AtomChip® SG220-2 (Hoax?)
frakk2000
Har fått tilsendt denne linken fra noen jeg kjenner: Atom Nanochips
Og det lukter litt hoax av den.
Bare hør på specs'ene:
Processor: 6.8GHZ CPU(!! (AtomChip® Quantum® II processor or 4 x Intel® Pentium® M processors 1.7CHz)
System Compliance: Two Operating Systems with Voice Command (Microsoft® Windows® XP Professional and Linux®)
Memory: 1TB Quantum-Optical non-volatile RAM (NvIOpSRAM-SODIMM 200-pin)
Storage: 2TB non-volatile Quantum RAM (NvIOpRAM-ATA IDE)
Optical Drive: DVD Super Multi
LCD Display: 12.1” WXGA (1280 x 800, 16:10) TFT Glare Type LCD display with 1.3 Mega pixel CMOS camera
Video & Graphics: Two Integrated graphic controllers [intel®855GME internal graphics, support Intel® DVMT (Dynamic Video Memory Technology) and AtomChip® DVM (Dynamic Video Memory)]
++ masse mer
Communication: 10/100 Base-T LAN on board, MDC Fax/Modem V.90/V.92 on Board, 802.11a/802.11b/802.11g WLAN, Intel® PRO/Wireless 2100/2200BG/2915ABG network connection, WiFi, Bluetoth, GPRS -with Bluetoth antena, CMOS camera with USB interface, Mega pixel resolution CMOS image / Pointing Device: Synaptics touchpad with 4 way scrolling button / Application Launch Key: E-mail, Internet, Capture, WLAN / LED Status Indicator: Power, Suspend/Resume, Battery Charging Status, Quantum Storage Access, Num Lock mode, Caps Lock mode, Scroll Lock mode, WLAN Lock mode / Keyboard: 3.0mm travel, inverted-T, 88keys with 2 windows key (Internet & Microsoft For Connectivity) / Interface Ports Front Side: One 4-in-1 card reader slot (support SDIO/SD/MS Pro/MS), Audio line out, Stereo Microphone-in / Interface Ports Left Side: LAN port, Modem port, SVGA–out port, One Type II PCMCIA slot (support CardBus), 1394A port (mini jack) / Interface Ports Right Side: USB 2.0 ports x 3 / Interface Port Rear Side: DC-in, Kensington Lock / Audio: Built-in two stereo speakers and Built-in Microphone / AC Adapter (Input: 100-240V AC, 50-60Hz, 1.5A. Output: 20V DC, 2.5A, 50W) / Battery: 6 cell Li-lon battery pack. Battery Charge: 3 hrs charge time to 100% capacity w
hile system off and 4 hrs charge time while system on. Battery Life: Approximately 8 hours for AtomChip® Quantum® II processor and 3 hours for 4 x Intel® Pentium® M processors 1.7CHz / BIOS: AMI, Support PnP, password, Bootable from USB and DVD / Power Management: ACPI 2.0 compliance / Smart Battery System Support / Security: Kensington Lock / Size: 320.0(W) x 242.0(D) x 22.0(H)mm/28.0mm (front/back) / Weight: 1.9kg(when fully equipped with AtomChip® Quantum® II processor) and 2,20kg(when fully equipped with 4 x Intel® Pentium® M processors) / Packing Accessories: Quick Guide, Support CD (Driver, Utility, Manual), AC Adapter, Power Cord, Battery Pack, BOSE Headphone Music System with noise Cancelling.
Synes det høres litt sykt ut?
Bruker visstnok optikk for å sende rundt informasjon, istedet for kopperledere?
Hva mener dere?
Endret av frakk2000
Hørte faktisk om at lys kom til å bli brukt til prosessing for ett år siden, kanskje litt lenger. Tror det var israelske forskere som hadde pønsket ut noe smart. Men jeg TVILER på at de har kommet så langt på kort tid, og at du også kan bruke Intel prosessor... Det høres ikke rett ut for meg. Gret nok at Microbølgeovnen kom på markedet ufattelig kort tid etter at den ble oppdaget, men dette tror jeg bare ikke noe på. legger med noen linker uansett, så kan du/dere lese om "Prosessor med lysets hastighet", som ITavisen sier det så pent:)
http://www.itavisen.no/showArticle.php?articleId=1302200
http://www.lenslet.com/newsItem.asp?showArchive=&newsId=184
EDIT: ser man det! 2 år siden altså. Tiden går fort:)
Endret av capy
Les
Bli rik på 10 enkle steg
1. Tenk ut noe utrolig, men ikke mer utrolig enn at folk ville kjøpe det hvis det kunne la seg gjøre.
2. Søk amerikansk patent. US Patent & Trademark Office vurderer ikke om patentet virker, de ser bare om ideen er kjent fra før og hvis ikke stempler de OK på den.
3. Lur godtroende journalister til å skrive om det. Mistroiske artikler hjelper også, medieomtale er sin egen rettferdiggjørelse.
4. Hype, hype, hype.
5. Foreta aksjeemisjon.
6. Hype, hype, hype.
7. Rekrutter flere journalister. Nå er det lett, aksjen går jo oppover så det må være noe i det?
8. Hype, hype, hype.
9. Selg dine nå sinnsvakt verdifulle aksjer.
10. Gå under jorda og lev et liv i sus og dus.
Kommentar fra en leser på digi.no
Det første som ga meg et clue til at det var noe totalt feil var at Quantum II hadde samme skrifttype som brukes på Pentium II, og her var løsningen. Den bærbare er en Pentium II maskin som er kassert og man da kan "leke" litt med.
Så kommer vi til neste punkt, nemlig klistremerket på den bærbare, den har nemlig ett "Designed for Windows" merke, og Quantum merket er et hvitt merke klistret over "Pentium II" merkene.
Når man ser på bildene av selve Quantum "diskene", så ser man ved ettersyn at de har en annen skarphet og er et klistremerke som er satt over på et gammelt komponent.
Neste avslørende punkt er at den slot som "disken" er satt inn i er i en Ram slot og at det er satt inn i floppy disk bayen.
Deretter ser man tydelig et bilde hvor det vises en Ami Bios fra 1999 med versjonsnummer 535, til produsent BB19 som er en BIOS laget for bruk på AMD K6-2 Maskiner, noe som stemmer overens med formen på prosessoren vi såvidt kan skimte under all "dekoren".
Neste punkt er at det på bunnen av den bærbare er både CE merker, såvel som FCC merke, noe som er totalt merkelig da Quantum aldri har levert noen produkter inn for godkjenning.
Orker ikke en gang å kommentere de flotte bildene av deres optiske løsninger som er så dårlige eksperimenter med Phonoplugger og utklipte komponentdeler at det ikke en gang er verd kommentar.
