Nye SLi hovedkort fra ASUS baseret på nForce 4
Boralis
Taipei, Taiwan; Aug 22, 2005 – In accordance to the release of Nvidia®’s nForce™ 4 SLI X16 chipset, ASUSTeK Computer Inc. (ASUS) today introduced the A8N32-SLI Deluxe and P5N32-SLI Deluxe motherboards, which support dual PCI Express x16 slots running at full speed to liberate graphics cards from the narrow bandwidth platform of x8 speed only.
“ASUS proudly announces the A8N32-SLI Deluxe and P5N32-SLI Deluxe motherboards, which are the most powerful motherboards in our product line", said Joe Hsieh, Director of ASUS Motherboard Business. "The obstacle during development is to include a reliable thermal solutions. With ASUS’ innovative designs to bring out the real potential of Nvidia’s latest chipsets, gamers can enjoy faster graphics and higher video quality.”
High-performance GPU (graphics processing unit) is one of the hottest components in a computer system. SLI motherboards, with two graphics cards, require the best heat dissipation designs.
One of the reliable thermal solutions is Stack Cool 2. Originally implemented on the Intel 955 and 945 chipset platforms, the A8N32-SLI Deluxe and P5N32-SLI are the first Nvidia-chipset based motherboards with this zero noise feature. Stack Cool 2 is a fan-less cooling design that effectively transfers heat generated by the critical components to the other side of the specially designed PCB (printed circuit board) for heat dissipation and significantly decreases component temperature.
The P5N32-SLI Deluxe further pushes Intel based motherboards well into the extreme gaming segment. The dual x16 SLI architecture provides excellent scalability, and of course, renowned ASUS performance and overclocking quality will ensure an unparalleled gaming experience for Intel fans.
The A8N32-SLI Deluxe and P5N32-SLI Deluxe will be available in September. Below are their brief specifications.
A8N32-SLI Deluxe
- AMD Athlon 64 FX/Athlon 64 X2/Athlon 64 / Sempron
- NVIDIA GeForce™ 6150 and NVIDIA nForce 4 SLI
- 2000/1600 MT/s System Bus
- 4 x DIMM, max. 4GB, DDR 400/333/266
- 2 x PCIe x16 (running @ x16 speed), 1 x PCIe x4, 3 x PCI 2.2
- Dual Gigabit LAN
- 6 x Serial ATA 3 GB/s ports including 1 external port
- 2 x IEEE 1394a
- ASUS two-slot thermal design
- ASUS Stack Cool 2
P5N32-SLI Deluxe
- Intel Pentium Processor Extreme Edition/Pentium D/Pentium 4/Celeron
- NVIDIA nForce 4 SLI Intel edition and NVIDIA nForce 4 SLI
- FSB 1066/800/533 MHz
- 4 x DIMM, max. 16GB, DDR2 667/533
- 2 x PCIe x16 (running @ x16 speed), 2 x PCIe x1, 1 x PCIe x4, 2 x PCI 2.2
- Dual Gigabit LAN
- 2 x IEEE 1394a
- ASUS Stack Cool 2
http://www.asus.com/
Dammit! Har akkurat bestilt ASUS A8N SLI Premium. De kunne godt ha venta, ihvertfall litt. Faktisk, så kunne de godt ha tilpasset takta på produktlanseringer mye bedre med takta på mine PC kjøp. Dette er og blir et helv***, nå har jeg venta nesten sida August ifjor, og tenkte at ...nå - endelig er de her, alle delene jeg vil ha.... også skjer sånt dagen etter at bestillinga er gjort. Kanke ha råd til det nyeste annenhver måned.
Hvis de bare kunne ringe litt oftere, og høre om når det er greit...
:whistle:
...og hvor blir de av - disse fantastiske, helt nyskapende, flotte BIOS'ene de lovde oss for snart to år sida..?
Endret av khaakon
Rompa di
:cry:
Nei, unnskyld, det var ikke pent
Stå på, snekkern. Kjøp og test og kast og bruk, så lenge du gjør sånn en god innsats med å holde oss andre informert. Har lest mange bra innlegg fra deg. Er jo bare misunnelig (på den rompa)
Endret av khaakon
"One of the reliable thermal solutions is Stack Cool 2. Originally implemented on the Intel 955 and 945 chipset platforms, the A8N32-SLI Deluxe and P5N32-SLI are the first Nvidia-chipset based motherboards with this zero noise feature. Stack Cool 2 is a fan-less cooling design that effectively transfers heat generated by the critical components to the other side of the specially designed PCB (printed circuit board) for heat dissipation and significantly decreases component temperature."
Jaha, en annen løsning enn Asus A8N-SLI Premium altså?
Er det slik å forstå at hvis man på ASUS A8N SLI Premium kjører 2 SLI kort går hastigheten ned til 8x, mens kjører man med et kort har man 16x ?
Eller kjører det på 8x uansett ? Vurderer å kjøpe 7800 GT og nytt hovedkort. Kommer nok aldri til å kjøre med SLI. Lurer på om jeg skal vente eller kjøpe ASUS A8N SLI Premium nå.
Arne M
nVidia sitt nye chipset + E4 og E6 stepping av Athlon64 gjør det kanskje mulig å kjøre med 4 RAM brikker @ DDR400++ 2-2-2-5 1CMD nå da!?
Definitivt ikke.
Det vil gjelde for de første SLI-kortene ja. På de nye vil man få 16x på hvert kort, og man trenger heller ikke velge SLI-modus.
Denne doblingen i båndbredden virker temmelig meningsløs på meg. Når de først skal øke antallet PCIe-kanaler burde nVidia ha prioritert annerledes.
Edit: PCIe-kanaler, ikke SLI-kanaler :p
Endret av Bob Ibsen
  • 1 måned senere...
Noen som har fått dette kortet ennå?
Er jo litt skuffende at det i realiteten bare er 5 "vanlige" SATA plasser, det er jo en nedgradering fra A8N-SLI deluxe og A8N-SLI premium. Hvis man fyller de 5 så må man kople siste disken på den eksterne porten og trekke en lang strømledning til den. :thumbdown:
