Repriser - Mulig å kjøre repriser?
borchgrevink
Vil du ikke kunne faa til dette med timeshifting software da, slik som PowerVCR II eller lignende? eller helt uten PC ved hjelp av harddisk recordere? De kan man gjerne gaa tilbake i tid paa eller pause o.l.
"With PowerVCR II's Instant Replay feature, you can pause, and rewind live television, as well as watch in slow motion, and view instant replays. So, if you are watching your favorite TV program and the phone rings, you can just hit the "Pause" button and freeze the action for a period of time, and then pick up right where you left off. Or if you are watching a basketball game and you just saw an amazing play, you can rewind back and watch it over again (several times if you wish). When you are finished just fastforward to catch up to the live TV broadcast.
Note: Instant TV Replay is different from Time Shifting in that you don't need to record the program to use this feature. Just watch the TV program in Instant Replay mode."
PowerVCR
Per Christian
