Knutgrus Skrevet 1. september 2005 Del Skrevet 1. september 2005 Driver å skal oppgradere for tiden. Henger ikke med i heletatt. Hvor stor forskjell er det mellom ei brikke som har 3 CAS Latency mot ei som har 2 CAS Latency? Lenke til kommentar
Smirnoff Skrevet 2. september 2005 Del Skrevet 2. september 2005 http://en.wikipedia.org/wiki/Cas_latency Uansett, det det koker ned til er: "the CAS Latency (CL) refers to the length of time, in clock cycles, it takes for a request sent from the memory controller to read a memory location and send it to the module's output pins." "When selecting a RAM card the lower the CAS latency rating the better your system will perform. Current DDR2 RAM should have a CAS latency of about four, or optimally three." Lenke til kommentar
