raakken Skrevet 1. september 2005 Del Skrevet 1. september 2005 Hei Har nå lest litt rundt og prøvd å endre X11/XF86Config-4, for å få høyere enn 8000*600 i oppløsning. Men jeg får det ikke til... Er det noen som bruker debian her som kan hjelpe meg? her er fila ihverfall: Section "Files" FontPath "unix/:7100" # local font server # if the local font server has problems, we can fall back on these FontPath "/usr/lib/X11/fonts/misc" FontPath "/usr/lib/X11/fonts/cyrillic" FontPath "/usr/lib/X11/fonts/100dpi/:unscaled" FontPath "/usr/lib/X11/fonts/75dpi/:unscaled" FontPath "/usr/lib/X11/fonts/Type1" FontPath "/usr/lib/X11/fonts/CID" FontPath "/usr/lib/X11/fonts/Speedo" FontPath "/usr/lib/X11/fonts/100dpi" FontPath "/usr/lib/X11/fonts/75dpi" EndSection Section "Module" Load "GLcore" Load "bitmap" Load "dbe" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "record" Load "speedo" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "keyboard" Option "CoreKeyboard" Option "XkbRules" "xfree86" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Device" Identifier "NVIDIA Corporation NV25 [GeForce4 Ti 4200]" Driver "nv" EndSection Section "Monitor" Identifier "Generic Monitor" HorizSync 28-64 VertRefresh 43-87 Option "DPMS" EndSection Section "Screen" Identifier "Default Screen" Device "NVIDIA Corporation NV25 [GeForce4 Ti 4200]" Monitor "Generic Monitor" DefaultDepth 24 SubSection "Display" Depth 1 Modes "800x600" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "800x600" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "800x600" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "800x600" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "800x600" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1024x768" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" EndSection Section "DRI" Mode 0666 EndSection Lenke til kommentar
Palme Skrevet 1. september 2005 Del Skrevet 1. september 2005 Prøv å kommenter ut (sitt # fremfor:) #HorizSync 28-64 #VertRefresh 43-87 Lenke til kommentar
objorkum Skrevet 1. september 2005 Del Skrevet 1. september 2005 (endret) Som sagt prøv å kommenter ut VertRefresh og HorizSync, og så restart X (logg ut så Ctrl+Alt+Backspace) EDIT: Høgare enn 8000*600 får du nok ikkje Endret 1. september 2005 av objorkum Lenke til kommentar
Palme Skrevet 1. september 2005 Del Skrevet 1. september 2005 EDIT: Høgare enn 8000*600 får du nok ikkje That's teh real HDTV Lenke til kommentar
petter1 Skrevet 1. september 2005 Del Skrevet 1. september 2005 Du kan også bruke dpkg-reconfigure xserver-xfree86. Lenke til kommentar
raakken Skrevet 2. september 2005 Forfatter Del Skrevet 2. september 2005 8000 var vel litt mer enn jeg håpet på, men jeg skifta nå litt på noen verdier og skrev inn en oppløsning jeg ville ha, men ingenting skjedde. Men da jeg slo på maskinen idag var oppløsningen høyere(det jeg satte den til, 1024*768) Så nå er jeg fornøyd kan noen forklare meg på dummy metoden hvordan jeg skal mounte en harddisk. Har fulgt råd og slikt, men den nekter rett og slett... mounter den under home, men mounter bare en mappe med det navnet jeg har laget, ikke selve harddisken Lenke til kommentar
olear Skrevet 2. september 2005 Del Skrevet 2. september 2005 kan noen forklare meg på dummy metoden hvordan jeg skal mounte en harddisk.Har fulgt råd og slikt, men den nekter rett og slett... mounter den under home, men mounter bare en mappe med det navnet jeg har laget, ikke selve harddisken mount /dev/en_partisjon /en_mappe Lenke til kommentar
