"System volume information", kan jeg slette denne?
Det ser ut til at Google kan lede meg til informasjon om dette ...
If you've done much wandering around in Windows Explorer you might have noticed a folder called System Volume Information and wondered what purpose it serves. It's actually a part of System Restore; the tool that allows you to set points in time to roll back your computer. The System Volume Information folder is where XP stores these points and associated information that makes them accessible. If you have System Restore enabled but don't see this folder, go into [Tools] [Folder Options] [View] and click the radio button next to [show Hidden Files and Folders] and it will be visible.
How many System Volume Information folders your computer has and where they are located depends on the settings you've selected for System Restore.
