Nintendos revolusjon er avslørt (Rev)
Var en post på IGN sitt insider board angående en hardcore fps spiller som hadde prøvd Rev kontrolleren :
Not me:
"So what did you play?
I played the Retro-fitted version of Metroid Prime 2: Echoes.
And ...?
It played far better than the original controls. Turning and aiming were instantaneous. Control was absolutely precise.
At a certain point during the demo, one of our designers did a double-jump over a gap and spun a full 180 degrees in midair before landing on the opposite side. When I saw this my arm literally started shaking and had to grab and squeeze the cup holder on my theater seat like Doctor Strangelove to hold my arm steady.
Then he circle-strafed around a Space Pirate.
Yes, circle-strafed.
In Metroid Prime 2.
And that's without target-locking.
How were the controls set up?
It was set up in the "nunchaku" configuration described in the article. On the left controller, the thumbstick controlled player movement, the upper trigger button was assigned to visor-switching, and the lower trigger was assigned to the "scan" function and locking onto a target. On the right controller, the controller itself moved the player's gun independently of the player's view (yes, you could fire at any point on the screen without changing the player view -- the gun tilted to face toward the aim point), the trigger button fired the gun, and three of the buttons controlled jumping, firing missiles, and switching to morphball mode.
How does it compare to a mouse?
From what I experienced, it seemed to be more precise than a mouse, but it's also much faster because it requires only a much smaller movement of the hand to achieve the desired effect. You just instantly point the controller at any part of the screen and bam!, that's where you're looking.
There is no lag.
There is no error.
It took a while to get used to the idea of how little effort is required to play a game with this controller. I kept wanting to lean forward and move the controller closer to the screen, and it took some practice to just sit back and just calmly move my hand ever so slightly.
At one point, someone said, "If you were to play a game with this against someone using a mouse, they'd have no chance against you." I had to admit it was true.
I've been using a mouse and keyboard for gaming for almost as long as I've been a gamer. I've logged over 80 hours so far in Battlefield 2 and I have a level 60 World of WarCraft character. If somebody had tried to tell me before now that a better controller would come along, I would have laughed at them.
But it only took me 5 minutes with the Revolution controller to realize that I don't need to use a mouse ever again.
Let's take a first-person shooter as an example. With a flick of the wrist, you can completely change your aim point from one corner of the screen to the other. Changing your aim point that way would require you to move a mouse all the way across a gamepad and could potentially take up to several seconds of pushing on a thumbstick with a standard console game controller.
Add to that the fact that the controller can correctly interpret roll (rotation of the controller clockwise and counterclockwise) and movement toward the screen or away from it, and you start to get an idea of the universe of new gameplay possibilities that Revolution games will be able to explore.
Gizzard: I would worry that if its in any way sloppily implemented, it will suck bigtime.
No worries in that category. If there was any sloppiness whatsoever, I didn't see it.
I do not expect to be using any other controllers ever again once the Revolution comes out.
The Angriest Smurf: This is cool as a novelty, but how does this lend itself to extended play sessions?
Try it yourself. Then see if you can still call it a novelty.
Trust me, I was very skeptical going into this. That skepticism is gone.
The Angriest Smurf: Could you imagine playing an FPS for over an hour with this without your hands getting tired?
Hell yeah, brother.
I often play Battlefield 2 for up to 3-4 hours in an evening (yes, I'm an addict), and after 10 minutes with the Revolution I'm ready to throw my mouse out the window for good.
When you take into account that the Revolution controller is very light (it seemed to me a bit lighter than I'd expect a TV remote of the same size) and that it's basically effortless to play with it, extended play sessions are a non-issue.
EvaUnit02: My concern is with playing today's standard genres of games. How do I play a racing game? Do I spin the controller around like a steering wheel?
That would be one way to do it.
Given the number of buttons available in the "nunchaku" configuration, combined with the tilt/rotate/push/pull aspects of the controller, I can't think of a game you couldn't easily adapt to the Revolution controller.
EvaUnit02: It's just not going to work.
I have played it. It works brilliantly."
Så tror de har implementert teknologien "temmelig" bra ;)
Godt poeng... men de burde ha ett annet alternativ...
Folk med sykdommer og problemer med bevegelse kan jo ikke spille med denne kontrollen...
De har et annet alternativ. Men det betyr ikke at de fleste ikke kan bruke denne kontrolleren som den er ment, og få mer ut av det.
Veldig interessant innlegg, AciD18!
Off, jeg hadde forventa meg noe bedre enn dette her ja, nå skal jeg hvertfall ikke ha Nintendo Revulution :no:
Du forventet deg noe annet.... derfor skuffelsen ;)
Anbefaler at du leser litt om den og ser filmen for å få et bedre bilde av den. Det er visstnok en kontroll du må prøve for å skjønne.
Morsomt med de som synes det er rart med Rev-kontrolleren... Vi har jo allerede et lignende redskap for PC: Mus!
Hvis du har problemer med å bruke en vanlig PC-mus så er du nok uheldig nok til at du vil ha problemer med Revolution.
Men da er du nok i et mindretall uansett :)
Men det store spørsmålet (som vi alle lurer på) er vel egentlig om det faktisk går an å bruke denne kontrolleren som en nunchaku i sin rette forstand? Både i demonstrasjons øyemed og i faktiske slåssituasjoner? DA vil det jo virkelig være en revolusjon innenfor sjangeren!
Endret av Vice
Jeg lurer på om Revolution blir stående i "stands" rundt omkring på Spaceworld, Elkjøp og alle andre kjeder, slik som dagens konsoller gjør. Ser for meg mye uheldig veiving med "stikka" i starten. :p
Men for all del, dette er en revolusjon, og jeg gleder meg ekstremt til å faktisk prøve denne. Nå må vi heller ikke glemme at Nintendo lover at NES/SNES(osv)-spill skal være fullt nedlastbare fra internett!
Blant tingene du kan koble til kontrolleren, er en klassisk kontroller som gjør at du kan spille gamle Nintendo-spill, og en «nunchako»-dings som du kan styre med i spillene mens du veiver rundt med hovedkontrolleren.
Jeg gleder meg ihvertfall. :)
kan jo bli stress å spille noen timer i strekk, vist en ikke finner en måte og holde den i fanget på og kan justere følsomheten
Leste et intervju der han sa at den var veldig følelsom, og at dedet ikke er noe problemer med å hvile hendene i fanget.
Men da mister det jo litt av poenget syns da jeg ;) Liker å bevege meg mens jeg spiller. Alla DDR. At jeg blir sliten og trenger en dush etter en lang spillesesjon har jeg bare godt av ;)
hehe, ja det er jo en ting, har ikke lest noe om den før, men fikk bare ett lite intrykk av at en kunne bli veldig statisk sliten, men de har vel tenkt gjennom det både en og to ganger før de lanserte det :)
