trx Skrevet 13. august 2005 Del Skrevet 13. august 2005 (endret) Grunnen til at jeg lager en ny topic om dette, er fordi problemet mitt har forandret seg litt siden sist. Jeg fant en side (link) etter et google-søk, og han har akkurat samme problem som meg: I have just installed a new Seagate Barracuda 7200.7 200gb (ST3200822A) drive to replace an old 9gb drive. Windows XP Disk Manager recognises the drive and reports it as 186.31GB Unallocated. I can create a Primary Partition on this drive to use up all 186.31GB, however if I also choose to format it then at the very end of the format process I get the error "Logical Disk Manager: The format did not complete successfully". The drive appears in Windows Explorer and when I try to access it I am told that it is not formatted and prompts me to format it - which also fails. I have also tried using Partition Magic 8.0 but this fails with Error #514 Unknown error formatting volume during the final stage of Updating System Information. When searching the Net, the number 137GB kept appearing as a "large disk" boundary which may cause problems, so I tried creating a partition of 130GB and it worked, however this leaves me with 70GB of wasted space! I am unable to create more partitions to use up the extra space as the formatting fails. I am running Windows XP SP2 (I also tried it with SP1 before upgrading to SP2). The fact that windows CAN see the full size of the disk and create partitions, but cannot format them seems curious. Bortsett fra at jeg har en Samsung 250 GB IDE disk, har jeg samme problem. Jeg har ikke prøvd å opprette en partisjon på 130GB da. Det høres rart ut, fordi partisjoner kan jo være over 137 GB! Som han fyren får som svar, kan visst atapi.sys-filen være gammel. Men det skjønner jeg ikke, fordi jeg har alle oppdateringer, inkludert SP2. Noen som veit løsningen på mitt problem, så blir jeg glad! Endret 13. august 2005 av trx Lenke til kommentar
trx Skrevet 13. august 2005 Forfatter Del Skrevet 13. august 2005 Hva er LBA? Og for å komme inn i BIOS, det er da man som regel trykker en av FX-tastene (F1, F2 osv) når maskinen starter ja? Lenke til kommentar
Jarmo Skrevet 13. august 2005 Del Skrevet 13. august 2005 Hva er LBA? Og for å komme inn i BIOS, det er da man som regel trykker en av FX-tastene (F1, F2 osv) når maskinen starter ja? Ofte DEL også.. der ser du disken din. http://www.48bitlba.com/ Lenke til kommentar
trx Skrevet 13. august 2005 Forfatter Del Skrevet 13. august 2005 Takk for linken! Skal sjekke om det er enablet, men tror det siden jeg også har en 200GB disk som funker utmerket uten at den er partisjonert opp. Lenke til kommentar
Jarmo Skrevet 13. august 2005 Del Skrevet 13. august 2005 Takk for linken! Skal sjekke om det er enablet, men tror det siden jeg også har en 200GB disk som funker utmerket uten at den er partisjonert opp. Man kan sette opp LBA manuelt for hver enkel disk... Lenke til kommentar
trx Skrevet 14. august 2005 Forfatter Del Skrevet 14. august 2005 Og en ting til. Jeg har endelig fått formatert harddisken ved å skrive cmd i run-menyen, og format I: Når jeg nå skriver format i: står følgende: "Filsystemet er RAW Bruk /FS-bryteren for å angi filsystemet du vil bruke på dette volumet" Hva menes med dette? Hvilken bryter er det snakk om? Finnes det noen komandoer jeg kan skrive inn for å fikse det (jeg bruker NTFS)? Lenke til kommentar
Jorgur_ Skrevet 14. august 2005 Del Skrevet 14. august 2005 Jeg tror det er omtrent noe sånt: En bryter (eng: Parameter) er ekstra alternativer når man utfører en komando (en komando er f.eks: format c:). I DOS skriver man bryterene med en skråstrek etter komandoen slik: c:\test.exe /install I dette tilfellet brukes bryterene til å angi hvilket filsystem du vil ha på harddisken din. De mest vanlige filsystemene er NTFS, FAT32, FAT16. Hvilket filsystem som passer best for deg, kommer an på. Det finnes mange tråder som forklarer mer detaljert om dem. Hvis du ikke er helt sikker, kan jeg si at jeg bruker NTFS, og det fungerer fint. Jeg er ikke sikker på hvilke brytere du skal bruke, det må noen andre svare på. Lenke til kommentar
trx Skrevet 14. august 2005 Forfatter Del Skrevet 14. august 2005 Okei, takk! Om noen veit hvilke brytere jeg skal benytte, rop ut (NTFS passer nok best for meg, har alltid brukt det). Lenke til kommentar
Jorgur_ Skrevet 14. august 2005 Del Skrevet 14. august 2005 Fant netopp ut at du kan skrive format /? for å få oversikt over bryterene. Prøv format x: /fs:ntfs x= stasjonsbokstaven på disken din Lenke til kommentar
trx Skrevet 14. august 2005 Forfatter Del Skrevet 14. august 2005 Etter litt googling og prøving fant jeg det ut akkurat før jeg leste dette, hehe. Uansett, takk for hjelpen! Lenke til kommentar
