Hvordan endre navn på papirkurven?
Slapp av! Du trenger ikke å fortvile!
Se her
http://easy.box.sk/indexN.php?pid=tips&cos...j=detail&id=965
" Rename your Recycle Bin
contibutor: Abhinav Jain, Jan, 8 2002
Ok..this is a registry edit trick...click on start>run> type regedit and press enter...a window will pop-up. Click on edit>find> there type "Recycle Bin" without the quotes. press ok.
Wait for some time until a result is found..then on the right side the name "recycle bin" appears..simply right click (Default) and select modify...tadda u can now rename it to anything (I have kept it Dust Bin)
You can also modify the infotip the same way [NOTE : when u clik on the recycle bin and hold your mouse there for a while, the infotip text popups] "
:grin: :grin: :grin: :lol :grin:
