unexpected T_STRING? [LØST] NYTT PROBLEM. [LØST]
Hva menes med unexpected T_STRING?
edit: her er filen som feilen sto i, det var LINJE 28.
<?php
include('config.php');
// Connect to MySQL
mysql_connect($mySQLhost, $mySQLuser, $mySQLpass);
mysql_select_db($mySQLdb);
// Get data from form
$name = $_POST['name'];
$email = $_POST['email'];
$tlf = $_POST['tlf'];
// Check that none of the fields are empty
if(empty($name)) {
echo "Du må fylle ut hele navnet ditt.";
elseif(empty($tlf)) {
echo 'Du må fylle ut e-postadressen din.';
else {
// Remove HTML-tags and unnecessary spaces
$name = rtrim(ltrim(strip_tags($name)));
$email = rtrim(ltrim(strip_tags($email)));
$tlf = rtrim(ltrim(strip_tags($tlf)));
// Insert the data into the database
if(@mysql_query("INSERT INTO `"fest"` (`name`, `email`, `tlf`) VALUES ('$name', '$email', '$tlf'))
 echo $regSuccess;
else {
 echo $regFailed;
mysql_close();
echo '<p><a href="list.php">Vis liste over påmeldte</a></p>';
Ser dere noe feil?
Endret av BigJackW
Den er helt fucka.
<?php
// Connect to MySQL
if(empty($name)) {
else {
if(@mysql_query("INSERT INTO `"fest"` (`name`, `email`, `tlf`) VALUES ('$name', '$email', '$tlf')")
 echo $regSuccess;
else {
 echo $regFailed;
mysql_close();
Har du msn?
Parse error: parse error, unexpected T_LIST in /web/www/frac/users/vegtor/reg.php on line 38
