Motorhispania rx 50 security switch?
ÖzzY
IMPORTANT:
When starting the engine you must take into account:
-The contact key is in the adequate position (ON position)
-The lateral support is totally folded the frame, if not the security switch in it, will prevent the starting.
Lateral support = støtta ?
Betyr dette at hvis støtta er nede så vil ikke mopeden starte?
