_by_the_neptunes)_-_www.torrentazos.com.mp3)
original disc pos #0 + 21441 (21441) = #21441/4:45.66
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21441 blocks [PLEXTOR DVDR PX-716A]
10: TRM_AUDIO_NOPRE (08-missy_elliott-we_run_this_(produced_by_rhemario_rio_beats_webber)_-_www.torrentazos.com.mp3)
original disc pos #0 + 15399 (15399) = #15399/3:25.24
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15399 blocks [PLEXTOR DVDR PX-716A]
11: TRM_AUDIO_NOPRE (09-missy_elliott-remember_when_(produced_by_missy_elliot)_-_www.torrentazos.com.mp3)
original disc pos #0 + 19421 (19421) = #19421/4:18.71
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19421 blocks [PLEXTOR DVDR PX-716A]
12: TRM_AUDIO_NOPRE (10-missy_elliott-my_man_(feat_fantasia)_(produced_by_the_avila_brothers)_-_www.torrentazos.com.mp3)
original disc pos #0 + 23306 (23306) = #23306/5:10.56
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23306 blocks [PLEXTOR DVDR PX-716A]
13: TRM_AUDIO_NOPRE (11-missy_elliott-cant_stop_(produced_by_rich_harrison)_-_www.torrentazos.com.mp3)
original disc pos #0 + 17187 (17187) = #17187/3:49.12
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17187 blocks [PLEXTOR DVDR PX-716A]
12:16:48 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [PLEXTOR DVDR PX-716A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 14:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 38666880, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 38666880 39019680 76959792, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 76959792 77312592 125335728, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 125335728 125688528 176757504, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 176757504 177110304 209619648, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 209619648 209972448 255126144, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 255126144 255478944 295580544, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 295580544 295933344 326330592, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 326330592 326683392 371959392, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 371959392 372312192 422741424, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 422741424 423094224 459312672, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 459312672 459665472 505343664, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 505343664 505696464 560512176, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 560512176 560864976 601288800, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
16290 | 2 | 0 | 0x21 | 0x00
16440 | 2 | 1 | 0x21 | 0x00
32571 | 3 | 0 | 0x21 | 0x00
32721 | 3 | 1 | 0x21 | 0x00
53139 | 4 | 0 | 0x21 | 0x00
53289 | 4 | 1 | 0x21 | 0x00
75002 | 5 | 0 | 0x21 | 0x00
75152 | 5 | 1 | 0x21 | 0x00
88974 | 6 | 0 | 0x21 | 0x00
89124 | 6 | 1 | 0x21 | 0x00
108322 | 7 | 0 | 0x21 | 0x00
108472 | 7 | 1 | 0x21 | 0x00
125522 | 8 | 0 | 0x21 | 0x00
125672 | 8 | 1 | 0x21 | 0x00
138596 | 9 | 0 | 0x21 | 0x00
138746 | 9 | 1 | 0x21 | 0x00
157996 | 10 | 0 | 0x21 | 0x00
158146 | 10 | 1 | 0x21 | 0x00
179587 | 11 | 0 | 0x21 | 0x00
179737 | 11 | 1 | 0x21 | 0x00
195136 | 12 | 0 | 0x21 | 0x00
195286 | 12 | 1 | 0x21 | 0x00
214707 | 13 | 0 | 0x21 | 0x00
214857 | 13 | 1 | 0x21 | 0x00
238163 | 14 | 0 | 0x21 | 0x00
238313 | 14 | 1 | 0x21 | 0x00
255500 | lead-out | 1 | 0x01 | 0x00
12:16:48 #13 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 48x (7 200 KB/s)
12:16:48 #14 SCSI -1189 File Cdrdrv.cpp, Line 1180
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x03AD6200
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x02
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0xFF 0x40 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x02
12:16:48 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
12:16:48 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #16440
12:16:48 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #32721
12:16:48 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #53289
12:16:48 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #75152
12:16:48 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #89124
12:16:48 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #108472
12:16:48 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #125672
12:16:48 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #138746
12:16:48 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #158146
12:16:48 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #179737
12:16:48 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #195286
12:16:48 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #214857
12:16:48 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #238313
12:16:48 #29 Text 0 File Mmc.cpp, Line 16922
StartDAO : CD-Text - On
12:16:48 #30 Text 0 File Mmc.cpp, Line 21708
Set BUFE: BURN-Proof -> ON
12:16:48 #31 Text 0 File Mmc.cpp, Line 17211
CueData, Len=240
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 03 27 0f
21 02 01 00 00 03 29 0f
21 03 00 00 00 07 10 15
21 03 01 00 00 07 12 15
21 04 00 00 00 0b 32 27
21 04 01 00 00 0b 34 27
21 05 00 00 00 10 2a 02
21 05 01 00 00 10 2c 02
21 06 00 00 00 13 30 18
21 06 01 00 00 13 32 18
21 07 00 00 00 18 06 16
21 07 01 00 00 18 08 16
21 08 00 00 00 1b 37 2f
21 08 01 00 00 1b 39 2f
21 09 00 00 00 1e 31 47
21 09 01 00 00 1e 33 47
21 0a 00 00 00 23 08 2e
21 0a 01 00 00 23 0a 2e
21 0b 00 00 00 27 38 25
21 0b 01 00 00 27 3a 25
21 0c 00 00 00 2b 17 3d
21 0c 01 00 00 2b 19 3d
21 0d 00 00 00 2f 2c 39
21 0d 01 00 00 2f 2e 39
21 0e 00 00 00 34 39 26
21 0e 01 00 00 34 3b 26
01 aa 01 01 00 38 30 32
12:16:55 #32 Text 0 File Cdrdrv.cpp, Line 1286
12:16:55.859 - PLEXTOR DVDR PX-716A\H0 T0 : Queue again later
12:17:31 #33 SCSI -1093 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x06C10000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0xFF 0xFF 0xD2 0x8E 0x00 0x02 0xAA 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x02 0x00
12:17:31 #34 CDR -1093 File Writer.cpp, Line 311
No seek complete
12:17:35 #35 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
12:17:35 #36 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
12:17:35 #37 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 48x (7 200 KB/s)
12:17:35 #38 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
12:17:35 #39 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\nvata.sys': Ver=5.10.2600.0534 built by: WinDDK, size=92800 bytes, created 17.05.2005 17:45:08 (Adapter driver for rec)
File 'Drivers\nvatabus.sys': Ver=5.10.2600.0479 built by: WinDDK, size=87936 bytes, created 12.01.2005 01:32:20 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Vet ikke om det er dvd/cd rom brenneren eller nero programmet,forstår ikke så mye av denne feil meldingen, kan noen her hjelpe meg?
stalltips
prøv annet brenneprogram, f.eks. det i mediaplayer
brennere slites ut...selv om plextor er kvalitet vil det alltid bli slitasje på det mekaniske drivverket..
har du endret noe på pcen konfigurasjoner osv.?
når skjedde dette første gangen?
innstillinger i nero?
Vel det begynte ca 1 mnd etter at jeg hadde kjøpt den og da ble det så ille at jeg måtte formatere maskinen min, det som var problemet da var også det at maskinen låser seg hele tiden når f.eks skjermbeskytteren har stått på, må da restarte hele maskinen.Da den var ferdig formatert så var den helt lik, men nå har ikke maskinen låst seg så mye da.
