[LØST]trenger hjelp med et template system
Jeg fant en tutorial om å lage et template system, jeg modifiserte den litt så jeg kunne lage en function og sette eks. {server_status} på html filen og der ville denne vise.
Problemet er nå at {server_status} kommer helt øverst på siden ikke der jeg vil ha den dette skjedde ikke før jeg modifiserte. Jeg endret "REDTEXT" => server_status()) i information.php før var det "REDTEXT" => '<font color="red">Red text!</font>' )
class_template.php
<?php
/*    Begin the class    */
class tplSys
   var $loci = array();
   /*    Holds the html template    */
   var $tpl_htmlcode = array();
   /*    Holds variable references    */
   var $tpl_dirtycode = array();
   /*    Holds compiled and clean code    */
   var $tpl_cleancode = array();
   function tplSys($root)
       /*    Constructor, sets tpl and cache directories    */
       if( empty( $root ) )
           die("tplSys(): No root directory set.");
       if( !is_dir( $root ) )
           die("tplSys(): $root Directory doesn't exist.");
       $this->loci['root'] = $root;
       $this->loci['cache'] = $root . 'cache/';
   /*    Grabs file from directory and loads
       all the code into _dirtycode array    */
   function getFile($file_array)
       if( !is_array($file_array) )
           die("getFile(): $file_array not an array.");
       foreach( $file_array as $ref=>$filename )
           $fileref = $this->loci['root'] . $filename;
           $this->tpl_htmlcode[$ref] = implode( "", @file($fileref) );
   /*    Define references inside the HTML file    */
   function varRef( $handle, $refArray )
       if( !is_array($refArray) )
           die("varRef(): $refArray is not an array.");
       if( empty($handle) )
           die("varRef(): $handle was empty.");
       if( !empty( $this->tpl_htmlcode[$handle] ) )
           /*    Code exists, create references    */
           foreach( $refArray as $ref=>$replace )
               $this->tpl_dirtycode['{' . $ref . '}'] = $replace;
       else
           die("varRef(): Template data for $handle didn't exist.");
   /*    Parses dynamic code and prints it to the browser    */
   function parseDynamic( $handle )
       if( empty( $handle ) )
           die("parseDynamic(): $handle was empty.");
           $this->tpl_cleancode[$handle] = $this->compile( $handle );
           eval( $this->tpl_cleancode[$handle] );
   function compile( $handle )
       if( empty( $this->tpl_htmlcode[$handle] ) )
           die("compile(): No code existed for $handle.");
           die("compile(): $handle was empty.");
       $code = $this->tpl_htmlcode[$handle];
       /*    Count and clean up the code for parsing    */
       $code = str_replace('\\', '\\\\', $code);
       $code = str_replace('\'', '\\\'', $code);
       $d_code = explode( "\n", $code );
       $line_count = sizeof( $d_code );
       /*    Loop through and add 'echo' and '\\n' to each line    */
       for( $x = 0; $x < $line_count; $x++ )
           foreach( $this->tpl_dirtycode as $varref=>$replace )
               if( preg_match( "/^(.*)" . $varref . "(.*)$/", $d_code[$x] ) )
                   $d_code[$x] = preg_replace( "/^(.*)" . $varref . "(.*)$/", "\\1" . $replace . "\\2", $d_code[$x] );
           /*    This is where the loop data and logic will be taken care of    */
           $d_code[$x] = 'echo \'' . $d_code[$x] . '\' . "\\n";';
       $code = implode("\n", $d_code);
       return $code;
/*    EOF    */
information.php
<?php include ("includes/config.php");
  include("functions.php");
/* testing    */
require("class_template.php");
$tplObj = new tplSys("./includes/theme");
   $tplObj->getFile( array(
       'test' => '/information.html' )
   $tplObj->varRef( "test", array(
   $tplObj->parseDynamic("test");
functions.php
<?php
function server_status() {
$STATUS = fsockopen($REALMLIST, 3724, $errno, $errstr, 2);
 if (!$STATUS) {
 echo "<img src='gfx/off.png' alt=''>";
 } else {
 echo "<img src='gfx/on.png' alt=''>";
 fclose(!$STATUS);
Endret av kylefj
  • 1 år senere...
