"Den store Photoshop" tråden
Fra Smashing Magazine/Tom Giannattasio:
10. Cloak of Invisibility
Remove everything from the screen except for your file.
F, F, F | Cycle through Screen Modes
Tab | Remove Tools and Palettes
Ctrl+H | Hide Extras (Grid, Guides, Slices, etc.)
Ctrl+R | Hide Rulers
9. Quick Brush Jab
Quickly and easily customize a brush. This combo is a staple for digital painting.
B | Brush Tool
Right-Click and Select or F5 and Select | Open condensed or full Brush Palette
or . or , or Shift+. or Shift+, | Cycle through brushes or jump to first or last brush
[ or ]: | Shrink or enlarge brush radius
Shift+[ or Shift+] | Decrease or increase brush hardness
{Numeric Input} | Change brush opacity (e.g. ‘5′ = 50%, ‘55′ = 55%)
8. Quick Brush Jab Path Stroke
Stroke a path with a customized brush.
{Draw Path} | Use any tool to draw a path
B | Select Brush Tool
Quick Brush Jab | Use the Quick Brush Jab Combo to customize brush
Enter | Stroke the path with your customized brush
7. Gaussian Attack
Apply a filter, fade it and apply again. Good combo for fine-tweaking filters.
{Apply a Filter} | Manually choose and apply a filter (warning: using the Lens Flare filter may result in a swift kick to the mouse balls)
Ctrl+Shift+F | Fade the filter
(Ctrl+F or Ctrl+Shift+F) | Reapply filter with or without dialog box
6. Shadow Maker
Create a basic shadow based on a chosen layer.
{Select Layer} | Select the layer the shadow will be created after. The transparency of this layer needs to resemble the desired shape of the shadow.
Ctrl+J | Layer via Copy
Ctrl+[ | Move layer down
D | Reset color defaults
Alt+Shift+Backspace | Fill with black and preserve transparency
Ctrl+T | Free transform
{Transform} | Modify to your liking
Enter | Commit
5. Layer Catcher
Select, group and mask layers. Often easier than using the layers palette.
V | Selection Tool
Ctrl+Click or Ctrl+Shift+Click or Ctrl+Shift+Right-Click | Select your layers
Ctrl+G | Group Layers
4. OCD Layer Sort
Rearrange your layers quickly and easily. Great cure for you neuroticism.
F7 | Show Layer Palette
Alt+[ or Alt+] or Alt+, or Alt+. | Select a layer
Shift+Alt+[ or Shift+Alt+] or Shift+Alt+, or Shift+Alt+. | Select more layers
Ctrl+[ or Ctrl+] or Shift+Ctrl+[ or Shift+Control+] | Move layers down or up or send to bottom or bring to top
3. Ultimate Flattener
Merge All Layers (even those hidden). Quick way to flatten a file.
Alt+. | Select Top Layer
Shift+Alt+, | Select all layers between currently selected and bottom layer
Ctrl+E | Merge the selected layers
2. Infinite Dupe
Duplicate and evenly distribute or transform items. Nice way to distribute something like nav buttons.
Ctrl+T | Transform
{Transform/Move} | Manually Move or Transform
Enter | Commit Transform
(Ctrl+Alt+Shift+T) | Duplicate and transform relative to the newest item
1. Finishing Move - The Web Extractor
Extract a selection and save it for the web. Extremely useful when pulling individual elements from a design, such as buttons or rules.
{Create Selection} | Select the area you want to extract
Ctrl+Shift+C | Copy Merged to clipboard
Ctrl+N | Create New Image based on selection size
Enter | Confirm New Image
Ctrl+V | Paste from clipboard
Ctrl+Alt+Shift+S | Save for the Web
Endret av KristofferB
Du kan få samme resultatene i mspaint som du får i photoshop, bare du gidder å træle lenge nok.
Det er bedre å spise suppe med skje (Photoshop) enn med gaffel (gimp) (paint blir vel som en tannpirker eller noe?), men det er langt enklere med skje.
Så det er altså ikke slik at gimp fungerer like bra som ps for nybegynnere?
haha, spise suppe med tannpirker, det blir nok noe enda mindre med ms paint ;)
Photoshop er enkelt og greit å begynne med syns jeg. Bare å følge noen kickass tutorials (www.tutvid.com kanskje..) også etter et par uker (kanskje mnder..:p) så har man teket på det.
Det var det jeg gjordet hvertfall, nå kan jeg si at jeg kan det meste i photoshop, eller.. jeg kan gjøre det meste i hvertfall. Og jeg startet med å ikke kunne noenting, se på tutorials, leke meg, oxo før du vet ordet av det så kan du plutselig photoshop
:D
for det første er all skyggen bak "kloden", noe som bare forsterker følelsen av at det er en disk og ikke en kuleform. I tillegg er skyggen for skarp.
Og hvorfor i all verden har du en skygge i det hele tatt?
Hva står kloden på?
Lens Flaren som heter "50 mm" er jo rød..?
I PS Elements hvertfall. Der har jeg 3 lens flares å velge mellom.
Så kan du jo bruke "replace color" på den grønne tingen, og gjøre den og rød.
Endret av toth
