petterg Skrevet 1. september 2005 Del Skrevet 1. september 2005 (endret) Scrollhjulet på musa gjør ingenting i kde. Det funker i kde på Knoppix live cd. Det gir også respons vet cat /dev/input/mice. Tipper det da er config av Xorg eller kde som er problemet. Noen forslag til løsning? Edit: Det er en A4tech WOP35 mus Løsningen: http://forums.gentoo.org/viewtopic-t-98028.html Endret 19. september 2005 av petterg Lenke til kommentar
petterg Skrevet 1. september 2005 Forfatter Del Skrevet 1. september 2005 Xorg.conf Section "ServerLayout" Identifier "X.org Configured" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" RgbPath "/usr/lib/X11/rgb" ModulePath "/usr/lib/modules" FontPath "/usr/share/fonts/misc/" FontPath "/usr/share/fonts/TTF/" FontPath "/usr/share/fonts/Type1/" FontPath "/usr/share/fonts/CID/" FontPath "/usr/share/fonts/75dpi/" FontPath "/usr/share/fonts/100dpi/" EndSection Section "Module" Load "glx" Load "extmod" Load "xtrap" Load "record" Load "dbe" Load "dri" Load "freetype" Load "type1" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" EndSection Section "Monitor" #DisplaySize 280 210 # mm Identifier "Monitor0" VendorName "IBM" ModelName "198f" Option "DPMS" EndSection Section "Device" ### Available Driver options are:- ### Values: <i>: integer, <f>: float, <bool>: "True"/"False", ### <string>: "String", <freq>: "<f> Hz/kHz/MHz" ### [arg]: arg optional #Option "SWcursor" # [<bool>] #Option "HWcursor" # [<bool>] #Option "NoAccel" # [<bool>] #Option "ShadowFB" # [<bool>] #Option "UseFBDev" # [<bool>] #Option "Rotate" # [<str>] #Option "VideoKey" # <i> #Option "FlatPanel" # [<bool>] #Option "FPDither" # [<bool>] #Option "CrtcNumber" # <i> #Option "FPScale" # [<bool>] #Option "FPTweak" # <i> Identifier "Card0" Driver "nv" VendorName "nVidia Corporation" BoardName "NV5M64 [RIVA TNT2 Model 64/Model 64 Pro]" BusID "PCI:2:0:0" EndSection Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" SubSection "Display" Viewport 0 0 Depth 1 Modes "800x600" EndSubSection SubSection "Display" Viewport 0 0 Depth 4 Modes "800x600" EndSubSection SubSection "Display" Viewport 0 0 Depth 8 Modes "800x600" EndSubSection SubSection "Display" Viewport 0 0 Depth 15 Modes "800x600" EndSubSection SubSection "Display" Viewport 0 0 Depth 16 Modes "800x600" EndSubSection SubSection "Display" Viewport 0 0 Depth 24 Modes "800x600" EndSubSection EndSection Lenke til kommentar
zyp Skrevet 1. september 2005 Del Skrevet 1. september 2005 Endre: Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" EndSection Til: Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" EndSection Lenke til kommentar
olear Skrevet 1. september 2005 Del Skrevet 1. september 2005 (endret) *slettet* EDIT: Var litt treig der ja Endret 1. september 2005 av olear Lenke til kommentar
petterg Skrevet 1. september 2005 Forfatter Del Skrevet 1. september 2005 Det var ikke værre, nei Mange takk! Lenke til kommentar
petterg Skrevet 1. september 2005 Forfatter Del Skrevet 1. september 2005 Foresten, hva står "4 5" for? Lenke til kommentar
zyp Skrevet 1. september 2005 Del Skrevet 1. september 2005 Knapp 4 og 5. Scrollehjulet sender henholdsvis signal 4 og 5 når du ruller opp og ned. Merk at eventuelle sideknapper (som vanligvis kalles for knapp 4 og 5) derfor er 6 og 7. Lenke til kommentar
petterg Skrevet 2. september 2005 Forfatter Del Skrevet 2. september 2005 Aha Hva gjør man da med mus som har flere knapper og sideveis scroll? (Hva erstatter man "ZAxisMapping" med?) Lenke til kommentar
escariot Skrevet 2. september 2005 Del Skrevet 2. september 2005 Hvis jeg tør gjette.. og det gjør jeg. Option "ZAxisMapping" "4 5" - ruller opp og ned Option "XAxisMapping" "6 7" - ruller vel da venstre og høyre vil jeg tro.. Er vel logisk utifra at det ser ut som man ligger i XYZ (3D) planet? Men da burde vel strengt tatt ZAxis vært YAxis? tja.. -Escariot Lenke til kommentar
zyp Skrevet 2. september 2005 Del Skrevet 2. september 2005 X har ikke innebygget støtte for sideveis scroll, men det kan gjøres ved å binde hendelsene til tastetrykk på høyre/venstre piltast. For å ta i bruk alle knappene anbefales det å bruke evdev. En guide for å ta i bruk alle tastene på en Logitech MX1000 finner man her. Lenke til kommentar
petterg Skrevet 3. september 2005 Forfatter Del Skrevet 3. september 2005 Hvis jeg tør gjette.. og det gjør jeg. Option "ZAxisMapping" "4 5" - ruller opp og ned Option "XAxisMapping" "6 7" - ruller vel da venstre og høyre vil jeg tro.. Er vel logisk utifra at det ser ut som man ligger i XYZ (3D) planet? Men da burde vel strengt tatt ZAxis vært YAxis? tja.. -Escariot Jeg tror X og Y er bevegelse av musen. Scroll er å betrakte som en tredje dimmensjon. Snodig at X ikke støtter sideveis scroll. Det har jo eksistert lenge. Aner ikke når det kom, men jeg har hatt det siden min første pentium2 fra 1998. Å konfigurere devicer ser vanskelig ut. Greit nok å følge en howto som passer en spessiell enhet, men å tenke seg til hvordan min egen mus skal settes opp var litt i overkant. Finnes noen "ev/udev for dummies"? Hvordan mapper man til piltaster (og andre taster)? Lenke til kommentar
zyp Skrevet 3. september 2005 Del Skrevet 3. september 2005 Angående korrektheten i mitt forrige utsagn kan jeg ikke garantere noe, men såvidt jeg vet så støtter den ikke horisontal scroll. Hvilken mus har du? Er vanligvis bare å google etter den så finner du en passende howto. Lenke til kommentar
petterg Skrevet 3. september 2005 Forfatter Del Skrevet 3. september 2005 A4tech WOP35, WWW35, WWW5 (tre maskiner, tre mus, alle på PS2) Lenke til kommentar
petterg Skrevet 10. september 2005 Forfatter Del Skrevet 10. september 2005 Dette var løsningen på horisontal scrolling: Option "Buttons" "7" Option "ZAxisMapping" "4 5 6 7" Lenke til kommentar
zyp Skrevet 10. september 2005 Del Skrevet 10. september 2005 Da lærte man noe nytt i dag også. Lenke til kommentar
petterg Skrevet 12. september 2005 Forfatter Del Skrevet 12. september 2005 Jeg sliter fortsatt med sideknappene. De gir respons ved cat /dev/input/mouse0 Ved å mappe disse til vertikal scroll virker de. Da fungerer plutselig horisontal scroll som back/forward i browser. Scrollhjulet gjør da ingenting. Dersom de ikke er mappet til scroll gir de heller ingen respons i xev. (Har satt Option "Buttons" "9" for dette.) Jeg prøvde imwheel uten suksess. Lenke til kommentar
petterg Skrevet 19. september 2005 Forfatter Del Skrevet 19. september 2005 Denne guiden gjorde susen: http://forums.gentoo.org/viewtopic-t-98028.html Bare huske at med to scrollhjul skal man bytte ut 6 og 7 med hhv 8 og 9 Lenke til kommentar
