Hva betyr OEM?
DJMartin
http://www.webopedia.com/TERM/O/OEM.html
Short for original equipment manufacturer, which is a misleading term for a company that has a special relationship with computer producers. OEMs buy computers in bulk and customize them for a particular application. They then sell the customized computer under their own name. The term is really a misnomer because OEMs are not the original manufacturers -- they are the customizers.
OEM står for Original Equipment Manufacturer
Det bestyr at du kjøper programwaren sammen med en hardware komponent som er relevant til programwaren. Derfor blir det ofte billigere å kjøpe det. Men ingen forskjell elers som regel.
men når jeg skal kjøpe en OEM versjon må jeg da kjøpe et hardware ved siden av?
