Lang DVI kabel som funker?
AndersT2
Er det noen som har en lang DVI kabel som funker? Den må være rundt 10 meter.
Har en kompis som kjøpte en 10 m DVI kabel på svinesund, og den ga røde prikker og streker i de sorte områdene. Dette forsvant når vi byttet til den korte til
PC skjermen.
Så hvilke merker er garantert å funke? Denne var kjøpt i vanlig elektrosjappe, og er sikkert beregnet for videosignaler fra DVD til projektor.
Et lite søk på google gir denne infoen:
http://www.scala.com/hardware/dvi-vga-cable.html:
"Using copper cable it would appear that the limits are approximately 1600x1200@60Hz to one meter and 1024x768@60Hz to 9 meters with appropriate signal strength from the graphics adapter. "
"Our cables are configured for single or dual link operation, and use super high resolution (24-gauge wire) cables, while most consumer-grade DVI cables use smaller, 28-gauge wire. This limits consumer-grade cables to lower resolutions and distances of less than 5 meters. "
http://www.datapro.net/techinfo/dvi_info.html#Page04
"HOW LONG DOES DVI GO?
The official DVI specification deems that all DVI equipment must
maintain a signal at 5 meters (16 feet) in length. But many manufacturers
are putting out much stronger cards and bigger monitors, so the maximum
length requirement is not ever specified.
In-house tests on varying equipment have produced strong signals up
to 9 and 10 meters long. Tests at 12 meters resulted in signal loss and
an unusuable image on the display.
Keep in mind that when using DVI-I cables at extensive lengths, you
may not be seeing a digitally-clear image on your screen. Because analog
has a much longer run, your display may auto-switch once the digital signal
is too weak. For this reason, long runs are best done with DVI-A or VGA,
but if you really want to make sure you're getting the best (digital) image,
use only DVI-D cables."
Ved google søk benytt DVI length evt. DVI lengde for å få infp henholdsvis internasjonalt eller i Norge. Du vil også få tilslag på salgssteder.
Kablen er av type DVI-D og på boksen den kom i var det spesifisert at den skulle ta oppløsninger opptil 2048x1024. Mener han også sa han hadde testet med lavere oppløsning. Men skal spørre ham igjen.
Kan skjermkortet ha noe å si. Han har jo kun ett X600 kort
