Redigere HD-video: Et problem?
Det stemmer.
System requirements
• Intel® Pentium® 4, 3GHz 533 FSB Hyper-Threaded (Pentium 4, 3.2 GHz 800 FSB Hyper-Threaded recommended)
• Microsoft® Windows® XP Professional or Home Edition with Service Pack 2
• 1GB of 333Mhz DDR RAM (1GB of 400Mhz DDR RAM in Dual Channel configuration recommended)
• 800MB of available hard-disk space for installation
Ikke noe å spøke med mao.
Hmm... hvor mye plass tar en times HDV når det overføres ukomprimert fra kamera? Vet at vanlig DV er 13 gigabyte, så da burde vel HDV være en del mer?
HDV-standarden nytter MPEG2-koding, for å spare plass (noko som i sin tur gjer redigering litt vanskelegare pga. måten MPEG2 vert koda på.). Er ikkje sikker, men eg trur HDV har omlag same bitrate som DV. OM eg hugser rett, har HDV 19 MBit/s, medan DV har 25 MBit/s.
Endret av incanus
Beklager dobbeltpost.
Frå hdvinfo.net:
"Basically, HDV is a 19 megabit-per-second MPEG-2 transport stream that records to existing standard DV format digital video cassettes, the most popular form factor of which is the Mini-DV shell. The transport stream interface conforms to IEEE 1394 (FireWire). HDV is native 16:9 at a resolution of 1280 pixels wide by 720 pixels tall. Supported frame rates are 60i (frames-per-second interlaced), 30p (progressive), 50i, and 25p."
