Glipp Skrevet 17. august 2005 Del Skrevet 17. august 2005 DriverHeaven har slippet ATI sine drivere en dag før ATi selv hjør det (ikke leaked.. full version av den..) FIXED in drivers: Sitat Issues Resolved in Catalyst™ Software Suite 5.8 The following section provides a summary of the issues that have been resolved in the latest version of Catalyst™. These include: * Battlefield 2: Geometry corruption or missing textures are no longer noticed when playing the game for an extended period of time under Windows XP with an ATI Radeon® X800 XT installed * 3D Mark03: Enabling Powerplay mode and running the 3DMark03 or 05 in a loop no longer results in an error message being displayed * Area51_2.3dc: Playing the game under Windows XP no longer results in the NPC and guns appearing distorted, flashing or missing. Further the polygons no longer pop in and out of the display * GTA: Vice City: Setting the desktop and the game display option to 1024x768 32bpp and attempting to play the game under Windows XP MCE, no longer results in an Invalid Pixel Format message being displayed after approximately 5 minutes of game play * Lineage 2: Playing the game under Windows XP no longer results in display corruption being noticed * Movie Maker 2: Connecting an external video source using the S-video composite connectors, no longer results in the Movie Maker 2 application intermittently failing to capture video, when selecting the Capture from Video Source * MU Online: Opening a chat window and playing the on-line game no longer results in hesitation being noticed when pressing the Enter key * Quake 3: Enabling SmartShader™ followed by attempting to do a mode change while playing the game, no longer results in the game failing to respond * Star Wars Knights of the Old Republic: Running the Dantoonie level of the game no longer result in hesitation being noticed * Terathon: Starting the Terathon 3D engine and selecting a single player demo, no longer results in the 3D engine failing to respond under Windows XP * Trackmania Sunrise: Playing the game under Windows XP no longer results in the operating system failing to respond, when attempting to exit the game after leaving the PC idle for an extended period of time * Warcraft III: Playing the game under Windows XP with the display rotated by 90 degrees CCW, no longer results in display corruption being noticed * Performing an overwrite of the video driver install, no longer results in the Hydravision Multidesk feature being unable to load * Video mode and Overscan can now be enabled when connecting a TV as the secondary display device and setting the display resolution to 640x480 32bpp 60Hz and extending the desktop * The Select by Signal Format is now the default setting when connecting a TV to an ATI display adapter * Catalyst™ Control Center: Updates to saved profiles is now available * Catalyst™ Control Center: Connecting a TV using the S-Video connector no longer results in the Apply button found in the TV properties of the Catalyst Control Center being active when no changes are made to the TV properties * Catalyst™ Control Center: An intermittent service error message is no longer displayed when starting up the Windows XP MCE operating system * Connecting a TV as the secondary display device and a CRT as the primary display device, no longer results in the Video mode and Overscan option not functioning properly when extended desktop is enabled * Catalyst™ Control Center: Double clicking anywhere on the Catalyst™ Control Center background after changing the color correction to the Full Screen 3D option no longer results in a full screen preview * Hesitation is no longer noticed when attempting to resume from an S3 or S4 state with Analog tv * Random display corruption is no longer noticed when playing a raw audio/video capture for the first time * Configuring Windows Media Encoder 9 as ATI AVStream Analog capture and ATI AVStream Analog Audio capture, followed by selecting a TV channel as input, no longer results in the both the Input and Output windows going black when Start Encoding is clicked * The DVB-T channel scan time no longer appears to be slow * Catalyst™ Control Center: Graphic truncation is no longer noticed under the Desktop and Display Setup of the Display Manager, in the German edition of the Catalyst Control Center * Catalyst™ Control Center: The text found in the Overlay/VIDEOVISION section of the Catalyst™ Control Center is no longer cut-off for the Turkish edition of the Catalyst™ Control Center * Setting the desktop resolution to 1024x768 32bpp and using the DVI connector to hot-plug an HDMI display device, no longer results in an error message being displayed * Using the ATI recommended speed option found in the Overdrive™ tab of the Catalyst™ Control Center, no longer results in the engine and memory clock values being the same as the default values * Using the DVI connector for a DFP display device, and the S-Video connector for a TV, no longer results in the driver returning the wrong display mappings when unplugging the DFP display device and extended desktop is enabled * Catalyst™ Control Center: The Set Desktop Area To, is no longer enabled and the resolution list is no longer available, when hot-unplugging a secondary display device under Windows XP * Playing an MPEG file on a secondary display device that is connected to the DVI port, no longer results in the lower portion of the playback window being missing * Hesitation in the Aquarium screen saver is no longer noticed when the ATI Multimedia Center™ is running * Using a limited account under Windows XP and changing the SmartShader™ aspect from none to black and white, no longer results in a general protection fault * Creating a custom hot-key for rotation no longer results in the custom hot-key to become unavailable for the secondary display device, when extended desktop is enabled and both display devices are set to 1280x1024 **Download** Lenke til kommentar
embark Skrevet 17. august 2005 Del Skrevet 17. august 2005 Laster heller ned fra www.ati.com. Lenke til kommentar
Glipp Skrevet 17. august 2005 Forfatter Del Skrevet 17. august 2005 Ferr skrev: Laster heller ned fra www.ati.com. joa.. sikkert mange som kommer til og gjøre det men det er fremdeles den samme filen Lenke til kommentar
Goodall Skrevet 17. august 2005 Del Skrevet 17. august 2005 (endret) Ati har ikke lagt den ut enda da Og denne tråden ble lagt ut i går Så 5.8 var allerede mulig å få tak i går, synes det da at det er veldig rart ATI ikke har lagt ut sine, hvis dette er de driverne som kommer ut Endret 17. august 2005 av Goodall Lenke til kommentar
embark Skrevet 17. august 2005 Del Skrevet 17. august 2005 Goodall skrev: Ati har ikke lagt den ut enda da Hvorfor ikke? Lenke til kommentar
Ronnie Skrevet 17. august 2005 Del Skrevet 17. august 2005 (endret) Det er ikke så veldig merkelig hvis en følger litt med på www.driverheaven.net . De har en egen kategori i forumet hvor Catalyst driverne diskuteres. I denne kategorien er ofte Terry Makedoni som er leder for Catalyst teamet til ATI aktiv. Han ønsket igår å gi leserne av dette forumet en forsmak på 5.8 driveren. Drieverheaven fikk driverpakken og de som ønsket det kunne laste ned fra de et døgn før ATI legger ut driveren på sine sider. Kanskje det også er en liten testmulighet for å se om driveren blir godt mottat. Driverpakken som ble sluppet er med CCC. Driver med CP blir sluppet idag på ATI sine sider. Det sies også at ATI ikke vil slippe drivere med CP etter 5.9. Så det er kanskje greit å prøve driveren med CCC i denne realesen. Ronnie Endret 17. august 2005 av Ronnie Lenke til kommentar
Goodall Skrevet 17. august 2005 Del Skrevet 17. august 2005 Ronnie skrev: Det sies også at ATI ikke vil slippe drivere med CP etter 5.9. Så det er kanskje greit å prøve driveren med CCC i denne realesen. Ronnie Uff det var trist, jeg synes CP er så mye mere oversiktlig og brukervenlig enn CCC, har prøvd CCC 3-4 ganger ca. og hver gang så har jeg gått tilbake CP etter en uke Lenke til kommentar
Ronnie Skrevet 17. august 2005 Del Skrevet 17. august 2005 Ellers så blir vel driveren lagt ut på ATI sine sider ca. 21 - 22 ikveld. De pleier å legge de ut kl 15.00 på ettermiddagen i Canada og det er 6 timers tidsforskjell til oss. Samtidig påpeker jeg at det jeg sa om CCC bare er ting som er kommet fram i forumet og ikke bekreftet av ATI.com Lenke til kommentar
ExcaliBuR Skrevet 17. august 2005 Del Skrevet 17. august 2005 De er ute på ATi sine sider nuh =) Lenke til kommentar
superdigg Skrevet 17. august 2005 Del Skrevet 17. august 2005 Noen av oss hentet den i går: http://forum.hardware.no/index.php?showtopic=458019 Lenke til kommentar
Vargtass Skrevet 17. august 2005 Del Skrevet 17. august 2005 (endret) Testet den nå med 3DMark05: Cat 5.6: 5.710 Cat 5.8: 5.667 (hoppet over cat 5.7..) Ned 0,75% fra cat 5.6 - ikke allverden. 5.8 skal vist løse en del 'issues' med BF2 og x800xt - har ikke spilt med 5.8 enda. mvh r.- Endret 17. august 2005 av roger_h99 Lenke til kommentar
Glipp Skrevet 17. august 2005 Forfatter Del Skrevet 17. august 2005 yup.. skal teste den etter jeg kommer hjem fra arbeid i morgen Lenke til kommentar
ExcaliBuR Skrevet 17. august 2005 Del Skrevet 17. august 2005 superdigg skrev: Noen av oss hentet den i går: http://forum.hardware.no/index.php?showtopic=458019 Poenget var at nå støtter ATi de offisielt, noe som ble påpekt på DH.com at deres ikke var før ATi slapp de selv Lenke til kommentar
Gjest Slettet+3124 Skrevet 17. august 2005 Del Skrevet 17. august 2005 Catalyst 5.8 er offisielt sluppet på ati.com Lenke til kommentar
HKS Skrevet 17. august 2005 Del Skrevet 17. august 2005 Jepp, og versjon av 8.16.20 Linux driveren demmes er også sluppet! https://support.ati.com/ics/support/default...ge&folderID=300 Det kommer seg, det kommer seg... Lenke til kommentar
cyberpet Skrevet 17. august 2005 Del Skrevet 17. august 2005 Ronnie skrev: Det er ikke så veldig merkelig hvis en følger litt med på www.driverheaven.net . De har en egen kategori i forumet hvor Catalyst driverne diskuteres. I denne kategorien er ofte Terry Makedoni som er leder for Catalyst teamet til ATI aktiv. Han ønsket igår å gi leserne av dette forumet en forsmak på 5.8 driveren. Drieverheaven fikk driverpakken og de som ønsket det kunne laste ned fra de et døgn før ATI legger ut driveren på sine sider. Kanskje det også er en liten testmulighet for å se om driveren blir godt mottat. Driverpakken som ble sluppet er med CCC. Driver med CP blir sluppet idag på ATI sine sider. Det sies også at ATI ikke vil slippe drivere med CP etter 5.9. Så det er kanskje greit å prøve driveren med CCC i denne realesen. Ronnie Virker jo litt rart hvis de skulle gjøre det.. er det ikke en del kort som ikke har støtte for CCC?? Correct me if im wrong... Lenke til kommentar
superdigg Skrevet 17. august 2005 Del Skrevet 17. august 2005 Sitat Raptor' date='17/08/2005 : 23:39'] Jepp, og versjon av 8.16.20 Linux driveren demmes er også sluppet! https://support.ati.com/ics/support/default...ge&folderID=300 Det kommer seg, det kommer seg... Jøss! Impregnerende! Linux-support kan jeg like. Lenke til kommentar
- Cre8or - Skrevet 18. august 2005 Del Skrevet 18. august 2005 Prøvde akkurat Catalyst 5.8 med Battlefield 2 og fikk svart skjerm etter 10 minutter.. Prøvde en gang til, å det samme skjedde, lyden hang seg opp og det kom "rare" prikker på skjermen.. Trur nok jeg går tilbake til 5.7 hvis det ikke tilfeldigvis var noe annet som gjorde det.. Har et Sapphire Radeon X 850 XT PE.. Lenke til kommentar
tbend Skrevet 18. august 2005 Del Skrevet 18. august 2005 Ser du har klokket det Det kan tilfeldigvis ikke være årsaken? Lenke til kommentar
