XHTML: Problemer med validering
Heisann.
Sliter med å få denne teksten validert av http://validator.w3.org/ :
<?xml version = "1.0"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 1.0 Frameset//EN"
 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-frameset.dtd">
<html xmlns = "http://www.w3.org/1999/xhtml">
<head>
 <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
 <title>Eriks Webpage</title>
</head>
<frameset cols="10%,80%">
 <frame src="venstre.htm" >
   <frame src="hoyre.htm" >
  </frameset >
</html>
Får følgende feil:
Result: Failed validation, 0 error
Unknown Parse Mode!
The MIME Media Type (text/html) for this document is used to serve both SGML and XML based documents, and it is not possible to disambiguate it based on the DOCTYPE Declaration in your document. Parsing will continue in SGML mode.
Namespace Found in non-XML Document
Namespace "" found, but document type is not XML!
Ble litt uryddig kode her, gitt.. men det får gå.
Noen som kan hjelpe?
Prøv å legge til denne her:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html lang="en" xml:lang="en" xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" />
</head>
Endret av OShea
Takker for svar.
Har gjort litt om på koden så den nå ser slik ut:
<head>
</head>
 <frame src="venstre.htm" />
   <frame src="hoyre.htm" />
  </frameset >
</html>
Virker som om validatoren likte det bedre, men står igjen med følgende melding:
No Character Encoding Found! Falling back to UTF-8.
I was not able to extract a character encoding labeling from any of the valid sources for such information. Without encoding information it is impossible to reliably validate the document. I'm falling back to the "UTF-8" encoding and will attempt to perform the validation, but this is likely to fail for all non-trivial documents.
Såvidt jeg skjønner så må jeg angi character encoding. Hvor gjør jeg det?
<head>
</head>
  </frameset >
</html>
