SWAT 4 bare stopper, og det kommer "critical error
Hei.. Nå i det siste har jeg spilt en del SWAT 4 igjen, men de siste gangene har spillet bare stoppet og gått tilbake til windows igjen, så kommer det en "critical error" Det står følgende:
No Label
Crash Time: 08/13/05 19:40:48
OS: Windows XP 5.1 (Build: 2600)
CPU: AuthenticAMD Unknown processor @ 2654 MHz with 1023MB RAM
Video: RADEON 9800 XT (Omega 2.6.25a) (6512)
UserName: -------
ComputerName: ------
Application location: D:\SWAT 4\Content\System\
SWAT Build Number: 31973
Access Violation caused General protection fault!
History: APawn::FindAnchor <- APawn::GetRoomName <- APawn::execGetRoomName <- UObject::CallFunction [sCRIPT=Engine.Pawn.GetRoomName' OBJ='SwatHostage23] <- APawn::execIsInRoom <- UObject::CallFunction [sCRIPT=Engine.Pawn.IsInRoom' OBJ='SwatEnemy8] <- UObject::CallFunction [sCRIPT=SwatAICommon.ThreatenHostageAction.GetClosestUsableHostageInRoom' OBJ='ThreatenHostageAction8] <- UObject::CallFunction [sCRIPT=SwatAICommon.ThreatenHostageAction.CanThreatenHostage' OBJ='ThreatenHostageAction8] <- UObject::ProcessEvent [Function SwatAICommon.ThreatenHostageAction.selectionHeuristic() on ThreatenHostageAction SP-DNA.ThreatenHostageAction8] <- UAI_Resource::chooseAction <- UAI_Resource::ProcessGoals [(SwatCharacterResource SP-DNA.SwatCharacterResource18)] <- APawn::UpdateCharacterAI <- ASwatPawn::TickSpecial <- ASwatAI::TickSpecial [swatEnemy8 - Location: (-6499.009766, 1148.427246, 263.950012)] <- ASwatAICharacter::TickSpecial <- AActor::Tick [Actor: 'SwatEnemy8' Actor->bDeleteMe: FALSE] <- ASwatRagdollPawn::Tick <- TickAllActors <- ULevel::Tick [(NetMode=0)] <- TickLevel <- UGameEngine::Tick <- UpdateWorld <- MainLoop->GenerateExtraCrashInfo [(GLevel: 'myLevel' PendingLevel: '(NULL)' NetMode: 'NM_Standalone'] <- MainLoop
Skjønner ikke så mye av det jeg :p Men ser det står general protection fault.. Hva nå det vil si...?
Overklokka litt i går også, kan det ha noe å si?
Takk for svar :thumbup:
Endret av erlendru
Har du installert nyeste patch til spillet?
Klikket ikke spillet sånn før?
Prøv å installere nyere/gamlere skjermkortdrivere eller å re-installere selve spillet.
EDIT: Overklokking kan ha noe å si, ja. Prøv å klokke tilbake, og se om spillet fortsatt klikker. ;)
Endret av MeTa][iC
