problemer med cpufreq Gentoo
Grom
Jeg prøver å få aktivert speedstep på Laptopen min.
Har installert cpufreq, men når jeg kjører cpufreq-info får jeg kun opp følgende:
# cpufreq-info
cpufrequtils 0.3: cpufreq-info (C) Dominik Brodowski 2004
Report errors and bugs to [email protected], please.
analyzing CPU 0:
 no or unknown cpufreq driver is active on this CPU
CPU = Pentium M Dothan 1.7Ghz.
Huska du å ta med støtte for den i kernelen?
hvis du roter i dmesg, skal du finne noe àlà
powernow-k8: Found 1 AMD Athlon 64 / Opteron processors (version 1.50.3)
powernow-k8:    0 : fid 0x0 (800 MHz), vid 0xa (1300 mV)
powernow-k8:    1 : fid 0xa (1800 MHz), vid 0x6 (1400 mV)
powernow-k8:    2 : fid 0xc (2000 MHz), vid 0x2 (1500 mV)
cpu_init done, current fid 0xc, vid 0x0
powernow-k8: ph2 null fid transition 0xc
Bare med intel stuff da ;)
For ordens skyld, her er cpufreq-infoen min:
Calculus ~ # cpufreq-info
analyzing CPU 0:
 driver: powernow-k8
 CPUs which need to switch frequency at the same time: 0
 hardware limits: 800 MHz - 2.00 GHz
 available frequency steps: 800 MHz, 1.80 GHz, 2.00 GHz
 available cpufreq governors: ondemand, userspace, performance
 current policy: frequency should be within 800 MHz and 2.00 GHz.
                 The governor "ondemand" may decide which speed to use
                 within this range.
 current CPU frequency is 800 MHz (asserted by call to hardware).
Endret av Klette
finner følgende i dmesg:
CPU: After generic identify, caps: afe9fbbf 00000000 00000000 00000000 00000180
00000000 00000000
CPU: After vendor identify, caps: afe9fbbf 00000000 00000000 00000000 00000180 0
0000000 00000000
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 2048K
CPU: After all inits, caps: afe9fbbf 00000000 00000000 00000040 00000180 0000000
0 00000000
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
ACPI: setting ELCR to 0200 (from 0c00)
CPU0: Intel(R) Pentium(R) M processor 1.70GHz stepping 06
SMP motherboard not detected.
Brought up 1 CPUs
CPU0 attaching sched-domain:
domain 0: span 01
 groups: 01
 domain 1: span 01
  groups: 01
Har du kompilert kernel med støtte for Dothans ACPI-tabeller?
HVordan gjør jeg dette? Finner ikke noen valg for dette når jeg kjører make menuconfig. Kjører kernel 2.6.12.
Denne er fin :)
Har prøvd å følge den guiden til punkt og prikke, men funker fortsatt ikke :no: .
Det er den jeg har fulgt, og jeg har Dothan 1.7GHz selv. Er du heeeeelt sikker på at du kryssa av for centrino driveren og de forskjellige governorene i kjerna?
Har krysset av for performance, powersave og ondemand governor.
CPU frequency table helpers finner jeg ikke noe sted.
Som CPU- driver har jeg krysset av Intel Enhanced SpeedStep .
Mulig denne som er feil?
Kompilerte senere kernelen v.hja. make i /usr/src/linux og reboota.
Her kan du se selv hva jeg har med. Men når du kompilerer kjerna, så kopierer du den til /boot og legger den til i grub ikke sant? Ikke bare rebooter?
[*] CPU Frequency scaling
<*>   CPU frequency translation statistics
Default CPUFreq governor (userspace)  --->
<*>   'performance' governor
<*>   'powersave' governor
<*>   'ondemand' cpufreq policy governor
<*>   'conservative' cpufreq governor
<*>   ACPI Processor P-States driver
<*>   Intel Enhanced SpeedStep
[*]     Use ACPI tables to decode valid frequency/voltage pairs
Men hvordan konfigurerer Grub?
Bær over med meg her, er relativt newbie når det gjelder Linux.
Åpne fila /boot/grub/grub.conf, og pass på at kjerna du har lagt i /boot er den som blir lasta fra grub. Ha gjerne den orginale i tillegg til den nye så du kan gå tilbake til noe du vet virker om noe går feil.
Kan f.eks se sånn ut:
default 0
timeout 6
splashimage=(hd0,0)/grub/splash.xpm.gz
title=Gentoo GNU/Linux - Ny
root (hd0,0)
kernel /boot/2.6.12-4 root=/dev/hda3
title=Gentoo GNU/Linux - Gammel
root (hd0,0)
kernel /boot/2.6.12-1 root=/dev/hda3
default 0
timeout 6
root (hd0,0)
root (hd0,0)
hmm..
Har faktisk ikke noen /boot/grub/gru.conf fil.
Det eneste /boot inneholder er System.map og bzImage
