genstian Skrevet 3. september 2005 Del Skrevet 3. september 2005 Hei, driver og setter opp en apache vhost server med ssl men har problemer: det funker ikke! httpd.conf # # Based upon the NCSA server configuration files originally by Rob McCool. # # This is the main Apache server configuration file. It contains the # configuration directives that give the server its instructions. # See <URL:http://httpd.apache.org/docs-2.0/> for detailed information about # the directives. # # Do NOT simply read the instructions in here without understanding # what they do. They're here only as hints or reminders. If you are unsure # consult the online docs. You have been warned. # # The configuration directives are grouped into three basic sections: # 1. Directives that control the operation of the Apache server process as a # whole (the 'global environment'). # 2. Directives that define the parameters of the 'main' or 'default' server, # which responds to requests that aren't handled by a virtual host. # These directives also provide default values for the settings # of all virtual hosts. # 3. Settings for virtual hosts, which allow Web requests to be sent to # different IP addresses or hostnames and have them handled by the # same Apache server process. # # Configuration and logfile names: If the filenames you specify for many # of the server's control files begin with "/" (or "drive:/" for Win32), the # server will use that explicit path. If the filenames do *not* begin # with "/", the value of ServerRoot is prepended -- so "logs/foo.log" # with ServerRoot set to "/usr/local/apache2" will be interpreted by the # server as "/usr/local/apache2/logs/foo.log". # ### Section 1: Global Environment # # The directives in this section affect the overall operation of Apache, # such as the number of concurrent requests it can handle or where it # can find its configuration files. # # # ServerRoot: The top of the directory tree under which the server's # configuration, error, and log files are kept. # # NOTE! If you intend to place this on an NFS (or otherwise network) # mounted filesystem then please read the LockFile documentation (available # at <URL:http://httpd.apache.org/docs-2.0/mod/mpm_common.html#lockfile>); # you will save yourself a lot of trouble. # # Do NOT add a slash at the end of the directory path. # ServerRoot "/usr/local/apache2" # # The accept serialization lock file MUST BE STORED ON A LOCAL DISK. # <IfModule !mpm_winnt.c> <IfModule !mpm_netware.c> #LockFile logs/accept.lock </IfModule> </IfModule> # # ScoreBoardFile: File used to store internal server process information. # If unspecified (the default), the scoreboard will be stored in an # anonymous shared memory segment, and will be unavailable to third-party # applications. # If specified, ensure that no two invocations of Apache share the same # scoreboard file. The scoreboard file MUST BE STORED ON A LOCAL DISK. # <IfModule !mpm_netware.c> <IfModule !perchild.c> #ScoreBoardFile logs/apache_runtime_status </IfModule> </IfModule> # # PidFile: The file in which the server should record its process # identification number when it starts. # <IfModule !mpm_netware.c> PidFile logs/httpd.pid </IfModule> # # Timeout: The number of seconds before receives and sends time out. # Timeout 100 # # KeepAlive: Whether or not to allow persistent connections (more than # one request per connection). Set to "Off" to deactivate. # KeepAlive On # # MaxKeepAliveRequests: The maximum number of requests to allow # during a persistent connection. Set to 0 to allow an unlimited amount. # We recommend you leave this number high, for maximum performance. # MaxKeepAliveRequests 0 # # KeepAliveTimeout: Number of seconds to wait for the next request from the # same client on the same connection. # KeepAliveTimeout 15 ## ## Server-Pool Size Regulation (MPM specific) ## # prefork MPM # StartServers: number of server processes to start # MinSpareServers: minimum number of server processes which are kept spare # MaxSpareServers: maximum number of server processes which are kept spare # MaxClients: maximum number of server processes allowed to start # MaxRequestsPerChild: maximum number of requests a server process serves <IfModule prefork.c> StartServers 5 MinSpareServers 5 MaxSpareServers 10 MaxClients 150 MaxRequestsPerChild 0 </IfModule> # worker MPM # StartServers: initial number of server processes to start # MaxClients: maximum number of simultaneous client connections # MinSpareThreads: minimum number of worker threads which are kept spare # MaxSpareThreads: maximum number of worker threads which are kept spare # ThreadsPerChild: constant number of worker threads in each server process # MaxRequestsPerChild: maximum number of requests a server process serves <IfModule worker.c> StartServers 2 MaxClients 150 MinSpareThreads 25 MaxSpareThreads 75 ThreadsPerChild 25 MaxRequestsPerChild 0 </IfModule> # perchild MPM # NumServers: constant number of server processes # StartThreads: initial number of worker threads in each server process # MinSpareThreads: minimum number of worker threads which are kept spare # MaxSpareThreads: maximum number of worker threads which are kept spare # MaxThreadsPerChild: maximum number of worker threads in each server process # MaxRequestsPerChild: maximum number of connections per server process <IfModule perchild.c> NumServers 5 StartThreads 5 MinSpareThreads 5 MaxSpareThreads 10 MaxThreadsPerChild 20 MaxRequestsPerChild 0 </IfModule> # WinNT MPM # ThreadsPerChild: constant number of worker threads in the server process # MaxRequestsPerChild: maximum number of requests a server process serves <IfModule mpm_winnt.c> ThreadsPerChild 250 MaxRequestsPerChild 0 </IfModule> # BeOS MPM # StartThreads: how many threads do we initially spawn? # MaxClients: max number of threads we can have (1 thread == 1 client) # MaxRequestsPerThread: maximum number of requests each thread will process <IfModule beos.c> StartThreads 10 MaxClients 50 MaxRequestsPerThread 10000 </IfModule> # NetWare MPM # ThreadStackSize: Stack size allocated for each worker thread # StartThreads: Number of worker threads launched at server startup # MinSpareThreads: Minimum number of idle threads, to handle request spikes # MaxSpareThreads: Maximum number of idle threads # MaxThreads: Maximum number of worker threads alive at the same time # MaxRequestsPerChild: Maximum number of requests a thread serves. It is # recommended that the default value of 0 be set for this # directive on NetWare. This will allow the thread to # continue to service requests indefinitely. <IfModule mpm_netware.c> ThreadStackSize 65536 StartThreads 250 MinSpareThreads 25 MaxSpareThreads 250 MaxThreads 1000 MaxRequestsPerChild 0 MaxMemFree 100 </IfModule> # OS/2 MPM # StartServers: Number of server processes to maintain # MinSpareThreads: Minimum number of idle threads per process, # to handle request spikes # MaxSpareThreads: Maximum number of idle threads per process # MaxRequestsPerChild: Maximum number of connections per server process <IfModule mpmt_os2.c> StartServers 2 MinSpareThreads 5 MaxSpareThreads 10 MaxRequestsPerChild 0 </IfModule> Listen 80 Listen 443 <IfModule !mpm_winnt.c> <IfModule !mpm_netware.c> User nobody Group nobody </IfModule> </IfModule> ServerAdmin [email protected] UseCanonicalName Off DocumentRoot "/home/www/default" <Directory /> Options FollowSymLinks AllowOverride None </Directory> <Directory "/home/www/default"> Options Indexes FollowSymLinks AllowOverride None Order allow,deny Allow from all </Directory> DirectoryIndex index.html index.html.var index.php index.php.var AccessFileName .htaccess <Files ~ "^\.ht"> Order allow,deny Deny from all </Files> TypesConfig conf/mime.types DefaultType text/plain <IfModule mod_mime_magic.c> MIMEMagicFile conf/magic </IfModule> HostnameLookups Off ErrorLog logs/error_log LogLevel warn LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined LogFormat "%h %l %u %t \"%r\" %>s %b" common LogFormat "%{Referer}i -> %U" referer LogFormat "%{User-agent}i" agent CustomLog logs/access_log combined ServerTokens OS ServerSignature On Alias /icons/ "/usr/local/apache2/icons/" <Directory "/usr/local/apache2/icons"> Options Indexes MultiViews AllowOverride None Order allow,deny Allow from all </Directory> IndexOptions FancyIndexing VersionSort AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip AddIconByType (TXT,/icons/text.gif) text/* AddIconByType (IMG,/icons/image2.gif) image/* AddIconByType (SND,/icons/sound2.gif) audio/* AddIconByType (VID,/icons/movie.gif) video/* AddIcon /icons/binary.gif .bin .exe AddIcon /icons/binhex.gif .hqx AddIcon /icons/tar.gif .tar AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip AddIcon /icons/a.gif .ps .ai .eps AddIcon /icons/layout.gif .html .shtml .htm .pdf AddIcon /icons/text.gif .txt AddIcon /icons/c.gif .c AddIcon /icons/p.gif .pl .py AddIcon /icons/f.gif .for AddIcon /icons/dvi.gif .dvi AddIcon /icons/uuencoded.gif .uu AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl AddIcon /icons/tex.gif .tex AddIcon /icons/bomb.gif core AddIcon /icons/back.gif .. AddIcon /icons/hand.right.gif README AddIcon /icons/folder.gif ^^DIRECTORY^^ AddIcon /icons/blank.gif ^^BLANKICON^^ DefaultIcon /icons/unknown.gif AddDescription "GZIP compressed document" .gz AddDescription "tar archive" .tar AddDescription "GZIP compressed tar archive" .tgz IndexIgnore .??* *~ *# HEADER* README* RCS CVS *,v *,t AddLanguage ca .ca AddLanguage cs .cz .cs AddLanguage da .dk AddLanguage de .de AddLanguage el .el AddLanguage en .en AddLanguage eo .eo AddLanguage es .es AddLanguage et .et AddLanguage fr .fr AddLanguage he .he AddLanguage hr .hr AddLanguage it .it AddLanguage ja .ja AddLanguage ko .ko AddLanguage ltz .ltz AddLanguage nl .nl AddLanguage nn .nn AddLanguage no .no AddLanguage pl .po AddLanguage pt .pt AddLanguage pt-BR .pt-br AddLanguage ru .ru AddLanguage sv .sv AddLanguage zh-CN .zh-cn AddLanguage zh-TW .zh-tw LanguagePriority no nn en ForceLanguagePriority Prefer Fallback AddCharset ISO-8859-1 .iso8859-1 .latin1 AddCharset UTF-8 .utf8 AddEncoding x-compress .Z AddEncoding x-gzip .gz .tgz AddType application/x-compress .Z AddType application/x-gzip .gz .tgz AddHandler cgi-script .cgi AddHandler type-map var BrowserMatch "Mozilla/2" nokeepalive BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0 BrowserMatch "RealPlayer 4\.0" force-response-1.0 BrowserMatch "Java/1\.0" force-response-1.0 BrowserMatch "JDK/1\.0" force-response-1.0 BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully BrowserMatch "^WebDrive" redirect-carefully BrowserMatch "^WebDAVFS/1.[012]" redirect-carefully BrowserMatch "^gnome-vfs" redirect-carefully NameVirtualHost *:80 NameVirtualHost *:443 <Directory /> Order Deny,Allow Deny from All </Directory> <Directory /home/www/*/www> Order Deny,Allow Allow from All </Directory> <Directory /home/www/*/ssl> Order Deny,Allow Allow from All </Directory> SSLRandomSeed startup builtin SSLRandomSeed connect builtin Include conf/vhost/*.conf conf/vhost/mail.w4n.org.conf <VirtualHost *:80> ServerAdmin [email protected] DocumentRoot /home/www/mail.w4n.org/www ServerName mail.w4n.org ErrorLog /home/www/mail.w4n.org/logs/error_log TransferLog /home/www/mail.w4n.org/logs/access_log </VirtualHost> <VirtualHost *:443> ServerAdmin [email protected] DocumentRoot /home/www/mail.w4n.org/ssl ServerName mail.w4n.org ErrorLog /home/www/mail.w4n.org/logs/ssl_error_log TransferLog /home/www/mail.w4n.org/logs/ssl_access_log SSLEngine on SSLProtocol all SSLCipherSuite HIGH:MEDIUM <Files ~ "\.(cgi|php?)$"> SSLOptions +StdEnvVars </Files> SSLCertificateFile conf/ssl/mail-server.crt SSLCertificateKeyFile conf/ssl/mail-server.key SSLCACertificateFile conf/ssl/my-ca.crt SSLCACertificatePath conf/ssl </VirtualHost> ca er generert slik: openssl genrsa -des3 -out my-ca.key 2048 openssl req -new -x509 -days 3650 -key my-ca.key -out my-ca.crt openssl x509 -in my-ca.crt -text -noout key og certificate slik: openssl genrsa -des3 -out mail-server.key 1024 openssl req -new -key mail-server.key -out mail-server.csr openssl x509 -req -in mail-server.csr -out mail-server.crt -sha1 -CA my-ca.crt -CAkey my-ca.key -CAcreateserial -days 3650 openssl x509 -in mars-server.crt -text -noout chmod 0400 *.key ser dere noe galt? se https://mail.w4n.org for error. Lenke til kommentar https://www.diskusjon.no/topic/465805-apache-ssl-vhost-error/
