pc2700u 2.5-3-3-7: hva betyr dette egetelig ?
sinnaelgen
hva betyr dette.
pc2700u 2.5-3-3-7
pc2700 har jeg lest om på pcworld men hva betyr de andre begrepen egentelig
sandra finner dette :
SiSoftware Sandra
Mainboard
Manufacturer : ASUSTeK Computer INC.
MP Support : No
Model : P4PE
Version : REV 1.xx
Serial Number : xxxxxxxxxxx
System BIOS : 11/10/2003-I845PE/ICH4/IT8708-P4PE
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 2GB
Bank 1 - DIMM 1 : DIMM Synchronous DRAM 512MB/72
Bank 2 - DIMM 2 : Empty
Bank 3 - DIMM 3 : Empty
Chipset 1
Model : ASUSTeK Computer Inc 82845PE Brookdale Host-Hub Interface Bridge (B0-step)
Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus
Front Side Bus Speed : 4x 101MHz (404MHz data rate)
Maximum FSB Speed / Max Memory Speed : 4x 133MHz / 2x 166MHz
Width : 64-bit
IO Queue Depth : 8 request(s)
Chipset 1 Hub Interface
Type : Hub-Interface
Version : 1.50
Number of Ports : 1
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Speed : 4x 66MHz (264MHz data rate)
Logical/Chipset 1 Memory Banks
Bank 0 : 256MB DDR-SDRAM 2.0-2-2-5 1CMD
Bank 1 : 256MB DDR-SDRAM 2.0-2-2-5 1CMD
Speed : 2x 134MHz (268MHz data rate)
Multiplier : 4/3x
Width : 64-bit
Power Save Mode : No
Fixed Hole Present : No
Memory Module 1
Type : 512MB DDR-SDRAM
Technology : 16x(32Mx8)
Speed : PC2700U 2.5-3-3-7
Date of Manufacture : 25. desember 1999
Set Timing @ 167MHz : 2.5-3-3-7
Set Timing @ 133MHz : 2.0-2-2-6
er det noen vits å endre på noe av dette for å få maskina til å jobbe raskere på de tyngste jobene?.
