Sony hd5 volum
1. Be in playback mode (playing a tune)
2. Press stop.
3. Straight away, flick the 'hold' button on the top of the player.
4. Hold the Search/Menu button down and enter the following combination of buttons in quick succession:
RIGHT RIGHT LEFT LEFT RIGHT LEFT RIGHT LEFT UP DOWN
5. Stop pressing the Search / Menu button and flick off the 'hold' switch. The backlight will turn off and the display will say "POWER". This means you are in the service menu.
6. Press UP until you get to "OTHER".
7. Press RIGHT until you get to "G TEST".
8. Press UP until you get to "SP SET".
9. Press PLAY button. If the display says "OFF", you have a non-EU player and the limiter is not in place. If it says "ON", the volume is limited.
10. Press the Search/Mode button so that the display shows "OFF".
11. Press the PLAY button to store the new setting. Now the display should say "SP SET".
12) Hold down the Stop button until the unit performs a normal startup and displays the WALKMAN logo. Go to the normal options screen and switch the backlight back on.
