Mer nøyaktig ping
C:\>ping www.vg.no
Pinger www.vg.no [193.69.165.21] med 32 byte data:
Svar fra 193.69.165.21: byte=32 tid=13ms TTL=247
Svar fra 193.69.165.21: byte=32 tid=12ms TTL=247
Svar fra 193.69.165.21: byte=32 tid=15ms TTL=247
Ping-statistikker for 193.69.165.21:
Pakker: sendt = 4, mottatt = 4, tapt = 0 (0% tap),
Gjennomsnittlig tid for tur-retur i millisekunder:
minimum = 12ms, maksimum = 15ms, gjennomsnittlig = 13ms
C:\>hrping www.vg.no
This is hrPING v2.26 by cFos Software GmbH -- http://www.cfos.de
Pinging www.vg.no [193.69.165.21]
with 64 bytes data (92 bytes IP):
Reply from 193.69.165.21: seq=0000 time=13.335ms TTL=247 ID=9edd
Reply from 193.69.165.21: seq=0001 time=12.437ms TTL=247 ID=9f27
Reply from 193.69.165.21: seq=0002 time=33.505ms TTL=247 ID=9faf
Reply from 193.69.165.21: seq=0003 time=13.248ms TTL=247 ID=9fed
Statistics for www.vg.no:
Packets: sent=4, rcvd=4, error=0, lost=0 (0% loss) in 1.513250 sec
RTTs of replies in ms: min/avg/max: 12.437 / 18.131 / 33.505
http://www.cfos.de/ping/ping.htm
