Ikkje noe 7800 Ultra ?
jon-t
Har heilt sikkert vert fleire liknene emner før, men var inne på Nvidia sine hjemmesider og leste litt i FAQen deires om 7800serien og fant noe interessant:
Q: Is there a GeForce 7800 Ultra?  GeForce 7800 GTX is our top of the line. We had so much positive response for the GT SKU (single slot, great performance) that we wanted to build upon that success and brand. GeForce 7800 GTX takes NVIDIA's high end performance offering to the next level.
Og
The GeForce 7800 GTX will be NVIDIA's new flagship GPU, replacing the GeForce 6800 Ultra at the top of our product line.
Kommer det sli med fleir enn to gpuer?
Q: Does GeForce 7800 GTX support more than two GPUs in SLI mode?  No - not right now.
Dei har ikkje utelukka agp heilt enda
Q: Will you use HSI to make AGP-based GeForce 7800 boards?  We are not disclosing plans for AGP at this time, but that is certainly possible with the flexibility of our HSI chip.
