Dette må være falske DVD+R Yuden plater!?
Intenso DVD+R 8x plater kjøpt i spindel på Datakjeden... fikk meg en overraskelse da jeg kjørte DVD-Identifier!
Kan vel ikke stemme...??
Hvis ikke drar jeg strake veien for å lagre opp flere;)
** INFO : Hex Dump Of 'Media Code'-Block Listed Below
** INFO : 4-Byte Header Preceding 'Media Code'-Block Discarded
** INFO : Format 11h (Method 1) - ADIP Information
0000 : a1 0f 02 00 00 03 00 00 00 26 05 3f 00 00 00 00 .........&.?....
0010 : 00 00 03 59 55 44 45 4e 30 30 30 54 30 32 00 38 ...YUDEN000T02.8
0020 : 23 54 37 10 02 4e 72 02 8c 63 16 16 0b 0b 0a 0a #T7..Nr..c......
0030 : 01 19 1b 0c 0c 0c 0d 01 00 00 00 00 00 00 00 00 ................
0040 : 01 00 38 38 02 34 63 13 05 22 22 10 0e 12 12 01 ..88.4c.."".....
0050 : 00 00 02 34 63 13 05 22 22 10 0e 12 12 01 00 00 ...4c.."".......
0060 : 02 00 54 70 02 4e 64 4a 20 11 08 08 01 18 00 00 ..Tp.NdJ .......
0070 : 00 00 02 67 64 4e 20 10 08 08 01 18 00 00 00 30 ...gdN ........0
0080 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00a0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00b0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00c0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00d0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00e0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00f0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
** INFO : An Empty Writable Disc Is Recommended For Accurate Results
** INFO : Drive = _NEC DVD_RW ND-3500AG [FW 2.16]
** INFO : Write Capabilities = DVD+R DVD+R-DL DVD+RW DVD-R DVD-RW
** INFO : Disc = [DVD+R:YUDEN000-T02-000]
** INFO : Write Speeds (Supported By This Drive On This Disc) Listed Below
** INFO : GET PERFORMANCE Write Speed Descriptor(s)
Descriptor #1 = 22160 KBPS (16.00x) - [CLV/Non-Pure CAV]
Descriptor #2 = 16620 KBPS (12.00x) - [CLV/Non-Pure CAV]
Descriptor #3 = 11080 KBPS ( 8.00x) - [CLV/Non-Pure CAV]
Descriptor #4 = 8310 KBPS ( 6.00x) - [CLV/Non-Pure CAV]
Descriptor #5 = 5540 KBPS ( 4.00x) - [CLV/Non-Pure CAV]
Descriptor #6 = 3324 KBPS ( 2.40x) - [CLV/Non-Pure CAV]
** INFO : MODE SENSE Write Speed Descriptor(s) [Legacy Command]
Descriptor #1 = 8467 KBPS ( 6.00x) - [CLV/Non-Pure CAV]
Descriptor #2 = 7056 KBPS ( 5.09x) - [CLV/Non-Pure CAV] - [invalid Entry]
Descriptor #3 = 5645 KBPS ( 4.00x) - [CLV/Non-Pure CAV]
Descriptor #4 = 4234 KBPS ( 3.06x) - [CLV/Non-Pure CAV] - [invalid Entry]
Descriptor #5 = 2822 KBPS ( 2.04x) - [CLV/Non-Pure CAV] - [invalid Entry]
Descriptor #6 = 1411 KBPS ( 1.00x) - [CLV/Non-Pure CAV]
** WARNING : Drive May Have Returned Incorrect Descriptors
Endret av The Terminator
