New kid on the block Skrevet 10. september 2005 Del Skrevet 10. september 2005 To some this may be a stupid question, but as my name imply´s I dod´nt know nearly anough about computers and computer realated topics to be shopping for my own one. Anyway my question is, how much ram and vram is ressesery for modren day, extreme, out of this world, to thr bone, flat out the best, hardcore gaming ever? PS. Sorry about my overexplaing of the gaming type, and i realy only need anough for modren exreme gaming. PS2. Sorry about the english, I just feel that I can´t live up to my full potential as a "forum poster" in norwegian. PS3. Holy#$/&=, realy sorry about the 3 PS´s Lenke til kommentar
Complexity Skrevet 11. september 2005 Del Skrevet 11. september 2005 hææ? what??.. snakk ordentlig engelsk da iallefall Lenke til kommentar
endrebjo Skrevet 11. september 2005 Del Skrevet 11. september 2005 [*trenepåengelsk*] For internet-/mail-/word-use, 512 MB is considered as a minimum of system RAM. Most of todays gaming-machines has at least 1024 MB (1GB) of system RAM, but for serious hardcore gaming (like you describe), 2048 MB (2GB) would be enough. Two RAM-modules of 1 GB each is recommended for a total of 2 GB. Four modules of 512 MB may create some unnecessary problems. You do not need more than 256 MB of vRAM. It is better to buy a powerful graphic card (with 128-256 MB vRAM) than a slow graphic card with much memory (256-512 MB vRAM). [/*trenepåengelsk*] Lenke til kommentar
Klekkus Skrevet 11. september 2005 Del Skrevet 11. september 2005 [*trenepåengelsk*]For internet-/mail-/word-use, 512 MB is considered as a minimum of system RAM. It's no problem to use 256 mb there, i had it on my last computer. i could run bf1942 Lenke til kommentar
New kid on the block Skrevet 11. september 2005 Forfatter Del Skrevet 11. september 2005 Well thanks for the info lads, I realy appreciate it. And man you guys are fast!! But with regards to my written english, when your ragging down on it keep in mind that i wrote it when; 01:48 AM. To you nocturnal comptuer geeks this may not be a problem, but to the rest of us english grammer is hard past midnight. Anyways thanks a bunch Endrebjorsvik89 1x 1 Gb 2x 512 Mg This would work fine, rite?? Lenke til kommentar
endrebjo Skrevet 11. september 2005 Del Skrevet 11. september 2005 [*trenepåengelsk*]For internet-/mail-/word-use, 512 MB is considered as a minimum of system RAM. It's no problem to use 256 mb there, i had it on my last computer. i could run bf1942 I had 192 MB until last winter. It worked fine when I ran only two or three applications (for instance Firefox, WinAMP and MSN (+ antivirus, firewall and so on)), but my hard drive made a hell of a noise, and now and then, the system got tremendously irresponsive. If I in addition ran LimeWire and Outlook Express, the system was like syrup. After I had upgraded to 448 MB, I could run almost as many applications as I wished. Lenke til kommentar
Brusfantomet Skrevet 11. september 2005 Del Skrevet 11. september 2005 1x 1 Gb2x 512 Mg This would work fine, rite?? It would work in single channel, butt most probably not in dual channel (in dual channel the to "pools" of dimms must be of equal size) Sorry about my crappy spelling Lenke til kommentar
endrebjo Skrevet 12. september 2005 Del Skrevet 12. september 2005 1x 1 Gb2x 512 Mg 1x 1 GB OR 2x 512 MB or, 1x 1 GB AND 2x 512 MB? Lenke til kommentar
New kid on the block Skrevet 12. september 2005 Forfatter Del Skrevet 12. september 2005 1x 1 Gb2x 512 Mg 1x 1 GB AND 2x 512 MB? So this would work?? And could you please tell me what is the differance between a "single" and "duel" channel in conection with RAM?? Lenke til kommentar
Bob Ibsen Skrevet 12. september 2005 Del Skrevet 12. september 2005 Single / dual channel is not about the RAM-sticks themselves, it's about the memory controller, and the size, number and configuration of the modules. Two or four equally sized sticks in the correct setup, will enable dualchannel. Each channel must see one or two sticks (in most cases). Using three modules will usually disable dualchannel Lenke til kommentar
xD^^ Skrevet 13. september 2005 Del Skrevet 13. september 2005 Off Topic: One question, why are you speaking english here, and norwegian here?: http://forum.hardware.no/index.php?showtopic=469488 Lenke til kommentar
New kid on the block Skrevet 13. september 2005 Forfatter Del Skrevet 13. september 2005 Why are you speaking english here, and norwegian here?: Sorry for this "cocky" answer, but why not? I´m bilingual, and so are you, be proud of that Lenke til kommentar
Amo Aka Eagle Skrevet 14. september 2005 Del Skrevet 14. september 2005 (endret) LOL ---> do I have to say more? ble liksom vanskelig å forstå hva det egentlige problemet er når man sliter med å finne ut hva du prøver å si... hvis du hadde giddi å skrivd det på norsk kanskje jeg kan stå til hjelp *tok meg tid* for bra gaming ville jeg anbefalt 2048mb ram altså 2x1024 brikker i dual channel med lave timings, på så store brikker må man ut med litt for å få bra timings da. Endret 14. september 2005 av Amo Aka Eagle Lenke til kommentar
New kid on the block Skrevet 14. september 2005 Forfatter Del Skrevet 14. september 2005 på så store brikker må man ut med litt for å få bra timings da. Ok då så blir det norsk.... Bare lure, ka meine du med "ut med lit", og ka vili det si å ha "lav eller bra timings"?? Lenke til kommentar
Plukk Skrevet 14. september 2005 Del Skrevet 14. september 2005 Ut med litt = Bruke litt penger Lav timings= Rask tilgangstid= Bra timing (F.eks: 2-2-2-5 er bedre enn 3-3-3-8) Lenke til kommentar
Jarmo Skrevet 14. september 2005 Del Skrevet 14. september 2005 på så store brikker må man ut med litt for å få bra timings da. Ok då så blir det norsk.... Bare lure, ka meine du med "ut med lit", og ka vili det si å ha "lav eller bra timings"?? Hehe ! gå over til engelsk igjen, det kan du bedre enn norsk så det så.... Lenke til kommentar
New kid on the block Skrevet 15. september 2005 Forfatter Del Skrevet 15. september 2005 på så store brikker må man ut med litt for å få bra timings da. Ok då så blir det norsk.... Bare lure, ka meine du med "ut med lit", og ka vili det si å ha "lav eller bra timings"?? Hehe ! gå over til engelsk igjen, det kan du bedre enn norsk så det så.... Sorry if you østlendings (just guessing østlandet) can´t understand sophisticated vestlands slang. Lenke til kommentar
endrebjo Skrevet 15. september 2005 Del Skrevet 15. september 2005 (endret) på så store brikker må man ut med litt for å få bra timings da. Ok då så blir det norsk.... Bare lure, ka meine du med "ut med lit", og ka vili det si å ha "lav eller bra timings"?? Hehe ! gå over til engelsk igjen, det kan du bedre enn norsk så det så.... Sorry if you østlendings (just guessing østlandet) can´t understand sophisticated vestlands slang. I Norge skriver man enten nynorsk eller bokmål. Ikke sognamaol. Endret 15. september 2005 av endrebjorsvik89 Lenke til kommentar
